Old May 6th, 2012, 12:51 PM   #161
n4mwd
n4mwd's Avatar
Originally Posted by Jiggles View Post
@CZroe thanks for the ridiculously long story lol, but Matt said he would not return the throttle body because it had been modified. Matt also offered to buy the kit back from n4 for 75% of what it originally sold for despite all the modifications.
Your facts are a little twisted. Back in the end of February, Matt offered to take the kit back at 75 cents on the dollar (excluding shipping). He was OK with the fact that it was modified. He said: "I know TB is heavily modified. But we can replace it with another one." He has never asked me to return it to be replaced with a new TB.
Matt did say that he would be shipping me the new fuel tap and regulator. He said Feb 23: "I will send you these 2 parts, without charge when I have it. So that you can still sell the kit." But I haven't received those either and don't expect to.
Jiggles, Did you get your new TB yet? Did Matt ask you to return your old one?
My Ninja Blog
Old May 6th, 2012, 12:59 PM   #162
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I guess my facts are twisted, oh wait, that's exactly what I said
And actually Matt sent me a brand new customized ninjette outfitted with the new throttle bodies and a new ECU that takes advantage of his new Wideband O2 sensors, as thanks for setting up the group buy.
No I haven't received anything, but I also haven't asked as I'm currently incapable of doing any modifications.
AFM #676
Supersports are for n00bs
Last futzed with by Jiggles; May 6th, 2012 at 02:18 PM.
Old May 6th, 2012, 01:00 PM   #163
For the record, what is said in PM's, stays in PM's. I'm not implicating anything here on anyone involved, but it is in the terms of service to keep private messages between the sender and recipient.
2.2
...PM's are not to be posted publicly, nor will they be moderated.
Old May 6th, 2012, 01:48 PM   #164
setasai
setasai's Avatar
What part of the last few posts are about the installation?
@EMSRace07 I think I am going to be lazy and leave the fuel rail pointing forwards. Can you let me know if pointing it downwards works out for you in say 1k miles? I doubt either method will cause any problems. That space is cramped regardless on how we route it. You are running K&N pod filters right? I think we have the exact same setup except I'm on a newgen. Stock exhaust or were you the one with the muzzy? I forget.
Btw, think you can send me some of your logs so I can compare with mine? Mainly idle from cold start and some blipping?
2009 Ninja 250R SE Green Sport Touring Style:
ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket
Old May 6th, 2012, 02:00 PM   #165
EMSRacer07
EMSRacer07's Avatar
Motorcycle(s): Ninja ex250 1990
Yeah sounds good lol. And yep will let you know. doesn't look like any problems with come about though. I was just worried when Matt said that it keeps the fuel lines away from the head and block, dont want more heat added to the lines, especally the rubber lines. That is why i moved mine.
and yeah I am running the K&N filters and muzzy full exhaust.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust
EMSRacer07 is offline   Reply With Quote
Old May 6th, 2012, 02:20 PM   #166
setasai
setasai's Avatar
Yea, I get that. I was worried too and then I just looked at the rest of it and thought, meh the way my fuel lines run now is exactly how the carbs used to run, between the carb body and the engine heads. Curved and downwards. Figured if i had issues, I could always change it later. Shouldnt affect performance really. Time to stop talking and go for a ride! We fix this flat spot and we'll be golden. Last issue.
Old May 6th, 2012, 02:30 PM   #167
EMSRacer07
EMSRacer07's Avatar
Yea def last issue. Everything else seems fine. Will probably do another MPG checking for the new software.
Old May 6th, 2012, 03:32 PM   #168
n4mwd
n4mwd's Avatar
It sounded like you were saying that Matt asked me to return my TB for replacement and that I refused because I had spent too much time modifying it - that wouldn't have been true.
For the record, Matt has not sent me any PM's through this board.
My Ninja Blog
Old May 7th, 2012, 07:51 PM   #169
setasai
setasai's Avatar
Just an update to those of you tweaking your installation. If you connect it to procal while the bike is running, check the ignition angle. CrA should be around -7.0 to -10.0 when engine is idling after being warmed up. When cold start, CrA should be closer to +7.0. Priority goes to warm engine settings.
To adjust the idle air, there are two screws (now on the bottom similar to idle mixture screws except it points out towards you on the left side of the bike). Be sure to mark the screw so you know where is one full turn. They are balanced from ecotrons and I'm not sure how to rebalance them if you mess it up. Adjust them exactly the same amount for both each time you adjust.
To make the CrA go more negative, turn the screw OUT, counterclockwise. This gives idle MORE air. Vice versa to go the other way.
Do a few blips with the throttle to see how it responds and you can also take it for a ride and record the logs during a ride to see how it changes. It's quite fascinating and gives you an idea how all the sensors come together.
