August 5th, 2014, 09:36 AM | #1 |
Inexpensive performance gain?
All,
Would love to hear from our tech / mechanical / engineering brain trust on this. Attached is a photo of the stock Kawa EX300 exhaust. I had a very similar configuration on an Italian bike. It would seem to me that the 6 inch or so, cross flow pipe (the one connecting the 2 pipes together) may be hindering the exhaust flow and thus, leading to a loss of performance and economy. Asked the dealer about this and a salesperson said it was needed for back pressure. As mentioned earlier, I had this on an Italian bike, I cut the member off and sealed both ends. This resulted in a substantial gain overall, the bike seemed to "breathe" much better and yes, mpg, top speed and launch times all improved. I am skeptical about doing this simply because if there was a gain to be had, why wouldn't the factory have done it....? My question is has anyone tried this and what would be the risk to do so? p.s. As I look at most performance exhausts for this bike, they do not have this "cross flow pipe" in their design. Thanks in advance for your thoughts. Last futzed with by Zackninja; August 5th, 2014 at 09:38 AM. Reason: Spell check |
August 5th, 2014, 09:53 AM | #2 |
MOTM - Sep '14
@kbryant ?
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
August 5th, 2014, 10:41 AM | #3 | |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
Theory says:
from: http://www.rbracing-rsr.com/exhausttech.htm Quote:
If noone has tried it before, I will !!! Last futzed with by Alex; August 5th, 2014 at 01:40 PM. Reason: edited to add source |
August 5th, 2014, 12:45 PM | #4 |
Grouchy Old Squid
Join Date: Apr 2014 Motorcycle(s): 2006 Ninja 250, 1993 Yamaha FJ 1200 ABS, 1990 Yamaha FJ 1200, 2014 Can Am Spyder RT-S Posts: 37
Zack,
There you have it, a very well stated technical explanation of some of the intricacies of exhaust system design. Some aftermarket 4 into 1 headers have indeed had crossover pipes connecting pairs of pipes, but the added cost was not usually worth the gains to be had. Trust me, you are not likely going to find any benefit in cutting off and capping that crossover pipe. You might find miniscule gains on the top end at the expense of your mid range. Joe |
August 5th, 2014, 12:46 PM | #5 |
Fighting Texas Aggie '05
^^^ can't say it much better than that, but the cliff notes of above it that a lot of exhaust use a link or cross pipe for scavenging effects on the other cylinder/cylinder banks. Some exhaust manufacturers incorporate this into the design, other's do not. It depends on the configuration and design of the piping. It may or may not help/hurt performance to remove the link pipe on the stock unit. Most likely if it gains anything it will be at the expense of performance elsewhere in the curve.
*edit* LOL Joe posted just a bit before I did *edit*
August 5th, 2014, 01:21 PM | #6 |
Area P
Join Date: Dec 2008 Motorcycle(s): Too many to list Posts: 439
Hi Zach - Welcome to the forum. In the simpliest form, the primary function in this particular case is that the cross-over allows smoother sound and reduction in decibels. In most (not all) motorcycle examples, that's why "cross-over" tubes are added. It allows the OEMs to reach the 80 dbA limit, while running a less restrictive muffler and/or without some kind of exhaust valve. Nothing more, nothing less. Twins are notorious for being difficult to pass sound legal limits. I can remember many years ago when designing aftermarket exhaust for Harley-Davidson Motor Company - the primary reason they changed to adding cross-over "balance tubes", was to meet the 80 dbA sound legal limits. It was the first time a manufacture truly admitted why the tube needed to be added. There are of course other ways to address it, but that would be simply through restriction in the muffler, which would lower the power level. The "cross-over" addressed the issue nicely and they were able to reduce sound levels 2 - 3 dbA (which is a huge amount), without the power loss. But it is a delicate balance of the positioning and/or size of the cross-over tube. This takes R&D to come up with the best positioning and diameter. Many times the actual "hole" that the tube is covering, is much smaller than the tube itself. Anyway, a lot more to it, but that is the basic reasoning behind the cross-over. The "surprise" you would get by removing that cross-over on your OEM headpipe, would be primarily sound; possibly a little better throttle response.
micoulisninja - That is a very well put statement. But when you post something like that, you should at least give credit to the people who actually wrote the paper and/or the brunt of it; and I would assume we both know who that is. Plagiarizing is not cool. Having been the in industry almost 40 years, we pretty much all know one another and/or seen most things before. Perhaps this was simply an oversight. |
August 5th, 2014, 01:47 PM | #7 | |
modaholic junkie
Anyone interested can read in detail and examples given here: http://www.rbracing-rsr.com/exhausttech.htm I am sorry if I have offended you or anyone else by unintentionally taking credit from anyone for merely copying and summarizing some of my favourite articles on the web...
If noone has tried it before, I will !!! |
August 5th, 2014, 02:25 PM | #8 | |
Area P
August 5th, 2014, 02:33 PM | #9 |
modaholic junkie
Thank you Kerry !!
August 5th, 2014, 02:47 PM | #10 |
Daily Jap rider
Join Date: Dec 2012 Motorcycle(s): 2012 Ninja 250r Posts: A lot.
The awesomely good natured people on this forum makes me want to hug kittens
August 5th, 2014, 02:54 PM | #11 |
Be gentle!
August 5th, 2014, 02:58 PM | #12 |
Area P
And that is the primary reason as to why I solely support this site when it comes to the 250/300 crowd. Pretty much back to the beginning. Good stuff!
