June 25th, 2009, 10:59 AM | #1 |
Pedal Power
Join Date: Jun 2009 Motorcycle(s): 2008 Ninja EX250R Posts: 401
Oil level sight glass
Hey all,
Noticed that the bike I bought is leaking oil around the round oil level sight glass. Is there a gasket that might need to be replaced or tightened?? How is this thing removed? Thanks |
June 25th, 2009, 11:10 AM | #2 |
June 25th, 2009, 12:42 PM | #3 |
Pedal Power
07 is the same as the 08?
June 25th, 2009, 12:49 PM | #4 |
for the most part, yes. what, specifically, is it that you're asking about?
the engine lower cases are pretty much a carry over from the pregens. |
June 25th, 2009, 12:56 PM | #5 |
Pedal Power
Bike was in an accident. Oil sight glass leaks. Not too sure if it is the clutch cover that is bent (has some scratches on it) or it the sight glass is bad (no cracks at all). Wondering how to remove the sight glass. IF the info in the links is applicable then maybe the sight glass popped out of it seat and is leaking a little bit
June 25th, 2009, 12:58 PM | #6 |
to confirm, check the part numbers of that sight glass on any site that sells OEM parts and see if the part numbers are the same between gens. I pretty sure you'll find they are.
June 28th, 2009, 04:29 PM | #7 |
The sight glass has a gasket, but I believe it comes as one piece. Best way to get it out is to use a box blade and gently pry it out.
Oil level sight glass | adouglas | General Motorcycling Discussion | 53 | May 16th, 2013 02:30 PM |
Oil sight glass | BlueHairSar | 1986 - 2007 Ninja 250R Tech Talk | 20 | December 13th, 2012 01:23 PM |
Foamy Oil in Sight Glass??? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 17th, 2010 07:00 PM |
Level in sight glass is rising! | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 17 | August 3rd, 2009 02:07 PM |
Oil Sight Glass | empyrean | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 25th, 2009 10:25 AM |
