November 10th, 2013, 06:25 AM | #1 |
Join Date: Jul 2013 Motorcycle(s): 2007 Ninja 250r Posts: 128
Clutch cable too taut to house?
Well, after my clutch cable shaping a month ago, I ran a new one where the old one was and got up to the handle, on the last step.. spent a total of two hours trying to house the knob into the correct slot. I've been riding it without it fully housed but 'secure' for about the time I was banned. No fraying or issues but I'd really like to house it just for safer measure.
If the line is impossibly too taut [even when adjusted out to the highest allotted slack] to put into it's housing under the clutch lever, are there any tricks to alleviate this issue? |
November 10th, 2013, 07:50 AM | #2 |
I would remove the bolt-pivot that holds the lever to the base (it has a counter-nut at the bottom and threads into the base), install the cable in the base and lever and only then, relocate the lever (caring for not braking the little plunger of the clutch micro-switch that is under the base) and the bolt-pivot.
November 10th, 2013, 09:23 AM | #3 |
Join Date: Jun 2011 Motorcycle(s): EX250, C10 Concours Posts: 109
Another suggestion, works for me
Screw the adjustor and lock ring all the way in, then out a bit until the slots in the adjustor and the lock ring are facing forward. With the cable NOT routed through the adjustor, stick the end into the lever. Pull on the housing and sneak the cable into the adjustor via the slot.
No guarantee. |
Clutch cable | Linkin | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 28th, 2015 03:29 AM |
clutch cable | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 27th, 2013 10:20 AM |
Clutch Cable | Scootch | 2008 - 2012 Ninja 250R Tech Talk | 18 | March 8th, 2012 02:02 AM |
Clutch Cable | atomicrm | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 17th, 2011 12:22 PM |
Help on Clutch Cable | kashun84 | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 31st, 2011 08:55 PM |
