Go Back   ninjette.org > Marketplace > Motorcycle-related
Old May 10th, 2014, 05:35 PM   #1
iZapp
former ninja 250'er
iZapp's Avatar
Motorcycle(s): Aprilia 1000R, CRF450, CBR600RR tracktoy, Ninja 250 -- GONE!!!!!
modified counter shaft cover, GP shift
for sale: our modified counter shaft cover that has the bottom part milled away, thus allowing use of the stock shift mechanism in GP mode (with lever flipped). Can also be used in standard shift mode. $20
iZapp is offline   Reply With Quote
Old May 15th, 2014, 10:55 AM   #2
WAGESLAVEesc
Motorcycle(s): 04 250R
Interesting, could you explain what you mean by the shift mechanism in gp mode?
WAGESLAVEesc is offline   Reply With Quote
Old May 15th, 2014, 11:18 AM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
It's the Anti-shift.
Old May 15th, 2014, 11:27 AM   #4
upside down
Old May 15th, 2014, 04:51 PM   #5
WAGESLAVEesc
Um I don't get it at all. So the clutch handlever is on backwards? Or the clutch is normally disengaged and only engages while the clutch lever is held? Or something else?
Old May 15th, 2014, 04:54 PM   #6
iZapp
former ninja 250'er
iZapp's Avatar
yep, and the rear brake is connected the throttle!
Old May 15th, 2014, 04:55 PM   #7
instead of pushing up on the shift lever to go up, you push down on the shift lever to go up. it's because people get used to doing things backwards because of countersteering, so they want their shifting backwards too
Old May 15th, 2014, 04:57 PM   #8
iZapp
former ninja 250'er
iZapp's Avatar
jk.
by swapping the linkage on the shifter, it requires a downward motion to upshift, thus making it easier to change gears while accelerating out of a corner due to foot clearance (foot's now ON TOP of the shift lever).
Old May 15th, 2014, 04:58 PM   #9
Instead of clicking up to upshift, and down to downshift, it's.....
....click down to upshift, and click up to downshift.
(1-up, 5 down instead of 1-down, 5 up).
EDIT: beat by a whole bunch of posts!
Old May 15th, 2014, 05:00 PM   #10
Originally Posted by iZapp View Post
easier to change gears while accelerating out of a corner due to foot clearance (it's now ON TOP of the shift lever).
so then the rear brake is automatically applied once you let off the throttle. and with the upside down shifting the clutch is always in so you can just change gears whenever you want!... right?
Old May 15th, 2014, 05:31 PM   #11
CC Cowboy
CC Cowboy's Avatar
I still want to know how to get the clutch lever on backwards?
Old May 15th, 2014, 09:25 PM   #12
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
This thread has so much troll in it, I am about to dye my hair purple and spike it up
For the youngins:
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Old May 16th, 2014, 12:04 AM   #13
Old May 16th, 2014, 02:01 PM   #14
dukeswift
dukeswift's Avatar
Motorcycle(s): 02 Aprilia RS70 97 Ninja 250
Good job sir, you made me LOL pretty hard there.
dukeswift is offline   Reply With Quote
Old May 16th, 2014, 02:14 PM   #15
WAGESLAVEesc
lolol ok ty for the explanation that makes sense
shift shaft seal BukkShot Items Wanted 4 March 21st, 2015 10:35 PM
Counter balance shaft side clearance cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 4 May 4th, 2014 05:09 PM
Is this shift shaft damaged? indr 2008 - 2012 Ninja 250R Tech Talk 4 January 5th, 2013 05:49 AM
2008 - 2012 Ninja counter balance shaft elimination? spooph 2008 - 2012 Ninja 250R Tech Talk 8 October 22nd, 2012 12:18 PM
Anyone replace a shift shaft seal. zzrguy General Motorcycling Discussion 3 March 18th, 2012 09:32 AM
