#1 |
Join Date: Aug 2010 Motorcycle(s): 2009 Ninja 250r Posts: 61
15T sprocket and 150/60R17 (BT-016)
Hey,
I was just wondering if anyone running this setup has had any clearance issues with the tire and swingarm. I bought the 15 tooth sprocket anticipating that I would install it. But, I just purchased a set of BT-016 tires and I wonder if I am going to run into any issues of rubbing? I am assuming the 15 tooth sprocket will move the rear tire inwards, and I have heard there is only about a 1/4 clearance from the 150/60R17 tire to the swingarm. Any info would be really appreciated.. Thanks! ![]() |
#2 |
I'm running both and no issues with the the swingarm. I did have to cut a notch on the chainguard though since that was rubbing on the tire. I can take a pic when I get the chance.
#3 |
^^^No need to notch the chain guard, if you put washers between the guard and its mounting points!
#4 |
Thanks for the heads up, guys!! I really appreciate it.
I am doing everything at once and didnt want to run into any issues with the install. I cant wait for spring time!! |
#5 |
Did my chain maintenance today so took some pics for you.
![]() Chainguard with notch cut in (wish I knew about the washer idea beforehand ![]() ![]() Looks sooo dirty, but I'm going to blame it on the construction they're working on in the parking lot. ![]() Yes, my car should be metallic black, not dusty yellow... |
15t Sprocket Noise | ChickenRun | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 18th, 2013 12:58 PM |
Bridgestone Battlax BT-016 Rear Tire 150/60 ZR17 100$ | krolinked | Motorcycle-related | 0 | January 7th, 2013 06:39 PM |
Quicky about 15t sprocket | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 28th, 2012 03:10 AM |
15t Sprocket Brands | lonewolf05 | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 4th, 2011 09:39 PM |
went from 14t sprocket to 15t | speedgsx98 | 1986 - 2007 Ninja 250R Tech Talk | 4 | May 11th, 2009 04:18 PM |
