Old January 29th, 2017, 12:06 PM   #1
Speedy3
Motorcycle(s): 2008 Triumph Speed Triple (Blazing Orange); 2010 Nina 250r (Race Project)
Talking Cheating with Tight Valve Clearances
Attached is a picture of what I found to be my valve clearances. The top row is exhaust, while the bottom row is the inlet (attachment may be rotated, but the "IN" and "EX" give proper orientation). The inlet are within spec, but I may adjust them wider while I'm working on my exhaust shims. In the past, I read (and may have taken ) a shortcut too tight clearances. More specifically, with an older ducati, I simply wet sanded the tops of the shims to increase the gap clearance. I did this with the finest of sand paper, and on a piece of glass (for an even surface).
Has anybody heard or utilized this shortcut? Tempted to do this again, as my valves are all tight, rather that loose and in need of tighter shims!
Speedy3 is offline   Reply With Quote
Old January 29th, 2017, 12:11 PM   #2
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
From the hip without a lot of thought: anything you sand will tighten the valves, not loosen them!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old January 29th, 2017, 12:14 PM   #3
Flying
Motorcycle(s): 2010 Ninja 250
I've heard of this being done, but you need to be careful about sanding away the surface treatment of the shim. Valve shims are typically case hardened steel and you ought to make your next clearance check earlier, should you go forward with this.
Old January 29th, 2017, 12:23 PM   #4
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
Sorry! Brain fart! You specified tight clearance, not tight valves
Old January 29th, 2017, 12:53 PM   #5
Speedy3
You worried me there! I thought my logic was on point!
If you don't mind extrapolating, what would cause me to want to check clearances sooner? I'm trying to better understand the inner workings of my bike. Would compromising the finish simply lead to a rusty/broken valve?
Old January 29th, 2017, 01:31 PM   #6
Flying
A shim is just a round steel disc. Case hardening dissolves carbon into the outside of the shim to harden it. If you grind away too much of the case hardening, you expose the shim's softer insides to the forces of engine operation and it might split.
I haven't seen any real world data on this happening to people, nor do I know to what degree the shims are hardened, but its still something to watch out for. Make sure to keep the surface you have sanded against the bucket.
At the end of the day, the Ninja 250 uses a souped up lawnmower engine, and you'll probably end up fine. Just don't be racing or anything.
Old January 29th, 2017, 02:45 PM   #7
Can you obtain a surface that is perfectly flat and parallel to the other surface of the disc?
If not, you will create points of excessive presure and subsequent wear between shim and disc bucket and between bucket and valve's stem.
Please, see this:
https://en.m.wikipedia.org/wiki/Surface_grinding
Old January 30th, 2017, 08:24 PM   #8
mgentz
Board Member
just buy a 7.48 shim kit. cheap insurance.
or buy 10 shims each that are 1-4 sizes smaller than what you have currently.
Old January 31st, 2017, 05:23 PM   #9
bruce71198
bruce71198's Avatar
I've done it on a belt sander, no ill affects.
Old January 31st, 2017, 07:09 PM   #10
mgentz
Board Member
^ that had to hurt! Bu da bum.
[motorcyclistonline] - Long-Term Update: Checking Valve Clearances On the 2015 KTM RC Ninjette Newsbot Motorcycling News 0 September 18th, 2015 12:20 PM
Fixed valve cover bolt leak & valve clearances Linkin Videos 3 June 24th, 2015 03:49 PM
about to start my bike after checking clearances... nickjpass General Motorcycling Discussion 4 July 29th, 2014 06:41 AM
[kropotkin thinks...] - Mike Webb On Cheating In Moto2: "If Anyone Is Cheating, They' Ninjette Newsbot Motorcycling News 0 May 14th, 2012 10:50 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
