Old August 17th, 2011, 01:10 AM   #1
Timon
Timon's Avatar
Motorcycle(s): Ninja EX250R
Stompgrip (new gen precut) on pre gen
I fitted Stompgrip from the new gen on my pre gen.
Timon is offline   Reply With Quote
Old August 18th, 2011, 08:57 PM   #2
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Did you have to modify it at all? What are your impressions?
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old August 18th, 2011, 10:54 PM   #3
Timon
Timon's Avatar
Modifications, none. It did take a lot of time to line up to make it match. Also the new gen comes with two for each side, obviously i only used one per side.
My impressions so far are that they are absolutely awesome. I had issues with sliding while corner and this solved the problem. A bit on the pricey side, I think getting a generic set and cutting it to match both sides might be a bit cheaper, but still well worth the money either way.
Old August 20th, 2011, 07:14 PM   #4
vince_2149
vince_2149's Avatar
Motorcycle(s): 2012 Ninja 250
Looks great!
And that's exactly what I did. I was afraid the precuts for the 08 would look weird so I went with the generics and used one of the patterns they provide for free. I only had to use one of the 2 sheets provided, plus you get the tank protector also.
Hope you don't mind me posting some pictures:
vince_2149 is offline   Reply With Quote
Old August 20th, 2011, 07:53 PM   #5
Timon
Timon's Avatar
Nice! I like the looks of yours. Is the tank protector made of the same material?
Old August 20th, 2011, 08:05 PM   #6
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Motorcycle(s): 1997 Ninja 250
Looking good! Blue or bust!
Mocha Man is offline   Reply With Quote
Old August 22nd, 2011, 12:07 AM   #7
vince_2149
vince_2149's Avatar
Thanks. Like I said, the universal kit comes with quite a few patterns to choose from and I thought this one looked like a good match.
Yep, it's the same material (I went with snakeskin) and comes precut in that shape which is really nice.
Old August 24th, 2011, 10:02 PM   #8
tanman2003
tanman2003's Avatar
Motorcycle(s): 2004 Kawasaki Ninja 250, 2007 Harley Davidson Nightster XL 1200N
how about this for a pattern?
tanman2003 is offline   Reply With Quote
Old November 30th, 2011, 12:41 PM   #9
andylawcc
Motorcycle(s): 2007 Ninja 250 faster red
looks good vince_2149!
andylawcc is offline   Reply With Quote
Old January 4th, 2012, 10:28 PM   #10
duckracer
duckracer's Avatar
Motorcycle(s): Ducati 1098 and 04 Ninja 250 race bikes
I have used boat non slip step material, and it works great. You can cut to fit. I got it at Bass Pro
duckracer is offline   Reply With Quote
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. AFazakerley 2008 - 2012 Ninja 250R Tech Talk 11 June 5th, 2016 02:03 PM
Fitting a new gen front wheel on a pre gen? thumper64 1986 - 2007 Ninja 250R Tech Talk 13 November 6th, 2013 02:44 PM
Bike size, new gen vs pre gen(zzr) bowerbird100 General Motorcycling Discussion 6 August 1st, 2013 05:49 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
FS/ part out new gen and pre gen 250r ninja carlos Motorcycle-related 3 May 14th, 2012 10:25 PM
