Old January 11th, 2009, 02:31 AM   #1
headshrink
headshrink's Avatar
Rejetting - what time of year?
Rejetting will likely be the next thing I do to my bike, if I don't go with the heated jacket first (just ordered gloves).
Since there are so many factors in rejetting, I was wondering how much it mattered which season, or what the weather is like, when this work is done. I am in CA and ride 12 months out of the year to commute to work. It is hot in the summer (90's - low 100's) and moderately cold in the winter (30's-50's).
I don't know if any of this matters, but then again.... that is my question.
Old January 11th, 2009, 02:45 AM   #2
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
From what I believe, the temperature has got apart to play in it as the density of the air and how much gets into the engine is related on the air temp, I THINK the hotter it is, the denser the air is, colder the other way round.
You could rejet on a day that is an avg temp over the whole year, this will give a bike with the best power at the mid temps (as this is what you would tune for) or, you could tune (shimming the needles) when the temps get hotter and colder, this will gove you the most power for that temp range, but requires shimming more often.
Note, take my advise with a grain of salt, this is what I believe and I am new to this, so I could be wrong, wait for the others to advise.
Viper-Byte is offline   Reply With Quote
Old January 11th, 2009, 03:19 AM   #3
headshrink
headshrink's Avatar
Thanks.
Cold air is denser, but I know what you meant
Old January 11th, 2009, 04:38 AM   #4
Viper-Byte
Viper-Byte's Avatar
NP
Well I had a 50/50 chance of getting it right, I guess I should have looked it up, just couldn't be bothered
Old January 11th, 2009, 08:46 AM   #5
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
It does make a difference. I am running one jet richer right now for the colder days. When the temperature drops below 55 or so there is a noticeable difference in power. On really warm days there is an obvious lack of power...
Once spring time comes around I aim on stepping back down one jet size, and then back up next fall
VeX is offline   Reply With Quote
Old January 11th, 2009, 10:28 AM   #6
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
I had put a second washer on mine when the temperature was in the 50s, and when I rode at 36* it was still running great... we'll see how it does when it's warmer in the spring, but so far it seems to be just about perfect for me.
Old January 11th, 2009, 01:08 PM   #7
headshrink
headshrink's Avatar
Does temp matter much for FI bikes?
I assume the computer makes all the adjustments.
Old January 11th, 2009, 01:23 PM   #8
Are you talking about our bikes? You know ours aren't FI.
FI bikes have temp sensors which relay that info back to the ECU.
Old January 11th, 2009, 05:58 PM   #9
headshrink
headshrink's Avatar
No, I know we don't have FI..... I was just thinking about a 650r at some point and like the idea of not needing to tweak it all the time. Of course there are those power-commander thingies for FI bikes, but that is totally different.
Old January 11th, 2009, 08:46 PM   #10
Erin_S
Motorcycle(s): Gix
Yes, FI will automatically adjust.
Not adjust as well as you can, though. Increasing the fuel map is a lot easier/faster than a jet though... not that you really need to do it anyway.
Erin_S is offline   Reply With Quote
This is the best time of year to ride red5 Off-Topic 3 September 27th, 2013 10:31 AM
It is that time of the year again Sailariel General Motorcycling Discussion 8 September 24th, 2012 02:40 PM
The sands of time, a new year coming mrlmd Off-Topic 4 December 28th, 2011 10:19 PM
That time of year. tapdiggy General Motorcycling Discussion 13 December 17th, 2010 12:03 AM
Rejetting for a Slipon Dano 2008 - 2012 Ninja 250R Tech Talk 7 April 11th, 2010 05:38 PM
