May 8th, 2014, 08:00 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
Ohlins or Penske Shock Ride Height ... ?
Anyone know the ride height of Ohlins or Penske shock for the new-gen 250? The stock shock is 320mm eye-to-eye ...
Setting up a bike for a friend and need the info. Thanks! Edit : Called Penske and they said they are 315mm eye-to-eye and -/+ 12mm adjustability.
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
May 8th, 2014, 08:04 AM | #2 |
Join Date: Jul 2013 Motorcycle(s): 2018 Ninja 400 Race Bike (in progress...) Posts: 126
The Ohlins goes from 320mm (stock) to 326mm, I run it all the way out at 326mm.
May 8th, 2014, 08:08 AM | #3 |
Thank You for the info. so both shocks are similar ..
May 16th, 2014, 04:12 AM | #4 |
Join Date: Oct 2013 Motorcycle(s): gsxr 750, sv650, 250 ninja Posts: 110
penske 6mm over stock
July 31st, 2014, 10:37 AM | #5 |
Join Date: Dec 2013 Motorcycle(s): Ninja 250R (race), Aprilia Tuono 1000R, CRF250X, DR650 Posts: 18
July 31st, 2014, 12:16 PM | #6 |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
Plus 1 to running ride height to max. I have a Racetech G3-S shock and it allows for +8mm ride height over stock. I found it its better to run it to its max because at stock shock ride height I was dragging pegs when I raced. Going up to the max I greatly minimized that.
Plus it made the bike handle a little better, made it flick in slightly faster. If you want to retain stock handling, reduce the fork height from stock to the same amount you did (so 14mm showing above top triple down to 6mm)
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
July 31st, 2014, 08:07 PM | #7 |
Fighting Texas Aggie '05
jack that rear up !!!!!
August 5th, 2014, 12:16 PM | #8 |
Join Date: Jan 2014 Motorcycle(s): 1996 Ducati 900SS/SP 45k miles Posts: 132
ride height . . .
too much at the rear, too much at the front, this is so confusing.
'09 Ninja 250R track only SOLD "If everything seems under control, you're not going fast enough." -Mario Andretti |
WTB 08+ shock ohlins, penske or similar | jasle | Motorcycle-related | 0 | June 20th, 2012 08:20 PM |
WTB Penske Shock | LCR | Items Wanted | 0 | June 11th, 2012 05:49 PM |
Penske Rear Shock - Where to mount? | esi7esi7 | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 7th, 2011 10:03 PM |
Installed my Penske shock today... | 2WheelGuy | 2008 - 2012 Ninja 250R Tech Talk | 8 | January 30th, 2011 04:46 PM |
[roadracingworld.com] - Penske Schedules Shock Seminar | Ninjette Newsbot | Motorcycling News | 0 | February 16th, 2009 04:40 PM |
