Old January 2nd, 2014, 09:53 AM   #41
old3
im going to make a bet that the bike was used and the PO put new springs in but didn't cut new spacers..... or put any oil in.
With the way they built mine, Kawasaki might have forgotten to put any in during assembly!
old3 is offline   Reply With Quote
Old January 2nd, 2014, 10:10 AM   #42
maybe the post shipping assembly guy for your bike "fixed it up" for you, old3
Old January 2nd, 2014, 10:25 AM   #43
old3
Maybe I'm not paranoid and "they" ARE out to get me too!!!
Na, they would have gone pretty far out of their way to do that! My front brake caliper was loose after a few hundred miles!
Old January 2nd, 2014, 11:23 AM   #44
Old January 2nd, 2014, 11:49 AM   #45
Jim, I like those bearings on my stem as much as the next guy, but that isn't the biggest problem here. She's getting pogo-ing and (dependig on the op's answer) excessive sag. That sounds like fork internals, not head stem bearings. Those are for AFTER we get the pogo feeling figured out.
Old January 2nd, 2014, 12:39 PM   #46
and here i thought stem bearings were responsible for controlling fork damping.
Old January 2nd, 2014, 04:03 PM   #47
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I see a nutty Florida mod thread coming with airbags rear, air assist springs front... Who got the gold plater??? We gonna pimp my riiiiiiiiide
Old January 2nd, 2014, 07:29 PM   #48
old3
I'm only sure there is a known issue and it takes about 5 minutes to check for it, if that. Can't hurt to look. I've dealt with a few rider complaints that were resolved nowhere near what they thought the problem area was.
My first suggestion is to check for metallic noises/sensations while topping out the forks, which could be internals or the commonly loose and failure prone bearings.
Not every rider is a great diagnostics tool!
Old January 2nd, 2014, 07:32 PM   #49
old3
Originally Posted by treecat View Post
the way she describes it, its like its rebounding too quickly toping out compressing and topping out again and again and again even on smoothish roads.
she was bottoming it out and getting the harshness you described but with the preload spacers I cut her she hasnt bottomed it since
Like clunkity clunkity as she goes down a smooth road? Check the steering bearings for sure. It don't cost ya nuthin!
Old January 2nd, 2014, 08:06 PM   #50
treecat
Motorcycle(s): r6
Its a brand new bike. 1200 ish km on it (booked in for first service early next week)
it sags about 40mm-45mm with her weight and no preload spacers. its in the right ballpark when I added the spacers.
treecat is offline   Reply With Quote
Old January 2nd, 2014, 08:21 PM   #51
old3
I'm getting 25mm of bike sag at the fork, full gas tank and a tank bag loaded with 3-4 lbs., 9,000 miles on stock springs and stock length preload total. I cut the spacers to allow for the emulator length. You had 30mm on a stock bike? Not really that far off considering the tolerances everywhere else!
How experienced and mechanical is the rider having the problem? What is rider weight?
Old January 2nd, 2014, 11:01 PM   #52
good job. i hope she gave you head for fixing her bike. i know if a girl fixed my bike i'd give her head for sure.
Old January 3rd, 2014, 10:44 AM   #53
JohnnyBravo
Anyone need bike work done??? Hahaha
Sounds like folks around here pay good
Old January 3rd, 2014, 12:31 PM   #54
Lychee
sail away
Lychee's Avatar
The information in this thread is weird. I always thought that compressed air/gas injection into an oil based shock was done to pressurize the oil chamber and prevent cavitation. Only small, small amounts of air should be added and the actual damping is still done by the oil.
Old January 3rd, 2014, 12:50 PM   #55
old3
OP was looking for more spring rate/bottoming resistance, not damping from air.
Old January 4th, 2014, 07:30 PM   #56
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
70s era dirt bikes used air, oil, and springs. In the 80s the shrader valve on dirt bikes was there to release air after the heat of the fork movement increased psi and resulted in a harsher ride. Now some mx bikes 450 Honda and kawi use air as the spring rather than a coil spring.
Old January 4th, 2014, 07:31 PM   #57
Correct. Whish is what adding air will do.
[motorcycledaily.com] - Michelin Launches Motorcycle Air Pressure Safety Campaign (In Ninjette Newsbot Motorcycling News 0 May 28th, 2014 01:50 PM
Hey, thanks for adding me. NickNYC New Members 25 January 27th, 2012 12:17 AM
Adding another one to the stable... Apex Off-Topic 16 March 18th, 2010 05:56 PM
[faster and faster] - Aero 3S add bling to the Campagna T-Rex, OptaMotive to add batt Ninjette Newsbot Motorcycling News 0 April 27th, 2009 10:30 PM
Air Pressure Gauge, which type to get? 00v_Lucky General Motorcycling Discussion 11 April 4th, 2009 08:27 PM
