Old November 30th, 2010, 11:59 PM   #1
dyeforever
dyeforever's Avatar
Motorcycle(s): 04 250r(sold), 09 250r(sold), 07 CRF450x, 07 sv650(sold)
Flickering headlight and stuck blinkers
Got back to riding my 250 after about two weeks and noticed a couple problems.
First problem is when i turn, put my blinker on and it stayed on, no blinking. If i cancel my blinker and put it back on it sometimes it will blink. the problem comes and goes. sometimes it will get stuck on at idle but when i rev it to 6k it starts to blink again. thought it would be my koso gauge causing this problem, so i installed my stock gauge cluster. nope problem still is there.
Next problem in my headlight flickers at idle and low rpm. I'll be sitting in my garage and can watch the headlight flicker. go out riding and it flickers below 6k or so, but in the upper rpm range it clicks and go back to normal. swap high beam bulb with the low beam, nothing.
Havent check the stator output yet, but i really hope it not that. any suggestion or help would be great.
dyeforever is offline   Reply With Quote
Old December 1st, 2010, 12:17 AM   #2
Momaru
Momaru's Avatar
Just a couple ideas:
Check for corrosion on the wiring/connectors on the headlights.
Check the turn signal relay and all of the turn signal bulbs.
Proud member of the Blue Army
Old December 1st, 2010, 11:18 AM   #3
dyeforever
dyeforever's Avatar
Checked all the plugs out everything looks fine. Going to test the battery today.
Old December 1st, 2010, 12:07 PM   #4
g21-30
g21-30's Avatar
The headlight flicker sounds like you have another accessory (aftermarket?) drawing excessive amps. The alternator reaches max power at 6K RPMs. Coincidentally, that is when your flicker stops. So, what could it be?
The turn signals are another problem..most likely a loose or bad connection on the side that is the problem. Make believe it is your left side and turn on the signal. If the front left bulb lights and the rear left doesn't, you have a loose connection in the left rear wiring. If the rear lights and the front doesn't, then the problem is in the front. By not blinking, the turn signal lets you know that either a bulb is burnt out or there is a wiring problem.
Old December 1st, 2010, 04:10 PM   #5
dyeforever
dyeforever's Avatar
Hmm, I do have accessory lights for my licence plate. Will test that tonight.
Old December 1st, 2010, 05:34 PM   #6
g21-30
g21-30's Avatar
Could also be something that continues to draw power while the bike is not running and possibly drains the battery.
Old December 1st, 2010, 09:50 PM   #7
dyeforever
dyeforever's Avatar
unplugged the license plate light, same problem. the blinkers stay steady on with the key on, bike off. going to swap parts with my brothers bike and try and find the problem.
Old December 1st, 2010, 11:35 PM   #8
UltrA_09
UltrA_09's Avatar
Motorcycle(s): Ninja 250R '09, SV650s '07
The first thing I'd swap out would be the turn signal relay (located under the rear tail fairing). It might very well fix the 'signal sticking' issue.
Goodluck!
UltrA_09 is offline   Reply With Quote
Old December 4th, 2010, 12:03 AM   #9
dyeforever
dyeforever's Avatar
Got around to fixing tonight. it was really bad riding tonight, so pull the fairings. checked all the wiring, no loose or frayed wire. remove the whole koso gauge harness, plugged in my stock gauge again. most the problems went away. blinker now blinks with key on bike off. headlight dont flicker, or barely enough to notice. im kinda bummed, i really like the koso gauge.
Old December 4th, 2010, 02:07 PM   #10
dyeforever
dyeforever's Avatar
Anyone with a koso rx2 installed having headlight, blinker or the oil, check engine light flicker on?
Old December 7th, 2010, 12:12 AM   #11
dyeforever
dyeforever's Avatar
Rode tonight still have the flickering headlights. anyone know how to test the stator?
Old December 7th, 2010, 01:03 PM   #12
do you have a service manual? what year is the bike? your info says new gen but your avatar says pre
gen.
Old December 7th, 2010, 01:30 PM   #13
Sailariel
Sailariel's Avatar
A good friend, who is a MC mechanic, says that 90% of electrical problems eventually are traced to a poor ground. He also suggested that you look at what you worked on last.
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550
Old December 7th, 2010, 09:53 PM   #14
dyeforever
dyeforever's Avatar
no service manual, but it a 09. think im the fourth or fifth owner of the bike. could be the ground, does a bike ground through the frame or everything grounds back at the battery?
Old December 10th, 2010, 12:36 PM   #15
Momaru
Momaru's Avatar
Not to pick nits here, but is your profile pic a picture of your bike? If so I'm pretty sure it's an '07 or earlier model, due to the left-hand exhaust and the single-piece seat, amongst other things. Might wanna check on that, there's a bunch of differences.
Old December 10th, 2010, 06:56 PM   #16
dyeforever
dyeforever's Avatar
That a pic of my old ninja. have gotten a chance to snap a pic of the new one.
Old December 11th, 2010, 08:35 AM   #17
Momaru
Momaru's Avatar
Hehehe, okies. Thought you might've been seriously mislead by the previous owner. /end derail
Old December 11th, 2010, 09:36 AM   #18
UltrA_09
UltrA_09's Avatar
Goodluck!
Have you tried switching the relay up for a new one? you can get one for around $10 from your local auto store.
Old December 15th, 2010, 09:24 PM   #19
dyeforever
dyeforever's Avatar
swap out the blinker relay from my brother bike. same problem. cant seem to find any ground that i would of disconnect when changing the gauge out. going to test the stator output tomorrow.
Old December 21st, 2010, 02:46 PM   #20
dyeforever
dyeforever's Avatar
tested the alternator today. output is good but too high. putting out about 60v when it should only be doing around 40v. regulator/rectifier is damaged.
Old December 22nd, 2010, 02:50 AM   #21
dyeforever
dyeforever's Avatar
Haha found it. was a loose ground on the battery. looked tight but grab the wire and it wiggled around. tighten it down and everything work fine. my water temp light stay on for a second or two after i start it, but that minor.
Dash lights flickering no starter ?!?! jamasda 2008 - 2012 Ninja 250R Tech Talk 7 May 6th, 2014 08:06 PM
Tail light flickering problem... skilletmo 2008 - 2012 Ninja 250R Tech Talk 7 August 9th, 2013 04:18 PM
Dash lights/ front headlights flickering? gilmorec61 2008 - 2012 Ninja 250R Tech Talk 17 February 27th, 2012 08:42 AM
Help Oil lights flickering mrscbw 2008 - 2012 Ninja 250R Tech Talk 58 April 1st, 2011 12:18 PM
Flickering HIDs The_beanz 2008 - 2012 Ninja 250R Tech Talk 2 February 1st, 2010 03:17 PM