If I'm incorrect about anything I'm sure Matt will chime to correct me.
Old May 10th, 2012, 10:08 AM   #170
@Terminal the extra part needed for the pre-gen is just the fuel-tap gasket from the new-gen correct?
Old May 10th, 2012, 10:12 AM   #171
Terminal
Motorcycle(s): '02 EX-250, '03 EX-500
That looks to be the one, just beware of the "A" variant of that part number that is actually for the petcock handle itself. Ordering mine as soon as BikeBandit price matches some other maintenance bits.
Terminal is offline   Reply With Quote
Old May 10th, 2012, 10:13 AM   #172
Thanks for the tip on that. Only thing I dislike about ordering online is the darn shipping prices...
Old May 10th, 2012, 10:23 AM   #173
Terminal
It's just an excuse to also order a new battery, and maybe some brake rebuild kits, and oooh that's shiny....
Old May 10th, 2012, 10:37 AM   #174
I highly recommend stainless steel brake lines and DOT5.1 fluid while you're at it.
Old May 10th, 2012, 09:49 PM   #175
flynjay
flynjay's Avatar
Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R
@ecotrons - I've got to say, I'm impressed with the modifications to the throttle body. Just got everything installed and Firmware updated. Too bad I won't get to ride it for a couple of days do to heavy rains.
I'd say you are probably as close to a plug and play kit that you can get.
flynjay is offline   Reply With Quote
Old May 10th, 2012, 10:18 PM   #176
@flynjay did you go with a pod filter to replace the airbox when you installed the kit?
Old May 11th, 2012, 05:32 AM   #177
flynjay
flynjay's Avatar
Yes, and it made installation that much easier. I could actually attach the pods to the throttle body and tighten everything down then install it all as one piece.
Longest part for me was actually installing the fuel pump mounting bracket mainly because the fastener alignment was a little off and they wouldn't thread. Fuel pump ended up on a bracket right over the rear shock.
Old May 11th, 2012, 06:08 AM   #178
Picture of your setup? EMSRacer07 showed me his pump bracket. I'm taking polls.
Old May 11th, 2012, 09:15 AM   #179
setasai
setasai's Avatar
On the newgen I did the same thing. The bracket mount right next to the rear shock where the original airbox mounted. It was the only place I could mount it without it being in the way of everything else. I think the tubing actually worked out quite nicely this way. I too have the K&N pod filters as well.
Old May 11th, 2012, 09:20 AM   #180
flynjay
flynjay's Avatar
On the pregen, there are two bolts that hold the rear wheel well plastics in place. I noticed that I had enough thread engagement to get a piece of aluminum in there. So I made a simple bracket using aluminum angle. Fuel line routing is much better, although I would like to get a different filter to make it even better. The new fuel rail also makes it a much cleaner install.
Without the stock airbox I have about a 1ft cube of open space in front of the battery. I am tempted to make a storage bin for that area.
I will try to get a pic tonight.
Old May 12th, 2012, 01:19 PM   #181
I was thinking the same thing. That seems like it might be what I go with once I get a better look at the mounting bracket supplied in the kit. That's out of the way of engine heat like the kit suggests, and is not requiring zipties.
Old May 13th, 2012, 08:31 AM   #182
flynjay
flynjay's Avatar
Here is my fuel pump mounting. Looking down from the top, battery is in the top of the frame. I had to bend the angle bracket a little to get access to the head of the bolt.
Old May 13th, 2012, 12:59 PM   #183
Alright, I just ordered everything I need to install this kit, I'll be attempting the install starting at the end of the week
Old May 13th, 2012, 01:39 PM   #184
DJK
Motorcycle(s): 2011 250R
same here, I begin on wednesday, will take some pictures of where I mount my pump
DJK is offline   Reply With Quote
Old May 15th, 2012, 10:37 AM   #185
I think I can mount it to the batter box either by itself or with an L bracket. Should be out of the way and out of the heat.
Old May 16th, 2012, 09:49 AM   #186
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
Just an update, with the new hardware and software from Ecotrons, I've got my kit running extremely well. I still don't have the O2 sensors installed just to clarify, so I'm running off of the "rich" setting all the time and still creating maps for the "desired lambda" table.
Idle: The idle on the kit with my current calibrations is good, it oscillates a little while in the mid to late warm up phase, but after that the idle is strong and steady. From 3,000 rpm down it drops a little slow, but that's nothing to worry about. The torque even at idle is enough to easily propel me up the driveway at a respectable slope with all my gear on weighing in at approximately 250 pounds. This was a significant change when compared to the carburetors.
