View Poll Results: What's your average MPG? | |||
less than 20 mpg | 4 | 0.65% | |
21 mpg - 30 mpg | 10 | 1.64% | |
31 mpg - 40 mpg | 32 | 5.24% | |
41 mpg - 50 mpg | 186 | 30.44% | |
51 mpg - 60 mpg | 262 | 42.88% | |
61 mpg - 70 mpg | 98 | 16.04% | |
71 mpg - 80 mpg | 11 | 1.80% | |
81 mpg - 90 mpg | 1 | 0.16% | |
more than 90 mpg | 7 | 1.15% | |
Voters: 611. You may not vote on this poll |
Thread Tools |
August 10th, 2010, 04:50 PM | #201 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
i'm getting about 48mpg (4.9l/100km), but since the break in I've been riding it like i stole it
edit: on a side note, anyone with an iPhone/ipod touch looking for an easy way to track mileage, get AccuFuel. That's what I'm using, and it works great. takes about 30 seconds to input the mileage, amount and price of fuel when you're done filling. |
August 18th, 2010, 11:03 PM | #202 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
definitely not a strong suite for my bike, last calculation i did (dont remember sactly how many km, lol) was around 220~240 KM when i filled up the tank with 16.4L of fuel, thats like 13.4 to 14.6 KM/L = 32 to 35 MPG....
how do ppl get over 60miles to the gallon! O.o must be them darn long straight roads with the 70mph speed limits over there in the civilized worlds!
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
August 19th, 2010, 02:17 PM | #203 |
Join Date: Aug 2010 Motorcycle(s): 1981 Honda Cx500 Custom, 2002 Ninja 250 Posts: 289
I think height and weight should be listed with fuel mileage results as well. I had an 07 that still got around 60 during its break in time.
Just sold an 09 Versys 650. I averaged 50 mpg with it. I have just purchased a 02 Ninja 250. Have yet to ride as I am having 15t front sprocket, new tires and carbs cleaned out 1st. My height is 6ft 4 Weight 245. I feel size/weight should be considered. |
August 19th, 2010, 05:13 PM | #204 | |
wonder if i'm running way too rich ...
August 19th, 2010, 05:23 PM | #205 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
52-53mpg, i always get 210-220 miles to a tank. 15t sprocket swap, stock can, shimmed needles, snorkel pulled. 99% of my riding is highway commute at 75mph - when accerlerating onto the highway i shift at 10k. 5' 10" 182 lbs.
August 20th, 2010, 04:19 PM | #206 |
Just filled up yesterday with 150.x on the odo and put in 3.5gal for 42.8mpg. No change from before I got the yoshi full installed. This was 90% in-town/commuting with not much slab time.
August 24th, 2010, 11:32 PM | #207 |
The Sportisi Master
My mileage sucks. Not fun when it costs $100 a tank.
Sportisimoto USA is born. |
August 25th, 2010, 03:56 PM | #208 |
motorcycle rider
I find that my 2008 250r consistently gets about 45 MPG in the city. Frankly it is a bit disappointing. I used to have a Honda XR200 (air-cooled 200cc single) that got over 90 MPG. Mind you, it didn't have anywhere near the same top speed or acceleration as my Ninja... :-|
August 25th, 2010, 06:23 PM | #209 |
Did you install an aftermarket Chevy Suburban gas tank on yours?!
"Rudeness is a weak persons attempt at strength." |
August 25th, 2010, 09:40 PM | #210 |
The Sportisi Master
nope
August 27th, 2010, 07:50 PM | #211 |
hes using jet fuel, NOS and a pinch of gold powder just for good measure and its BlingBling factor... or... Matt put a 35 gallon fuel-tank on his 2fiddy for a non stop cross country ride :P
rofl...
August 28th, 2010, 10:09 PM | #212 |
Well I see too late that this post was for 2008 plus bikes...
My bike is an 02, but will post anyway. Just got back from 700 mile round trip. My fuel mileage for first tank was 56mpg, second tank I tried hi test 54mpg. The third tank I was running interstate wide open in 6th gear and got 44mpg-yuck. The last tank when I got home and filled up was 48mpg. I probably averaged around 65 mph when not traveling interstate. My rpms averaged between 7 and 9k. Again, this is with fresh tune up, new tires, new 15tooth sprocket. My weight 245lbs height 6ft 4. I was hoping for 75mpg....didn't happen. Not sure what to do to make it get that. Bike is stock except for the above. My 09 Versys 650 gets this mileage almost exactly with tons more power. I am still happy with my little ninja though.
August 30th, 2010, 07:42 PM | #213 |
Not dead yet!
Join Date: Apr 2010 Motorcycle(s): 2009 Ninja 250R Posts: 315
I'd say I get about 55. When I do longer rides, I'm definitely up around 60, but my 8ish mile each way commute eats into that a lot. For comparison, my Dodge Magnum doesn't even come close to being fully warmed up by the time I get to/from work, and thus I average about 14mpg on that commute.
