Old September 20th, 2011, 01:55 PM   #1
poo poo
kinda sorta noob
Motorcycle(s): '03 and '08
Weird. Sometimes it doesn't shift to second.
Sometimes I try to shift from first to second (let's say around 7-9k rpm), and it feels like it went, but then I let go of the clutch, and it's still in first, which can be a bit unsettling while in traffic. I recently lubes the clutch cable, but put everything back the way it was. Does anyone have any ideas of what might be going on? I would be very much ingratiated......
“Riding a motorcycle is ten percent hands and feet and ninety percent mind and eyes.”
poo poo is offline   Reply With Quote
Old September 20th, 2011, 02:22 PM   #2
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
Try adjusting your shift linkage to make sure you get a good, firm shift.
LazinCajun is offline   Reply With Quote
Old September 21st, 2011, 08:30 AM   #3
Jinx250
Smoker
Motorcycle(s): Guess....
It happens. Shift more firmly. If it keeps happening, adjust the position of the shifter.
Jinx250 is offline   Reply With Quote
Old September 21st, 2011, 08:44 AM   #4
PHL
Motorcycle(s): 2014 Street Triple R
Can't remember if this applies to your problem, or if it's an issue with getting a false neutral. Regardless, a FAQ on the ninja250.org recommends keeping holding the shifter (rather than releasing) in place to ensure the shift is complete. I'll post back when I can find that page.
PHL is offline   Reply With Quote
Old September 21st, 2011, 11:24 AM   #5
If your tires aren't turning fast enough, the positive neutral finder will prevent you from shifting into second.
Old September 21st, 2011, 06:19 PM   #6
LazinCajun
LazinCajun's Avatar
But at 7-9k RPM like the OP said, you're going plenty fast to bypass the neutral finder.
Old September 22nd, 2011, 05:36 AM   #7
I can rev the RPM at a stop. :P
It's tire speed and not engine speed.
Old September 22nd, 2011, 09:53 AM   #8
LazinCajun
LazinCajun's Avatar
Old September 22nd, 2011, 02:57 PM   #9
poo poo
kinda sorta noob
Thanks! Still haven't solved it, but....
Good ideas! I'll let y'all know what I discover...
Old September 23rd, 2011, 07:47 AM   #10
Chuffmonkey
Chuffmonkey's Avatar
Motorcycle(s): 2012 Triumph Street Triple R, 2011 250R SE (sold 5/8/13)
I've been having the same problem shifting up into 3rd for the last week or so - it started right after my 600 mile service. I'll also try holding the shifter up
Chuffmonkey is offline   Reply With Quote
Here's a weird one... misfitsailor Help 4 August 17th, 2014 07:48 PM
Weird :/ reabo 2008 - 2012 Ninja 250R Tech Talk 16 April 12th, 2013 03:55 AM
WTB: New gen shift linkage + shift knuckle + Woodcraft rear sets 675Raisinator Items Wanted 1 July 30th, 2012 05:59 PM
[faster and faster] - EBR1190RS doesn’t have traction control, doesn’t need it Ninjette Newsbot Motorcycling News 0 November 3rd, 2011 02:10 AM