Start up: Starting up is very easy, normally the engine will fire on the first turn over. I've had some recent issues with the ignition not working while in first gear but I'm sure that's a loose wire somewhere probably on my fault during assembly/disassembly.
Warm up: During the early warm up phase (first minute or two of riding) the throttle isn't quite as responsive as when fully warmed up, but predictability is mostly the key during this time as you don't want to be rocketing off at 13k rpm on a cold engine anyway. Mid warm up (3-5 minutes) the throttle becomes more responsive, blipping becomes easier and the slight idle drops decrease. During the later portions of the warm up (from 5 minutes up to normal running temperature) the idle may oscillate a little bit until full temperature is achieved, throttle response and predictability are both excellent.
Mid Ride: Zero issues, amazing kit. The smoothness of the power curve on that kind of level was really unexpected. Smooth roll-ons and roll-offs allow you to see that there are absolutely no dips or spikes in the power curve, it's all smooth as silk. On top of that, a little extra power may have been gained through the kit (not sure if it's from changing settings or what, but there definitely was a stronger acceleration pull compared to the older hardware and software).
Overall impression: The improvements to the kit are spectacular, ease of installation and the more professional appearance (less hosing, fitting boots etc) definitely add to the kit's success. The performance gains when compared to carburetors are quite immense. One very satisfied customer, especially with the support from Matt at Ecotrons for the time and effort put in through a multitude of emails to get this kit to it's maximum potential. Those willing to take the time to get a basic understanding of the kit and programming will only get that much more satisfaction out of the product knowing that they essentially can control quite literally everything about the engine. Spark advance, air-to-fuel mapping, and volumetric efficiency just to name a few.
ATGATT
Scattcatt is offline   Reply With Quote
Old May 17th, 2012, 08:43 AM   #187
@Scattcatt what AFR are you tuned at for various rpm's? That's kinda what I've been wondering. I think most dyno charts that I've been looking at have been tuning to the 13.5 ish range, some even as low as 13. I've heard that if you go above 14, you lose some of the valve cooling effect that rich mixtures have.
Anyhow, just curious as to where your bike is tuned to run at so I can have an idea of where to set up my rich mode desired lambda/whatever once I get my kit installed with O2 sensors.
Old May 17th, 2012, 10:45 AM   #188
Scattcatt
Scattcatt's Avatar
Currently the calibration I'm using would ideally tune for 13.0 AFR, but I'm not entirely sure how accurate the AFR is based off of the various sensors and no wideband sensor to get a reading from. Anything in the 13.0 to 13.4 range works well for me though when I'm in a sporty mood
ATGATT
Old May 18th, 2012, 06:37 PM   #189
EMSRacer07
EMSRacer07's Avatar
Update for me:
New software fixed all the bugs so everything is good like the old tbs but almost more performance and so far more mpg. Still testing the gas mileage but i saw an increase of 3mpg over the old throttle bodies and alot more performance. I am seeing 70mpg from going up 1300ft of elevation and about 75mpg or more on a flat plain. And elevation changes are all adjusted so no affects when you travel out of town. It self tunes for every case.
Performance i have seen it pull pretty nice all the way to red line to 14.5k. NO dips in power, its all linear and alot more tq. I have pods, and full exhaust and the tunning adjust to the parameters of probably any combination within reason.
All in all im extremely happy with the kit. Love how the new kit is so much more simple to install. Easy diagnostics. Starts right up, no more chock, more performance. Well worth it, even on my old 1990 bike. I put new gen bikes to shame :P.
Old May 25th, 2012, 12:59 PM   #190
iNinja
iNinja's Avatar
Motorcycle(s): 2009 Ninja 250R EFI
i'm actually having the opposite problem of this.
it seems while my bike is warming up, the idle is steady, but once it's warmed up, it will oscillate from about 1300-1400rpms at set idle up to about 2000rpms and then back down. it will do this continually at idle. i don't know if i'm having an air leak issue or a tuning issue. when i snap the throttle it is a little late in response time almost like it wants to stall but doesn't. i keep thinking i missed something really stupid that's causing the air leak but i can't find it. throttle body is sealed and tight to both engine and air box (i'm using v2.0 throttle body with fuel rail). is there an air line that was originally to the carb setup that i missed that is or isn't supposed to be closed ? when it oscillates my spark drops to almost -13.0 CrA at it's lowest. i'm still using the stock airbox. only mod to it is a removed snorkle. i also have a hmf slip-on.
there's one line i have a question about that i don't know should be open or closed. here's a pic.
http://farm8.staticflickr.com/7188/7...1bc794bc_b.jpg
i've been through a couple different s19, cal, and a2l files and nothing seems to fix it. i use procal v6.9.6. any help would be appreciated or feel free to donate your files.
iNinja is offline   Reply With Quote
Old May 25th, 2012, 06:19 PM   #191
lgk
does that tie into the emissions system?
