Old July 11th, 2011, 06:53 PM   #1
kevinlo423
kevinlo423's Avatar
Choke acting weird?
When the bike idles weak, I give it some choke to avoid the bike dying. After it runs smoothly, I jump on the bike with the choke still on, put the kickstand up and straighten the handle bars. However, the second I turn my handle bars, the choke disengages and won't engage again.
Is this normal? It's been like this for a couple of days
kevinlo423 is offline   Reply With Quote
Old July 11th, 2011, 07:16 PM   #2
have you worked on the carbs prior? sounds like the choke cable is improperly routed.
Old July 11th, 2011, 09:12 PM   #3
kevinlo423
kevinlo423's Avatar
Yes. I've forgot to mention that this started after I shimmed the needles.
I should take apart the fairings and check? how do I know if its improperly routed?
Old July 11th, 2011, 09:20 PM   #4
pg. 17-6 and 17-8 of the service manual. do you have one?
Old July 11th, 2011, 11:14 PM   #5
kevinlo423
kevinlo423's Avatar
yup. I'll take a look at it this weekend and hopefully will be able to eliminate the problem! thanks kelly
Engine Acting Weird - Randomly Cutting to Low Performance Maddawg 2008 - 2012 Ninja 250R Tech Talk 8 May 8th, 2014 06:05 PM
Fuel gauge acting really weird Adaptive 2008 - 2012 Ninja 250R Tech Talk 1 September 14th, 2013 03:45 AM
Shifting mechanism acting weird after highway incident. milk_bear 2008 - 2012 Ninja 250R Tech Talk 3 October 12th, 2012 03:45 PM
bike acting weird! fenwaynomar45 2008 - 2012 Ninja 250R Tech Talk 3 June 8th, 2010 12:03 AM
[usridernews.com] - Acting Chairman of the CPSC Grants Enforcement Delay Ninjette Newsbot Motorcycling News 0 April 3rd, 2009 06:20 PM
