Old October 29th, 2013, 09:00 AM   #1
gkarats
gkarats's Avatar
Motorcycle(s): 08 Ninja 250r
bar ends....
hi another question....i pulled off the stock bar ends, what a pain that was and im left with a threaded end. From my understanding this can be removed? If so how, has anyone done this.
? Any help appreciated thanks
20131029_081803 by g_karats
gkarats is offline   Reply With Quote
Old October 29th, 2013, 09:59 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
don't think there is anything to come off there. My memory tells me the bar is one piece and it is threaded at the end. This diagram agrees with my memory but I supposed I could still be wrong?
http://www.kawasakipartshouse.com/oe...9fd6/handlebar
Old October 29th, 2013, 10:09 AM   #3
gkarats
gkarats's Avatar
For some reason i thought i heard those could be removed? By the looks of the parts list you are correct sir!
Thanks for the response!
Old October 29th, 2013, 10:47 AM   #4
SMman
SMman's Avatar
Motorcycle(s): 15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R
They cannot be removed. How's the vibration without the bar ends? I installed non-weighted Vortex bar end sliders on my ZX-6R and the vibes were so bad that I had to put the stock bar ends back on.
15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R 636
SMman is offline   Reply With Quote
Old October 29th, 2013, 12:14 PM   #5
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
If I remember when I switched to my clip-ons, I think the threaded (kind of threaded weld nut) part is welded to the handle bar.
You might be able to cut it or saw it in a way or another, but you won't be able to put them back the "OEM" way.
broken neck is offline   Reply With Quote
Old October 29th, 2013, 12:31 PM   #6
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
It's part of the bar, but you can put a bolt or plastic plug in there to cover it.
Chicagobob is offline   Reply With Quote
Old October 29th, 2013, 01:28 PM   #7
gkarats
gkarats's Avatar
Yes it is welded, the bar is hollow though if you can get past the threads. Going to leave it the way it is. Thanks all:-)
Old October 29th, 2013, 01:30 PM   #8
gkarats
gkarats's Avatar
I haven't ridden too much with them off and so far I did not notice a difference in vibration.
Old October 29th, 2013, 09:27 PM   #9
rasta
Your face
rasta's Avatar
Not that it matters anymore lol, but drilling into the stock threads (as outlined here) makes removing the bolts soooo much easier.
If/when you choose to put a bar end back on, you should totally use an allen bolt!
Old October 30th, 2013, 05:26 AM   #10
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
I feel like if you use the right tools removing the bar ends is non issue.
I have removed 3 sets from different bikes with a good quality bit that fits well placed into a bit holder then attached to a extension for maximum torque. No heat and they twist right out.
The bit quality and fit is paramount
Bar Ends skilletmo 2008 - 2012 Ninja 250R Tech Talk 8 March 8th, 2013 11:17 PM
bar ends skikman 1986 - 2007 Ninja 250R Tech Talk 8 January 7th, 2013 06:15 AM
!@#$!ing bar ends! Torch, impact screwdriver, breaker bar, etc ALL failed. :( CZroe 2008 - 2012 Ninja 250R Tech Talk 64 September 13th, 2012 11:50 AM
Bar ends james250ninja 2008 - 2012 Ninja 250R Tech Talk 8 October 22nd, 2011 08:54 PM
bar ends james250ninja 1986 - 2007 Ninja 250R Tech Talk 13 April 22nd, 2010 04:06 AM
