March 25th, 2016, 10:00 PM | #1 |
Join Date: Aug 2014 Motorcycle(s): 2016 Ninja 300 ABS, R.I.P 1986 Ninja EX250 Posts: 93
Rear Suspension Help
I've googled quite a bit and came up pretty empty handed.
I'm a very light weight rider. I'm 5' 10", and around 140 lbs soaking wet. I've seen a great many threads for setting your shock, for putting in a heavier spring, etc, but I haven't been able to find anything for lightweight riders. (I've even looked around on female specific forums) So, any help or advice? Aftermarket stuff for us skinny folks? I've got my OEM shocks at to 1 already, but it would be nice to get something a hair lighter for my body. Also if someone is feeling generous, advice on my front end suspension would be greatly appreciated, as that's all black magic to me still. :P |
March 25th, 2016, 10:21 PM | #2 |
It is my opinion that the ninja 250 is very well 'set up' for a wide variety of riders.
Easier and cheaper to learn how to use the tools that you have to their greatest advantage than to modify your tools in such a way that they become easier to use. Legs and arms are wonderful suspension components. Is there something mechanically wrong with the functioning of your bike? Perhaps your front forks are bent, or something of that nature. Hopefully someone else is more helpful than I.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
March 25th, 2016, 10:21 PM | #3 |
I am just taking an educated guess here, but as long as you're not loading 50+ more lbs on the bike... you're pretty much weigh within the stock operating range.
Is there a problem you're trying to solve? Riding 2up? Riding extended ranges?
March 25th, 2016, 10:27 PM | #4 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Post close up pictures of your front & rear tire wear. They will tell us what your suspension is doing and what ight need tweaking, if anything.
But considering your weight; there's probably nothing you need to do but spend your money on upgrading your riding skills! I WISH I had your suspension problems!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
March 25th, 2016, 10:40 PM | #5 |
Freedom for Germany
Dante for the rear I could recommend the following shock for you: MZ366-320TRL from YSS (this is a company from Thailand and their shocks are well known in Europe but maybe not so much in USA for some given reason...).
You can find the description here (please scroll down to Z-366R): http://www.yssusa.com/series-z.html If you have questions about it send an email to Klaus Huenecke from YSS USA (he is well known in the riders community) http://www.yssusa.com/about_us.html With this shock you have the big advantage to setup the Rebound (important) and the spring rate is 80 N/mm what is much better for your weight instead of the oem 93 N/mm. The front normally should fit your weight, maybe give it a little bit less Preload (by shortening the fork collar) and maybe lower the oil level by 5mm. Anyway look to set up the sag for your weight. Good luck |
March 26th, 2016, 10:23 AM | #6 |
I don't know if it makes any difference, but I totally forgot to mention that I'm on a brand new 2016 Ninja 300, not a 250. Stock tires, shock, etc. I've removed some weight from the bike with aluminum fittings, exhaust hanger / passenger peg delete, but I doubt those would have much effect. It's only got 603 miles on it right now.
I rode the hell out of my old '86 Ninja 250 though, and aside from refurbishing the front forks, I don't recall any suspension issues with it. |
March 26th, 2016, 06:38 PM | #7 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
What exactly are you looking to get from your suspension?
Better traction for high speed works on the track? More comfortable ride for daily commute? Avoid dented wheels when running over potholes? I'm 5'10", 155 lb. soaking wet. I use OEM rear shock from 2012 Ninja 250 on my 04 Ninja 250. I replaced the OEM rear tire with a 130/90-16 rear tire, that jacks up the rear end, (when bike is parked on centerstand, rear tire still touch the ground), put more weight on the forks. Progressive fork springs, heavier fork oil. Altogether works for me for my daily commute in NYC, where streets are littered with potholes, slick metal planks and even cobblestones. |
March 26th, 2016, 06:46 PM | #8 |
More or less I'm looking for a smoother ride for commuting, something that doesn't feel like the road is jarring me around as much. The YSS shock looks promising, as I'm not opposed to putting money into the bike. I don't think I would want to go with different tire sizes however
March 26th, 2016, 06:52 PM | #9 |
vampire
Sometimes less tire pressure is all you need for more comfortable ride.
March 26th, 2016, 07:13 PM | #10 |
Freedom for Germany
Yes Dante I've seen that your bike is the EX300.
The differences between the EX250 and the EX300 is so less, it's even not worth to talk about. |
March 26th, 2016, 07:30 PM | #11 | |
Slower than you.
Join Date: Oct 2015 Motorcycle(s): CBR600RR, CB750, EX300 (半蔵) Posts: 667
MOTM - May '16
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research. If another thread is linked or quoted, go read it yourself. |
March 26th, 2016, 07:38 PM | #12 | |
Seriously though, I've tried gaining weight, it just doesn't work for me. 30 years old and I can't manage to keep on a spare pound unless it's strapped to my bag. lol |
March 27th, 2016, 06:30 PM | #13 |
EX500 full of EX250 parts
There's some question over ideal spring rates, but according to RT's calc, the stock rear spring is 20% too stiff for your weight. With the rear too stiff, it'll tend to skip instead of properly absorbing bumps. The fork springs are a bit soft for your weight too, which will only make the rocking horse effect more severe.
I wouldn't expect these differences to have a huge effect on how the bike operates, but I am a big proponent of getting spring rates to match your weight. You can try to set your sag to see how far off the springs are (if they're too far off, you won't be able to get proper free and static sag settings at the same time). Any decent aftermarket shock should come with a spring matched to your weight (whether that's lighter or heavier than stock). Some of the GSXR shocks have softer springs too, if you'd rather DIY and save some money. https://www.ninjette.org/forums/show...02#post1023302 The SV650 shock actually has about the right spring rate.
March 27th, 2016, 07:38 PM | #14 |
ooooh, I wasn't aware of that calculator, thank you so much!
According to that, I should be looking for a spring rate of 7.824, now to find the closest thing to that, that'll fit the 300. Go-go-gadget google-fu! lol |
Rear Suspension Lock Up?? | xXecuterXx2 | 1986 - 2007 Ninja 250R Tech Talk | 4 | July 12th, 2015 07:43 AM |
rear suspension | Nate513151 | 1986 - 2007 Ninja 250R Tech Talk | 31 | February 6th, 2014 11:17 AM |
Rear suspension | fivepin | 1986 - 2007 Ninja 250R Tech Talk | 4 | April 6th, 2010 04:40 AM |
rear suspension | sombo | 1986 - 2007 Ninja 250R Tech Talk | 18 | November 4th, 2009 02:39 AM |
Rear suspension adjustments | Cochese | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 18th, 2009 12:05 PM |
