Old November 10th, 2013, 06:25 AM   #1
Løckøut
Løckøut's Avatar
Motorcycle(s): 2007 Ninja 250r
Clutch cable too taut to house?
Well, after my clutch cable shaping a month ago, I ran a new one where the old one was and got up to the handle, on the last step.. spent a total of two hours trying to house the knob into the correct slot. I've been riding it without it fully housed but 'secure' for about the time I was banned. No fraying or issues but I'd really like to house it just for safer measure.
If the line is impossibly too taut [even when adjusted out to the highest allotted slack] to put into it's housing under the clutch lever, are there any tricks to alleviate this issue?
Løckøut is offline   Reply With Quote
Old November 10th, 2013, 07:50 AM   #2
I would remove the bolt-pivot that holds the lever to the base (it has a counter-nut at the bottom and threads into the base), install the cable in the base and lever and only then, relocate the lever (caring for not braking the little plunger of the clutch micro-switch that is under the base) and the bolt-pivot.
Old November 10th, 2013, 09:23 AM   #3
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
Another suggestion, works for me
Screw the adjustor and lock ring all the way in, then out a bit until the slots in the adjustor and the lock ring are facing forward. With the cable NOT routed through the adjustor, stick the end into the lever. Pull on the housing and sneak the cable into the adjustor via the slot.
No guarantee.
GeorgeRYoung is offline   Reply With Quote
Clutch cable Linkin 2008 - 2012 Ninja 250R Tech Talk 5 January 28th, 2015 03:29 AM
clutch cable james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 July 27th, 2013 10:20 AM
Clutch Cable Scootch 2008 - 2012 Ninja 250R Tech Talk 18 March 8th, 2012 02:02 AM
Clutch Cable atomicrm 2008 - 2012 Ninja 250R Tech Talk 2 December 17th, 2011 12:22 PM
Help on Clutch Cable kashun84 2008 - 2012 Ninja 250R Tech Talk 6 March 31st, 2011 08:55 PM
