August 21st, 2016, 10:20 AM | #1 |
Join Date: Aug 2016 Motorcycle(s): '08 Ninja 250 Posts: 18
What is this electrical connector called?
I bought a voltmeter/usb charger for my handlebar, but it came with this on the end of the wires. I may just cut it off and splice the wires into my battery tender harness, but if I knew what it is was called I can look for an SAE adapter.
August 21st, 2016, 10:28 AM | #2 |
Join Date: Sep 2009 Motorcycle(s): 2013 Ninja 300 w/ ABS, 2014 NC700X, 2008 Ninja 250 (sold), 2002 Ninja 250 (sold) Posts: A lot.
MOTM - Jan '18, Sep '13
Looks like the 2 pin 2.8mm - .110 locking connector here: http://www.cycleterminal.com/110-connectors.html
My Ninja 300 |
August 22nd, 2016, 07:35 AM | #3 |
Join Date: Feb 2016 Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish Posts: 40
parts unlimited:
2120-0443 connector 2120-0453 pins |
August 22nd, 2016, 08:15 AM | #4 |
MOTM - Jan '16
I've always called them a Molex connector.
August 23rd, 2016, 08:50 AM | #5 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
The connectors are Sumitomo MTW-series connectors aka Hitachi-type connectors.
http://www.corsa-technic.com/categor...category_id=53 |
August 23rd, 2016, 09:18 AM | #6 |
I suggest directly wiring it to an accessory circuit. It'll always be there and working without having to plug/unplug things, and there will be fewer connections involved that could result in voltage drop. Using an accessory circuit means the power will be completely cut off when the bike is off - those USB chargers use regulator circuits that are always drawing a little bit of power (it's not a big deal until the bike unexpectedly sits for a lot longer than you planned).
Headlight Connector | Ralgha | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 14th, 2015 03:36 PM |
How do I disconnect this electrical connector | Proteus | 2008 - 2012 Ninja 250R Tech Talk | 8 | November 25th, 2014 08:28 AM |
Help identify this connector | Maielstrom | Off-Topic | 3 | June 29th, 2012 05:17 PM |
Help finding a connector. | gadgetguy1288 | 2008 - 2012 Ninja 250R Farkles | 8 | December 2nd, 2011 10:06 PM |
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2011 01:20 AM |