September 14th, 2010, 01:20 PM | #214 |
Join Date: Apr 2010 Motorcycle(s): 09 Ninja 250 SE Lime Green/Diablo Black Posts: 126
Man, I'm 200 lbs without gear or my backpack, so maybe 250lbs with it. I'm barely hitting 40 MPG. My bike is bone stock.
I need to sync the carbs and swap the air filter. Would that be a culprit? |
September 14th, 2010, 01:37 PM | #215 |
what kind of riding is the majority of bike use comprised of?
September 14th, 2010, 01:45 PM | #216 |
Mostly highway commuting lately. So anywhere from 100-140 km/h, but mostly averaging 120 km/h.
September 14th, 2010, 01:51 PM | #217 |
hmmm... I would think you would get great gas mileage with the bike in 6th and having the throttle at a constant, cruising speed.... you are in 6th, correct?
are you sure your choke is adjusted properly so when it is in the "off" position there is free play down by the carb slider bar thingy <highly technical term ? |
September 14th, 2010, 01:54 PM | #218 |
I'm in 6th unless I have to gear down to pass a semi.
I have not checked the choke free play. This could be a culprit, as I do find that when I use the choke and start it, the bike does rev to 4k rpm quite readily, and idles at 1500 with the choke off. Will look at it tonight. |
September 14th, 2010, 01:57 PM | #219 | |
also, when you push the bike around in the garage, does it feel like the brakes might be dragging? chain lubed and adjusted properly? |
September 14th, 2010, 02:02 PM | #220 | |
Things that make you go hmm.... |
September 14th, 2010, 02:07 PM | #221 |
Averaging 75 or more mph isn't going to get fantastic mileage. There's of course nothing wrong with checking to see if there is a culprit on the bike that is hurting mileage, but before you spend a lot of time and effort, try one more thing. Go at least 50 miles (*quickly does conversion*) 80 kilometers at a constant speed closer to 100 km/h. Start with a full tank, and calculate your mileage right after when you fill up. If the mileage gets closer to 50+ or even approaches 60 mpg, there's nothing wrong with your bike. At high speeds on the highway, the mileage just isn't going to be that great.
September 14th, 2010, 02:11 PM | #222 |
I assume you're doing accurate calculation of your mpg and not by the "I'm gettin' X miles per tank before fillup" method.
mileage since last oil change? I know I'm gonna start a holy war over this next comment, but you might try switching to a synthetic oil, if you haven't already. Not saying it will miraculously give you 60mpg, but every little bit helps. next time you have the opportunity, remove the spark plugs and see how they look. |
September 14th, 2010, 02:15 PM | #223 |
September 14th, 2010, 02:15 PM | #224 | |
I just recently switched to synthetic Rotella T6, it didn't seem to help a whole lot. I have new plugs that I am planning to put in, but I did take a look at my old ones when I did my valves, and they had a little bit of blackness on the element, which as I understand, means I'm running rich. Sometimes, when I turn on the bike, or I'm at a stoplight, I do get a strong gasoline smell. I will try Alex's method of measuring MPG this weekend when I have a bit more time. |
September 14th, 2010, 02:17 PM | #225 |
September 15th, 2010, 12:07 AM | #226 | |||
Join Date: Jun 2009 Motorcycle(s): Ninja 250R Fuel Injected Model 2009 Posts: 357
I'm getting worst case 60mpg and best case up to 70mpg. Although I think UK Gallons and US Gallons are not the same? Which one are you measuring too?
My vlogs on Youtube are here |
September 15th, 2010, 05:33 AM | #227 | |
So you're seeing 50 mpg to 58 mpg in US gallons.
September 15th, 2010, 05:51 AM | #228 |
Join Date: Jan 2009 Motorcycle(s): 2008 Ninja 250 1998 HD Road King Posts: A lot.
I've tracked my mileage from the day I got the bike and I'm getting 56mpg(average for two years). My highest tank was 62mpg and lowest was around 50.
September 17th, 2010, 07:04 PM | #230 |
Caferacer
Join Date: Mar 2009 Motorcycle(s): 2008 Ninja 250r Posts: 39
I get 50-52 mpg...I have a full yoshi pipe (without the quiet core), K & N filter,
dynojet kit, kleen air removed. I rev to redline most of the time up until about 60-65 mph unless getting on the interstate. I guess 50 is not bad but my last bike was a 955i triumph daytona and it got 42-44....go figure... |
October 7th, 2010, 10:44 AM | #231 |
I ran out of gas a couple days ago with 186mi on the tank. Still have the yoshi, still jetted up. I'm 6'1 @ 160lbs. I think I'm running rich and/or leaking somewhere. My buddy brought me a gas can with maybe a cup or two in it and when I filled up the filler read 4.7g. I've had a heavy hand lately but there's no way I could go from mid 40s to under 40 without some kind of problem...
