Go Back   ninjette.org > General > Off-Topic
Old July 16th, 2010, 05:25 PM   #1
hubcapbandit
hubcapbandit's Avatar
Motorcycle(s): 2006 Ninja 250 (Yellow!)
Locked out of my car today.
Running around this morning taking care of the rest of the paperwork for my new (to me) bike, I went to the UPS store to get the bill of sale notarized. I noticed that it didn't have the mileage written down on it, so I ducked back into the car to jot that down really quick, then went into the store. Coming back out, I was searching for my keys in my pockets. No dice. Looked inside the car, there they are on the passenger seat.
I waited about a half hour before I sent a text to my still-sleeping wife (due to my embarrassment), who then woke up a half hour later to reply. Mind you it was about 95 degrees out. She got hold of her mom who then picked me up an hour later and took me home so I could get my wife's keys, etc.
But yeah, annoying. Not to mention it was 95 degrees out today and I was in jeans and a sort of heavier t-shirt. bleh. I thought I had worked through this whole "locked my keys in the car" when I first started driving, haha. ah well.
hubcapbandit is offline   Reply With Quote
Old July 16th, 2010, 06:14 PM   #2
how did you lock the door w/o having the keys in your hand?
Old July 16th, 2010, 06:35 PM   #3
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
I'm gonna guess....with the "lock" button on the door...
'08 Bonneville Black
sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator
Reswob is offline   Reply With Quote
Old July 16th, 2010, 06:44 PM   #4
...then he shouldn't do that.
I learned years ago to only use the key/fob to lock my car no matter what kind of lame, lazy ass ways car companies have thought up to "help" us out by giving us a "trick" way to lock our cars w/o using the key. They all have logic flaws and can lead to just this scenario.
Old July 16th, 2010, 07:05 PM   #5
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
What lock button on the door? There are lock buttons on the doors now? What the frigin hell?
Anyway, my '87 mazda rx-7 used to have this feature where if you locked the door THEN slammed the door shut, the door would automatically unlock....thereby preventing you from doing something idiotic like leaving your keys inside the car while you inattentively slammed the door shut while locked.
I'm surprised that this feature hasn't been carried over...despite all of the advances with keyless entry and all that jazz.....
Old July 16th, 2010, 07:19 PM   #6
hubcapbandit
haha yeah, I had sat the keys on the passenger seat while I was writing in the mileage on the BoS. locked the door before I shut it, and WHUMP. locked out.
I have an '06 Honda Element, and it'll unlock the doors automatically provided the key is still in the ignition. I wasn't that lucky
Old July 16th, 2010, 07:24 PM   #7
Locksmiff
Locksmiff's Avatar
Motorcycle(s): 2010 Ninja ZX-6R
Our commodores, well from VT onwards have this feature that won't let you push the lock down on the drivers side unless the door is shut.
Locksmiff is offline   Reply With Quote
Old July 26th, 2010, 08:18 AM   #8
dimeified
Motorcycle(s): '09 Blue 250R
my old 911 driver side door could not be locked from the inside or out unless the door was shut. simple and effective
2 thumbs up
dimeified is offline   Reply With Quote
Old July 26th, 2010, 09:59 AM   #9
KTRacing38
2010 250 Cup Champion
KTRacing38's Avatar
Motorcycle(s): 2008 Ninja 250R and 2007 Honda CR150F
I locked the keys of a rental car in the trunk of the car not too long ago. Man did that suck! I'm used to keyless entry on my car and never thought twice about where the keys were when I closed the trunk. If only I had unlocked the doors first... silly.
KTRacing38 is offline   Reply With Quote
Old July 26th, 2010, 10:17 AM   #10
shadowskater
shadowskater's Avatar
Motorcycle(s): 08 Ninja 250R
Lol, same thing happened to be just a couple days ago. I have never locked my keys in my truck but sure enough it caught me. Reason being that my passenger door's actuator is on its way out and its response to the locking signal will not pull the lock all the way down, so it usually takes around 2-3 locks to get it down, so always when exiting the vehicle I will hit the lock button multiple times, then close the door and hit the lock on the keyfob. This time I was doing something awkward right as I parked and forgot the keys on the way out. Luckily I was at a friends house and after traffic died down he took me back to my house to get the spare.
shadowskater is offline   Reply With Quote
Old July 26th, 2010, 11:01 AM   #11
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
I keep two separate key sets, one for just the car, and one for everything else. Extra keys and stuff on the car set would wear out the ignition switch prematurely. I keep a spare door key on the main key set, which I end up using maybe once a year. I can also lock the car with it running, and for grins I occasionally toss the car set into the trunk and lock it when I'm transporting a passenger who doesn't know me that well. The look on their face, borderline WTF+panic, is always priceless.
Old July 27th, 2010, 04:55 AM   #12
g21-30
g21-30's Avatar
DIY - How to keep from being locked out of your car!
Get an extra key made, preferably an all metal one, i.e. no rubber or plastic head! Try the key in the door, in order to be sure that it works!
Now, using a file or grinder cut the ears (the "XXXX's" in the attached picture)
off. Go to the front of your car and look for a wiring loom hanging down. You want a loom that is convenient to reach, just in case you need to eventually use this key! Using electrical tape, place the key along side the wiring loom and wrap the key and the loom together, thus hiding the key. Wrap it a few times and then rub some dirt on the new tape, so that it looks like the original loom or pretty close.
I have done this with all my cars and it has saved my Wife numerous times!
Old July 27th, 2010, 02:50 PM   #13
Blackwidow
sucks, thats happened to me many a times. I actually locked myself out of my apartment all the time, the last time i locked myself out, I went to the back to jump in through the window, and my neighbor walks up to me...i should add that my neighbor is mentally disabled so our conversation was pretty fun...
neighbor: what are you doing?
me: oh i locked myself out and am trying to get in through the window to open the door.
neighbor: you know what i do to make sure i don't lock myself out
me: (very interested in some guidence here)...what?
neighbor: i make sure i have my keys with me when i walk out the door.
me: *puzzled look on my face* um...ya...thanks.
Blackwidow is offline   Reply With Quote
Old July 27th, 2010, 03:07 PM   #14
bikeguy57
Motorcycle(s): 1974 CB360 2008 Black 250 Ninja
Thumbs up
This is the coolest idea I have seen in a long time!!! Thanks
bikeguy57 is offline   Reply With Quote
Old July 27th, 2010, 03:20 PM   #15
Blackwidow
or you can get one of those magnet key holders and put your key in and have it under your car somewhere inconspecious (sp?)
like this one...
http://www.acehardware.com/product/i...LAID=109349185
or you can use this...this has a code.
http://preparedness.com/geseacstloke.html
Old July 27th, 2010, 03:29 PM   #16
front brake locked up yogurtpooh 2008 - 2012 Ninja 250R Tech Talk 8 March 8th, 2015 03:36 PM
Kinda wished I had been driving the car today. ninjamunky85 Ride Reports 5 November 23rd, 2012 07:06 PM
I drove a car today. :( lamchops Off-Topic 34 July 16th, 2012 07:02 PM
So i was driving my car today MarcoPolo General Motorcycling Discussion 8 April 9th, 2012 12:00 PM
Got my car back from the paint shop today Lil_Green_Demon Off-Topic 27 October 5th, 2011 10:49 AM
