November 16th, 2011, 12:46 PM | #1 |
Join Date: Jun 2011 Motorcycle(s): Ninja 250R 2011 Posts: 16
Can't shift up
I recently purchased the 2wheels levers from ebay and when I installed it I was unable to shift up. I can shift into 1st and neutral but not 2nd. I put in the old levers to see if I can shift up but wouldn't work. Does anyone know why?
November 16th, 2011, 12:59 PM | #2 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
Just to make sure....are you riding the bike when you're unable to upshift, or is it sitting still?
November 16th, 2011, 01:04 PM | #3 |
Riding still, I have not yet rode the bike. If the bike is moving will it be able to shift?
November 16th, 2011, 01:12 PM | #4 |
I'm not sure about the new bikes, but pre-gens lock out second gear when you aren't moving. The new generation of bikes most likely are the same. If all you've changed is your levers, I highly doubt you did anything to your transmission
November 16th, 2011, 01:17 PM | #6 |
It can be challenging to get the gear lever to do much when the bike is sitting still. 2nd gear will probably be impossible unless it's moving.
November 16th, 2011, 01:31 PM | #7 |
Hmmm I'll test it out when I go home. Its just weird cause I was able to shift up sitting still until I took out the levers.
Posted via Mobile Device |
November 16th, 2011, 01:54 PM | #8 |
Sounds like the kawi neutral-finder feature. It shouldn't have been able to shift up past neutral while stationary prior either.
November 16th, 2011, 08:06 PM | #9 |
So I started up the bike rode it and it shifted!!! Is it normal for it not to shift when its standing still? Because I was able to shift up standing still ever I first bought until I swapped out the levers. Well it still works so its fine just wondering if it was normal. I got too exctied that my bike still works that I forgot to put the kickstand down when I got off! Never done that before....
November 16th, 2011, 11:00 PM | #10 | |
Join Date: Oct 2011 Motorcycle(s): 09 Ninja 250 (black) Posts: 39
The bike is designed NOT to shift past neutral if the bike is not moving. This is a feature so you are not confused what gear you are in at a stop (so you dont have to wonder if you are in first or second, etc.). |
November 16th, 2011, 11:43 PM | #11 |
Thats good to know. Weird, wonder why I was able to shift up sitting still...
GP Shift... | Thrak | 2008 - 2012 Ninja 250R Farkles | 38 | March 29th, 2015 08:31 AM |
WTB: New gen shift linkage + shift knuckle + Woodcraft rear sets | 675Raisinator | Items Wanted | 1 | July 30th, 2012 05:59 PM |
when to shift | kn250 | 2008 - 2012 Ninja 250R Tech Talk | 5 | September 19th, 2010 09:27 AM |
GP Shift. | sometimesido | 1986 - 2007 Ninja 250R Tech Talk | 37 | June 30th, 2009 11:27 AM |
