Old May 11th, 2015, 10:50 AM   #1
kxpower?
kxpower?'s Avatar
Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000
Knoxville Area--Need 2 Pregen cam followers
Hello!
I had the lash adjustment screws on two cam followers back out and vamoosh down the cam chain tube. I'm in the process of tearing the engine down to find the pieces and see if they caused any damage, but in the meantime I need to track down some replacements. So if you have two spare cam followers you're willing to part with for cheap or in exchange for a couple beers at the Knoxville watering hole of your choice hit me up!
My profile still shows Nashville TN but I'm usually in Knoxville nowadays.
Thanks!
Oh god the bikes are multiplying!!!
Last futzed with by kxpower?; May 11th, 2015 at 10:51 AM. Reason: proofreading is better before you hit submit!
kxpower? is offline   Reply With Quote
Old May 11th, 2015, 02:21 PM   #2
Hasersys
Hasersys's Avatar
Motorcycle(s): Have owned Ninja250,EX500,Xj650,RD250,XV750
I have some extra. What you want to pay for them shipping would be pretty cheap an I am not after a lot.
Hasersys is offline   Reply With Quote
Old May 11th, 2015, 02:22 PM   #3
Hasersys
Hasersys's Avatar
I also would go through my eBay account and can ship within a day usually.
Old May 11th, 2015, 03:33 PM   #4
kxpower?
kxpower?'s Avatar
You want to say $20 shipped? I can PayPal in just a couple hours.
Old May 11th, 2015, 03:57 PM   #5
Hasersys
Hasersys's Avatar
Yea that's fine how many did you need? I can post the link tonight when I get home from work.
Old May 11th, 2015, 04:15 PM   #6
kxpower?
kxpower?'s Avatar
Just need 2 I figure $20 is about right for that.
Old May 11th, 2015, 04:18 PM   #7
Hasersys
Hasersys's Avatar
Ok no problem, I get off at about 10 tonight so I should have a link up after that. And shipped once payed for.
Old May 11th, 2015, 04:42 PM   #8
Originally Posted by kxpower? View Post
Hello!
I had the lash adjustment screws on two cam followers back out and vamoosh down the cam chain tube..........
Those should be found in the clutch case, underneath the clutch assembly.
Old May 11th, 2015, 07:49 PM   #9
Hasersys
Hasersys's Avatar
Private msg with link sent
Old May 18th, 2015, 06:27 PM   #10
kxpower?
kxpower?'s Avatar
Quick question, looks like the only gasket I'll need to R&R clutch cover is the 11009 gasket? Need to order whatever I need this week.
Old May 18th, 2015, 09:02 PM   #11
Yes, only the gasket, which you could make yourself:
http://n4mwd.blogspot.com/2013_08_01_archive.html
Old July 14th, 2015, 08:19 AM   #12
kxpower?
kxpower?'s Avatar
@Motofool: I'm finally opening it up and now see that the spring retainers on one valve came off! I luckily have a few extra retainers laying around, is there a trick to keeping the valve closed while compressing the spring with the head still installed? I'm thinking some rope down the spark plug hole or something.
I'd like to avoid pulling the head if I can, just not really sure that's possible.
Old July 14th, 2015, 06:46 PM   #13
I have not done that work on this engine myself, but I don't see why rope would not work.
Use eye protection and plenty of clean rags to keep little pieces from flying away or into the engine via the cam chain well.
Just for general information:
http://www.dansmc.com/valve.htm
If the old retainers are gone, you may want opening the clutch cavity and remove those potentially dangerous things, so they don't end up between the teeth of two gears.
Old July 16th, 2015, 09:11 AM   #14
kxpower?
kxpower?'s Avatar
Did the rope down the plug hole trick, worked like a charm once I figured out that 2 hands were needed on the valve compressor and 2 more dropping the retainers in. I found the old retainers in the oil drain pan
Old July 16th, 2015, 03:03 PM   #15
Old July 16th, 2015, 03:11 PM   #16
You got super lucky. I would have just removed the head and used a valve spring compressor...
You may considering flushing everything clean cheapo oil. Not entirely sure about putting anything down the spark plug hole... clean is the name of the game here.
Old July 17th, 2015, 05:19 AM   #17
kxpower?
kxpower?'s Avatar
It was a clothesline right out of the package so shouldn't have had anything too abrasive on it. I pulled the clutch cover to find the follower and sprayed WD40 all over in the clutch area and the crankcase, and all parts are now accounted for. When I get the timing set I'll probably throw some used oil in there so I can check compression while the motor is out on the bench (just to be sure I didn't bend that valve), that should get any other metal shards washed out of the motor, shouldn't it?
Old August 1st, 2015, 01:49 PM   #18
kxpower?
kxpower?'s Avatar
@Hasersys Check your PM! I need a couple more!
WTB: running pregen engine in LA area antonfire Items Wanted 0 November 13th, 2012 10:07 PM
Takeoffs for pregen-portland area Solunatic Motorcycle-related 0 September 22nd, 2012 07:37 PM
Area P *Pregen* Groupbuy... Anyone Interested? kkim Motorcycle-related 60 July 5th, 2011 02:56 PM
Pregen parts for sale in Bay Area CynicalC Motorcycle-related 11 May 27th, 2011 05:59 AM
4th Annual Knee Draggerz Ball 04/09 - Knoxville area oroboros Ride Reports 1 April 10th, 2011 07:39 PM
