January 1st, 2021, 05:01 AM | #1 |
Join Date: Jul 2018 Motorcycle(s): kawasaki eliminator 250 d4 Posts: 93
Carb problem
Hi is it possible to get ice inside the float bowls?
Its just that my carb seems to leak out of the overflow when ever it gets very cold, like almost freezing. 1 day it was extremely cold and the fuel came out in a very heavy stream, yet on the not so cold day it was only dripping, just thought it could be caused by ice as it goes away the warmer it gets? |
January 1st, 2021, 07:15 AM | #2 |
Ice doesn't go away when it gets warm, it turns to water. Water doesn't just sit there innocently.
As a wild guess, maybe they're some kind of glop in there that gets very stiff when it's cold, and interferes with the movement of the float and float needle. "Heavy stream" or "only dripping" are very similar. They both mean you need to fix a carburetor problem. Happy New Year Dude! |
January 1st, 2021, 09:16 AM | #3 |
So rip carb rebuild?
January 1st, 2021, 09:29 AM | #4 |
What if I shoved a hair dryer on the carbs in cold weather for 15 mins?
never ever had this problem till last 6 weeks entering uk winter, first day it leaked was 2 to 3 degrees, when it was dripping was maybe 5 to 6 degrees. please enlighten me, sorry, wish to understand and share only? |
January 3rd, 2021, 07:55 AM | #5 |
I'd also say there most likely is gunk inside the bowls that is causing the problem. You could have condensation in the gas that is on the edge of freezing as well.
A carb in good condition doesn't do odd things when the temps drop. |
April 21st, 2021, 10:12 AM | #6 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 460
Have you attempted to drain both fuel bowls? It is a simple procedure, and might help if there is something in there that shouldn't be - like water.
https://faq.ninja250.org/wiki/Draining_the_carbs
... can't stop updating the bike! |
April 30th, 2021, 04:13 AM | #7 | |
carb problem #153131326 | amanda_michele | New Members | 13 | November 29th, 2020 10:57 AM |
Carb sync problem | Cra1g | 1986 - 2007 Ninja 250R Tech Talk | 25 | September 15th, 2016 04:46 PM |
Carb problem? | Carytowncat | 1986 - 2007 Ninja 250R Tech Talk | 15 | March 8th, 2014 11:21 AM |
carb problem | radioflyer | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 19th, 2013 06:55 PM |
Carb Float Problem | Trainsk8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 4th, 2012 12:31 PM |