August 5th, 2014, 03:05 PM | #13 |
Daily Jap rider
August 6th, 2014, 03:35 PM | #14 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
How about "X" pipes? How do they work? What about the capped stubby pipes that seem to be there for no reason on some OEM exhaust? Straight cut pipe, or 45 degree slash?
Who's on first? What's on second? Can you really find the ideal collector length using a heat sensitive crayon? What's the deal with reversion harmonics? I miss my 2 strokes.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
August 7th, 2014, 06:22 AM | #15 | |
Straight from Flowmaster "Is an "X" pipe better than and "H" pipe? Not necessarily. Flowmaster has performed extensive dyno testing of traditional “H” pipes and various “X” pipe designs and has found that in most typical street applications, there are no clear benefits of one over the other. “X” pipes have become a buzz word in the world of performance exhaust, and are now produced in a wide variety of styles and designs. Some types perform well, and some others can be quite bad due to the excessive turbulence generated in the merge area. Unlike anything else available, Flowmasters Scavenger X-Pipe design features patented D-port technology to maximize the communication surface area between the two banks of cylinders, and maintain the exhaust pulse velocity for peak scavenging. In terms of sound, an X-pipe will generally provide a smoother, higher pitched tone than that of a traditional “H” crossover pipe. In some specialized race applications such as small cubic inch engines and /or restricted (small bore) carburetors, we have found that an “X” pipe can respond well over an “H” pipe. As with all race applications, there is no substitute for time on the dyno, developing the engine package as a system."
August 7th, 2014, 07:21 AM | #16 |
Years ago, there was a guy that ran a GPZ-550 in IDBA. I forget the class exactly, it was a Modified, I think. Dern fast little bugger.
At any rate, Murray built a custom "X" exhaust for it. That pipe made 6 more HP than any other pipe, plus it made the engine sound like it was turning a gajillon rpm. (It was in fact being turned to near 13,000). That thing would make your ears bleed. ALMOST as loud as the Denco Triple/Triple (Three 750 Kawi triples in one chassis).
August 7th, 2014, 09:40 AM | #17 | |
Area P
That being said, please correct your sig line about Kenny's ride at Indy as it's bugging me. - The TZ750 Miler was never a "short track bike". Back then it was either 250 or 360 two strokes only on the Short Tracks. That was an awesome ride even by today's standards. Kenny get's all the credit, but actually I think Mark Brelsford won a regional mile (Stockton) on an H2 before Kenny's historic win (although Kenny's was of course a GNC event), when everybody was going crazy about a 750 two stroke road race engine being used at a mile event. Ok probably dating myself too much here. Most of this stuff may have occurred prior to many forum members being born yet! |
August 7th, 2014, 09:42 AM | #18 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
just for information.... NONE of the full systems for the ninja 300 have that crossover pipe.... might be worth it to find a used on on ebay cheap ($75 shipped) do the modification and do back to back testing.... a dyno would be the best thing to see if it makes a difference obviously...
Just my 2 cents! |
August 7th, 2014, 09:55 AM | #19 | |
Area P
August 7th, 2014, 10:03 AM | #20 |
KAWASAKI GURU
August 7th, 2014, 11:14 AM | #21 |
I purposely used short track because most people instantly recognize the term. Only us old farts may recognize Grand Nationals.
I was so out of touch on short track, that when I went to see the races at Daytona in March, the bikes were just hotted up dirt bikes. I was envisioning XR-750s crossed up throwing great spouts of clay in my face. At the AIM show last October, on display at the K&N exhibit were two replicas of the bike that Kenny rode. Complete in every detail right down to the first gen Lectrons. Tinkering is fun, but the most fun was my old job back in the 70's when I worked for Honda. TTD (Test to Destruction). What can possibly be more fun that taking a new bike and beating it till it dies and get paid to do it! Speaking of Kawi triples, ever hear of Bill Baxter? He was THE MAN with the H2 drag bikes. In IDBA he held so many records it was unreal. He built an engine that made so much power that not even Paul Gast could build parts to handle it. So he sectioned off the transmission and built a unitized transmission that used Suzuki Pro Stock transmission parts. Now days, I just keep my baby ninja running well, and turn the occasional screw on my buddy's Top Gas bike. That thing is a hoot to ride. If you turn off all the timers and the throttle stop, set the nitrous delay to zero, and give it a build rate of 2 seconds, it will (with my ancient 145 pound ass on it) run 7.80's at 188. And as many hot laps as I have had, it still makes my knees quiver after I get it hauled back down. Oh, and it does have an old Murray pipe that used to be on one of Bob Carpenter's old Pro Stock bikes.
August 7th, 2014, 11:19 AM | #22 |
Area P
Good stuff.
Inexpensive rear stand? | kdogg2077 | General Motorcycling Discussion | 36 | July 8th, 2014 08:26 AM |
Inexpensive slip-on exhaust | peteypetepeep | Items Wanted | 4 | March 20th, 2014 05:49 PM |
Want an inexpensive mini battery | nick5446 | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 13th, 2013 05:25 AM |
Inexpensive/free modifications | Mauchner | 2008 - 2012 Ninja 250R Farkles | 57 | March 27th, 2013 02:36 PM |
Inexpensive Steering Damper | TheJimmyEnglish | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 11th, 2011 11:31 AM |
