July 24th, 2013, 12:34 PM | #1 |
Done here.
Brake bleeding bliss
http://www.amazon.com/Person-Bleeder...gnetic+bleeder
Boom. http://www.cvs.com/shop/product-deta...L?skuId=715154 Boom. I'm big on maintenance. Change my oil Every 3 track days (should probably change even more frequently). Lube my chain every track. Change my fork oil 2-3 times a year. And ofcourse bleed my brakes everytime I change my oil. It's like meditation. Calms my nerves. Makes me feel good. Makes me feel ready for next track... UNTIL THAT BRAKE FLUID SPILLS EVERYWHERE ON THE BIKE, ON THE FLOORS AND ON ME. Then it's not so meditating. This led me to go on a search for a better setup. And Above links saved a whole lot of time / profanity / and sanity. I recommend it to everyone... PS: I guess I should mention. I bleed my brakes the old school way. Don't use any fancy pumps or anything. Never had a problem. I get rid of all air bubbles in 10-15 minutes. Good enough for me. |
August 9th, 2013, 08:46 PM | #2 |
Good links. Looks like an inexpensive and useful way to go.
August 9th, 2013, 09:37 PM | #3 |
Done here.
August 9th, 2013, 10:16 PM | #4 |
Fast-Guy wannabe
MOTM - Jan '13
i use hose and water bottles so in comparison this is expensive
August 10th, 2013, 04:55 AM | #5 |
^^ same.
August 10th, 2013, 02:21 PM | #6 |
I have the same bottle that the link to Amazon showed. Autoparts stores carry them. Works to bleed a full sytem but not to service it. I did some caliper repair (not a Ninja) so the brake line was empty. To reservice the brake fluid, I could not get fluid flow and pressure using the bottle and pumping the brake handle. The syringe likely would have worked but I bought a Vacume pump from Harbor Freight. Minutes later my system was bleed and filled. About $22. Should last a long time and has good hoses/connectors of different sizes.
Bill |
July 2nd, 2014, 08:35 PM | #7 | |
They also have the tool in the OP for $1 cheaper with no shipping. Because shipping almost doubled it and you canh take off another 25% with a coupon, it's a much better deal if you have HF around. |
Front brake bleeding problem | Baron | 2008 - 2012 Ninja 250R Tech Talk | 28 | September 8th, 2014 08:41 PM |
Rear Brake Bleeding Trouble | dwright0723 | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 7th, 2014 07:26 PM |
Brake Bleeding Question | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 4th, 2014 10:55 AM |
Bleeding brake ? | caineroad | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 24th, 2013 02:53 PM |
bleeding brake fluid... still usable? | Hokie11 | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 14th, 2009 09:54 PM |
