Old October 3rd, 2013, 06:30 PM   #1
Rollingmenace
Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480)
Front suspension upgrade
Ok looking into a suspension upgrade for the pre gen front..
Looking at emulators springs and preload adjusters... I'm finding a lot of contrasting information....
What exactly is available and what will work on the pre gen.. I've found emulators and springs for a new gen and all the info I have is pointing to the new gen and pre gen internals are all the same... Is this true... And if so what about the new gen adjustable preload adjusters.. Will they work or is there an adjustable alternative for the pre gen...
Rollingmenace is offline   Reply With Quote
Old October 3rd, 2013, 08:43 PM   #2
cuong-nutz
cuong-nutz's Avatar
Springs, emulators, and preload adjusters are all the same.
HalfFast Racing Team
Old October 3rd, 2013, 09:57 PM   #3
Lychee
sail away
Lychee's Avatar
Replace the retaining C-clip with a snap ring. Preload adjusters may not be worth it when you can use a pvc pipe and a few washers. Vary the number of washers to vary the preload. Spend your money instead on linear rate springs that match your body weight. Sonic springs are less than $100. The newgen spring isn't necessarily better depending on your body weight. Don't forget constant viscosity fork oil is also an upgrade.
Old October 4th, 2013, 07:42 AM   #4
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
just stuck in GS500 springs
see http://web.ncf.ca/ag136/EX250/frameindex.htm
GeorgeRYoung is offline   Reply With Quote
Suspension upgrade jgcable 1986 - 2007 Ninja 250R Tech Talk 13 February 13th, 2015 02:22 AM
Advice on Suspension Upgrade? Sykes92 2008 - 2012 Ninja 250R Tech Talk 19 May 20th, 2014 12:26 PM
300 rear shock upgrade and front suspension agentbad 1986 - 2007 Ninja 250R Tech Talk 1 January 22nd, 2014 12:07 PM
New gen suspension upgrade randomwalk101 Ninjettes At Speed 23 October 18th, 2010 09:42 PM
is this suspension upgrade possible???? brausatch 1986 - 2007 Ninja 250R Tech Talk 5 October 3rd, 2010 03:33 PM