Old May 26th, 2012, 08:39 PM   #192
iNinja
iNinja's Avatar
i went for about an hour and a half test ride yesterday and the bike kinda 'tuned' itself. it's running a lot better and didn't have a single problem during my ride. torque and acceleration definitely improved. starts right up. i'm using the v2.0 throttle body with fuel rail and newly updated ECU with no bugs and the bike runs awesome. the only thing i changed in this kit was replacing the transparent fuel line for high pressure line, actual fuel injection hose clamps, and also got a smaller visu-filter fuel filter. i'm currently using on/off valves at my direct fuel and return lines until i can get some quick disconnects.
i'm very happy with this kit. i purchased this kit before the new v2.0 throttle body but didn't get to ride it with the old throttle body before the new one came out about 2 weeks later, so matt sent me the new version. i DID go through one MAP sensor from fuel contamination with the injectors on the bottom. the new design of the v2.0 throttle body is a great improvement. i was able to reach my throttle cable to left side and no problem at all with MAP contamination since the injectors are mounted on top this time. aside from getting some bungs welded to your exhaust for the O2 sensors and any little minor improvements you may want to do, this kit really is plug and play and not hard to install at all. i think the only trouble i had during the install was finding room for everything like routing fuel lines since there isn't a whole lot of room to work with (08+ anyway), but it can be done. i mounted my fuel pump below the new petcock to avoid fuel starvation and the smaller fuel filter saved room as well. for reassurance, get yourself some fuel injection hose clamps and high pressure fuel line and you're good to go, and don't forget to get either on/off valves or quick disconnects (quick disconnects recommended so it seals on both sides) for your tank fuel lines for easy tank removal. very inexpensive upgrades.
matt was also extremely helpful with anything i needed. i'm also the first female to do this install.
Old May 27th, 2012, 04:24 AM   #193
setasai
setasai's Avatar
@iNinja Yay! I'm glad it's working out for you. I'm loving it as well. Are you still having the idle fluctuation issue? It does it on mine once in a while but it doesnt quite bother me. It's usually pretty stable.
Old May 27th, 2012, 07:14 AM   #194
ecotrons
CONGRATULATIONS! @iNinja
The first female that's done the conversion. A college girl !
Now you guys start to make me proud!
Thanks for the suggestions on hose clamps and quick disconnects.
ecotrons is offline   Reply With Quote
Old May 27th, 2012, 07:42 AM   #195
iNinja
iNinja's Avatar
after my test ride it has much improved. it's not so noticeable anymore and happens a lot less frequently. before it was about 1300-1400 to about 2000 which was definitely noticeable at idle. after another ride yesterday it's only 1400 at set idle to about 1550 tops now. hardly a problem. the bike is running awesome and i'm very glad i did the conversion.
haha, thank you matt and thanks again for all your help during the install!
Old May 27th, 2012, 04:02 PM   #196
justinswidebody
justinswidebody's Avatar
Motorcycle(s): 250 ninja
Can someone tell me on the new fuel rail, are both sides feeds for the injectors, or is one side a return.
justinswidebody is offline   Reply With Quote
Old May 27th, 2012, 05:05 PM   #197
ecotrons
one side feeds, the other side returns. No difference on which side.
Sorry, supposed to broadcast the new TB installation instructions.
I will do it in the email then.
Old May 27th, 2012, 05:08 PM   #198
justinswidebody
Cool thanks Matt.
Old May 29th, 2012, 06:20 AM   #199
forbitel
Congrats!
Congrats @iNinja!,
I'm glad that you worked out the initial issues and got it working just fine. Great Job
I hope you enjoy your FI bike as much as I did.
forbitel is offline   Reply With Quote
Old May 29th, 2012, 06:40 AM   #200
iNinja
iNinja's Avatar
Originally Posted by forbitel View Post
Congrats @iNinja!,
thank you!
i'm definitely loving the conversion!
ecotrons tech questions. bigbadbob 1986 - 2007 Ninja 250R Tech Talk 1 April 17th, 2015 10:50 AM
Ecotrons map swarfman64 2008 - 2012 Ninja 250R Tech Talk 2 January 15th, 2015 06:09 AM
WTB:Ecotrons petcock crimsondragon Items Wanted 2 September 21st, 2014 06:54 AM
Ecotrons kit garth285 Items Wanted 0 June 17th, 2014 05:09 PM
Ecotrons Gen2 FI Kit Install Terminal 1986 - 2007 Ninja 250R Tech Talk 85 October 15th, 2012 02:02 PM
