Old November 2nd, 2011, 12:56 PM   #1
OddlyOrdinary
Motorcycle(s): 2009 SE Ninja 250
The awesomeness that is Seafoam
So I've had a realization that the previous owner didn't treat the bike as well as I thought he did and have been doing a fair bit of maintenance on it. Yesterday I added 4-5oz of Seafoam to a full tank and have ridden maybe 40 miles.
Wow. Just Wow.
My bike is soo much smoother and sounds much better. I don't think there is too much time left this year that I'll ride for pleasure but I expect to do a real job of cleaning up my bike for next spring when I pull it out of the garage. If you haven't cleaned your carbs recently or have doubts about the previous owner a can of Seafoam costs 6-10$ at a local store, cheaper online.
If you knew a bike had been sitting for a good while, what all would you do for a checklist to get the bike ready again. I currently don't have a garage to tear apart the bike, but plan on it next spring.
OddlyOrdinary is offline   Reply With Quote
Old November 2nd, 2011, 01:15 PM   #2
CodeProofMonk
Motorcycle(s): 2001 EX250
Originally Posted by OddlyOrdinary View Post
Wow. Just Wow.
Yup, that stuff's great! I add some to every tank of gas. It stabilizes your gasoline as well, so if you park the bike for a while the gas won't go bad.
- Change all fluids
- Check brake function and pads
- Check/replace tires
- Clean & lube chain, or replace if it's in really bad shape
- Check fork seals
- Clean & sync the carbs
(An overnight soak in Pine Sol will amaze you with the results)
CodeProofMonk is offline   Reply With Quote
Old November 2nd, 2011, 02:55 PM   #3
str8t six
never enough
str8t six's Avatar
Motorcycle(s): Blue 2010 ninja 250R
you soak the carbs in pine sol?
what does that do?
custom graphics, zero gravity DB
str8t six is offline   Reply With Quote
Old November 2nd, 2011, 03:05 PM   #4
str8t six
never enough
str8t six's Avatar
i was planning on taking the carbs out this winter when i rejet and cleaning them because my bike is breaking up when im just cruising at a slower speed. thanks for the tip!
anything else that would help?
Old November 2nd, 2011, 03:05 PM   #5
Jono
Jono's Avatar
That's the power of Pine Sol, baby!
Old November 2nd, 2011, 05:22 PM   #6
Lil_Green_Demon
Winging It In Life
Lil_Green_Demon's Avatar
Motorcycle(s): 2010 250R; 2011 250R (sold)
Seafoam is definitely awesome. I bought a bottle to use in my car. As for my bike, I don't think I've put enough miles on it yet to use Seafoam.
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015)
2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current)
Lil_Green_Demon is offline   Reply With Quote
Old November 2nd, 2011, 06:15 PM   #7
Purspeed
Purspeed's Avatar
Seafoam is incredible stuff. HOWEVER, be very careful when pouring it directly in your engine. It can cause serious damage in the engine if not used only as a flush.
When adding it to your gas, it's like a miraculous cure.
Most of the rough idle problems seem to stem from stale gas with ethanol.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008)
Purspeed is offline   Reply With Quote
Old November 2nd, 2011, 09:06 PM   #8
Jay72
Jay72's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250r
I see here in Canada at Canadian Tire there are a few different Seafoam products, which one do you use as a fuel stabilizer/treatment?
Here is the link.
http://www.canadiantire.ca/search/se...08474396672077
Jay72 is offline   Reply With Quote
Old November 2nd, 2011, 09:07 PM   #9
Purspeed
Purspeed's Avatar
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old November 2nd, 2011, 10:12 PM   #10
Jay72
Jay72's Avatar
Thank you sir, that is what I thought it was...no do you all suggest to use Seafoam instead of Stabil??? For winter storage?
Old November 2nd, 2011, 10:44 PM   #11
Purspeed
Purspeed's Avatar
I have in my Yamaha R6. It starts perfectly every single time and has been in storage for about a year. It's fuel injected.
However, carbs are a different animal and those needles clog up quick.
Some have suggested Seafoam for storage. Personally, I would drain the tank after running some Seafoam if you are up to the task (not difficult). That's the textbook way to store a bike.
You can also do a bit of searching on the forums and decide which one will work better for storage.
Old November 3rd, 2011, 05:39 AM   #12
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Gas tanks should be stored full to minimize the amount of condensation that can build up inside them and start the rusting process.
k-os is offline   Reply With Quote
Old November 3rd, 2011, 07:51 AM   #13
bob706
bob706's Avatar
http://www.seafoamsales.com/componen...2/view,folder/
I have used seafoam and it may "work" but I wouldn't store a bike with it in the tank. 10-20% ipa is a bit much
http://sandollarmotorcycleclub.com/
Old November 3rd, 2011, 08:34 AM   #14
Jay72
Jay72's Avatar
ahhh, I got ya, thanks for the tip, so I will just use Stabil. Or would a no name stabilizer work also? AS in the Canadian tire brand one?
Old November 3rd, 2011, 09:42 AM   #15
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Seafoam has placebo affect. Your bike thinks it's getting good fuel treatment and so is tricked into running better. In reality, you still need to remove and clean your carbs
Old November 3rd, 2011, 09:55 AM   #16
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
you have a riding season in texas?
blink-182
blink is offline   Reply With Quote
Old November 3rd, 2011, 11:20 AM   #17
Lil_Green_Demon
Winging It In Life
Some parts of Texas have wild, unpredictable weather. It can be hot and humid one day to suddenly being cold as hell & snowing the next.
Old November 3rd, 2011, 11:21 AM   #18
Boom King
So, where's the reverse?
Boom King's Avatar
Go with the brand name Sta-Bil Marine formula for the few extra dollars. Also found at your local Crappy Tire.
Old November 3rd, 2011, 06:05 PM   #19
OddlyOrdinary
Texas has plenty of frozen weather, especially around February. As I still drive my SUV for most outings especially if any alcohol is involved, the bike is purely for joy riding and errands. I don't fancy the idea of freezing weather + 50mph winds on the bike. It's just not the reason I own one.
Old November 3rd, 2011, 06:10 PM   #20
Jay72
Jay72's Avatar
Thanks and that is what I was thinking for the 3 extra bucks...
Old November 4th, 2011, 11:26 AM   #21
blink
Always.
blink's Avatar
Hmmm i never knew that.
I guess maybe the North East part more?
blink-182
Seafoam help please Jay72 2008 - 2012 Ninja 250R Tech Talk 15 August 3rd, 2012 09:37 PM
seafoam.. Stingray1000 1986 - 2007 Ninja 250R Tech Talk 16 June 18th, 2012 07:28 PM
SoCal Tech Day awesomeness!! GeneJunkie Pictures 55 June 11th, 2012 07:46 AM
How to use Seafoam? drdriftking007 1986 - 2007 Ninja 250R Tech Talk 22 April 17th, 2012 12:36 PM
seafoam? ReDnEcK 1986 - 2007 Ninja 250R Tech Talk 3 September 1st, 2010 09:00 AM
