#1 |
Join Date: Sep 2014 Motorcycle(s): Green Ninja 250 2008 Posts: 66
Radiator Leaking
Hello,
I have a small tumble on the bike not to long ago. I noticed some green liquid on my garage floor, not a lot, but some. I took off all the fairings and noticed at the botton right hand corner of the steel colored radiator green liquid was dripping. My question is, Does this need to be replaced? Can it be fixed? If I have to replace it could I just buy the radiator and not have to buy all of the hoses and etc that connect to it? |
#2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
First of all, verify where it's leaking. If it's a loose hose, tighten the clamp. If it's a hole in a hose, replace the hose.
If you suspect it's a bad radiator, you can take it to a radiator shop: they will pressure test it and confirm your suspicion. Then you'll buy a new or used radiator. You can re-use the existing hoses. |
#3 | |
![]() Quote:
If it was affected during the fall, it may be deformed or not fully closed. Try finding the source of the leak (probably right above where is dripping) after you stop the engine. When the coolant is hot, there is pressure inside the radiator that pushes the liquid out. If still not easy to spot, due the same and then wrap the suspicious area in toilet paper. This may help: http://faq.ninja250.org/wiki/How_do_...ling_system%3F
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#4 | |
#5 | |
![]() Quote:
It may work, saving you from replacing your current radiator.
#6 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
If you wind up needing a radiator I have one for sale.
#7 |
#8 |
KAWASAKI GURU
Coolant leaking into oil and oil leaking out of somewhere. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 31 | May 25th, 2013 04:09 PM |
Leaking coolant | Chuffmonkey | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 30th, 2012 11:47 PM |
Red Hot Glowing Radiator Supports/Radiator Top | bluebr65 | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 10th, 2012 10:05 AM |
leaking a little gas | h0yitsdom | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 11th, 2011 04:57 PM |
radiator hose burst :( leaking coolant | h0yitsdom | 1986 - 2007 Ninja 250R Tech Talk | 11 | June 3rd, 2011 11:06 PM |