November 21st, 2010, 10:40 AM | #232 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
I'm 170lbs, on my 2008 (Pipe and jetted). I commute 2-4 days a week and do some weekend twisties/light touring depending on the mood and riding group. On the highway I stay right around 65mph and I'm 30% highway/70% city. Per tank I average 60-65mpg on the stock gearing. Chain is always lubed and tire pressure checked/corrected. I just purchased 15/42 so I will try that gearing and see how it rides and if the mpg's change.
November 25th, 2010, 08:35 AM | #233 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
I'm in the mid 40's now. When it was stock I was getting 55-60's mpg. Now with intake mod, jetting, and exhaust I am in the 40's. Im still pleased with it. Also, its colder where I am at now so that could play with what i'm getting. Maybe when it gets warmer it will go up to the low 50'.?.
November 25th, 2010, 09:55 AM | #234 |
I've got 44-45 on every fillup since the first two, heh. Though almost all of my riding is either short commutes or long, quite spirited rides .
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
November 26th, 2010, 07:20 PM | #235 |
Got 39MPG last time and I wasn't too bard on it either. Remember, I'm at 15:41 too.
November 26th, 2010, 09:51 PM | #236 |
My mileage stayed exactly the same when I went from stock to 16/41, even. Also, even after I changed the jets and added the pod filter, it didn't change. I've been toying with tuning a bit more since I recently finished my exhaust system, and my fillup today was like 45.5mpg.
December 28th, 2010, 12:13 AM | #237 |
Join Date: Feb 2010 Motorcycle(s): 2009 CT Blue 250R(Sold), 2008 Black & Silver Honda CBR600RR(Current) Posts: 201
When i first got my ninja250 i was getting a constant 54-55mpg
after installing a yoshi full carbon slip-on with silencer insert my mileage went up to 58-59mpg Besides the slipon bike is all stock engine wise... with full gear on i weigh about 150-155lbs My riding style is all high rev shifting around 8-9k consistently, what can i say didnt geta bike to go slow use my car for that lol. I'd say i ride about 50/50 between highway and city. IMHO i love my ninja 250 i dont plan on selling it ever, even after i upgrade to a 600 |
December 28th, 2010, 12:43 AM | #238 |
Join Date: Dec 2010 Motorcycle(s): 2005 Ninja 250ex Posts: 38
After reading some of these posts I am loving my bany more and more. About 60% of my riding is in town mostly flat land. Although it may take you 20 minutes to go 10-12 miles due to lights and amount of traffic. My driving sttle driving style depends on amount of traffic but usually in a hurry, lol. The baby weighs 347lbs and I add about 130-135 in full gear so the 2 of us do not make 500lbs. I get about 70 mpg. If I do a trip to Key West (180 miles) I get about 75mpg but that's running down #1 and thru all the Keys. My bike is '05 and all stock.
Posted via Mobile Device |
December 28th, 2010, 09:08 PM | #239 |
seeking twisties
Join Date: Nov 2010 Motorcycle(s): '07 Ninja 650R, '09 250R special edition Posts: 199
I have been getting in the upper 40's. Most of my riding is freeway and highway-65-75mph. I have the Roaring Toyz hanlebar risers, so that makes my big fat body sit upright and catch more wind. I'm going to plan a trip with mostly 50-55mph riding and see how much the mileage increases. Also I ordered the 15 tooth sprocket-hope that can get me into 50mpg.
Bill |
December 31st, 2010, 12:40 PM | #240 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
Since I am now sharing mine with my son:
2009 250R Two Brothers Slip-On, DynoJet jetting kit, 3rd Ring from Bottom, 112.5 Jets and Uni individual Pods, drilled slides, stock sprockets 140 Sport Demon Rear tire. Me: 5'7" 220lbs in gear if I haven't eaten 50mpg 65-80mph Freeway 55+/-2mpg City, mostly 5th gear riding. Son: 5'2" 135lbs in gear sopping wet with fishing weights in his pockets so far mostly City with very brief stints on the freeway to not get a good idea...68mpg Ordered Vortex Sprockets F: #3202 15T R: #435 42T Will be interesting to see what effect it has.
2009 KLE650 LSL bars, Full Muzzy PC-V 1995 900SS/CR mildly modified |
This is some crappy gas mileage | 250rr | Off-Topic | 1 | September 4th, 2013 05:08 PM |
Low Gas Mileage, why? | Dhillon92 | 2008 - 2012 Ninja 250R Tech Talk | 32 | July 27th, 2013 04:51 PM |
what's your worst gas mileage? | boyonfire | 1986 - 2007 Ninja 250R Tech Talk | 24 | October 25th, 2012 06:46 AM |
Gas Mileage: New vs Old Gen | SmithSwede | General Motorcycling Discussion | 9 | June 12th, 2012 01:07 PM |
gas mileage | motorcycle_munge | General Motorcycling Discussion | 23 | May 16th, 2009 01:54 PM |
