Old October 17th, 2013, 08:07 PM   #1
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Main 30a fuse keeps blowing
Edit: The original problem has gone away, but the source of the issue was not found. Bike has been out of commission for a different reason, so haven't been riding it. Possible related issue down below
As the title states, my main 30a fuse blew and so did a replacement. Im sitting on the side of the freeway hoping to get going again. The only thing I did was replace headlights. Bike worked fine for 30 miles then just dies. Where can I look?
Last futzed with by broilmebk; October 25th, 2013 at 09:43 AM.
broilmebk is offline   Reply With Quote
Old October 17th, 2013, 08:29 PM   #2
tc.young
Motorcycle(s): '89 klr 650, '00 250r
there's a short somewhere if you blow the spare. get a tow home and figure it out in the morning where there's light. and you have the proper tools.
if it just blew the one but the spare works ride home fast and buy a spare fuse.
tc.young is offline   Reply With Quote
Old October 17th, 2013, 08:39 PM   #3
broilmebk
broilmebk's Avatar
Yea definitelu a short somewhere but noob that I am I dont know where to look or what to look for. I have a flashlight so I have some light, but I have a feeling I have to open up the bike.. and thats not happening on the freeway.
So any common spots to check?
Old October 17th, 2013, 08:53 PM   #4
Originally Posted by broilmebk View Post
.......The only thing I did was replace headlights........
Normally, the problem is coming from the last thing one changed.
I would go over my prior steps and see what + is touching ground before reaching the new head light bulb.
Old October 17th, 2013, 09:20 PM   #5
broilmebk
broilmebk's Avatar
Could I try disconnecting the wires to the bulb or do they need to be connected?
Old October 17th, 2013, 09:48 PM   #6
cuong-nutz
cuong-nutz's Avatar
Starter relay fuse? Make sure starter wire is not pinched and rubbing the frame on the right side behind to side panel and under the seat.
HalfFast Racing Team
Old October 17th, 2013, 10:32 PM   #7
broilmebk
broilmebk's Avatar
I think thats the fuse im not sure exactly. Its the one right underneath the back of the fuel tank. One end connected to the battery, another grounded to the engine.
Old October 18th, 2013, 04:04 AM   #8
cuong-nutz
cuong-nutz's Avatar
yeah, that's the starter relay fuse. Make sure all your connection are secure and that they are not shorting out.
Old October 18th, 2013, 08:17 AM   #9
Sorry that I couldn't stay and respond to you last night.
Could you solve the problem?
Old October 18th, 2013, 09:07 AM   #10
broilmebk
broilmebk's Avatar
Hey np. I got it towed and called it a night. Im sitting here in the garage trying to find the short still. Hoping I can make it to work for at least half a day..
Old October 18th, 2013, 09:27 AM   #11
Hey np. I got it towed and called it a night. Im sitting here in the garage trying to find the short still. Hoping I can make it to work for at least half a day.......
Try thinking of things you changed and did immediately before the fuse blew.
As I understand, you replace the headlight bulb earlier and the bike started normally (igniting the low beam, I assume), then when riding at night, the main fuse blew.
May it be that the problem happened as soon as you switched to the high beam?
Did you remove the bulb and even replaced with the bad bulb?
If you have a voltmeter that can measure ohms, you can use it for tests, avoiding blowing fuse after fuse: any circuit that shows close to zero ohms is in short.
Old October 18th, 2013, 09:34 AM   #12
broilmebk
broilmebk's Avatar
I had high beam on the entire 30 miles after changing both headlights. I was splitting traffic, maybe ran over one of those reflectors im not sure, I'll have to check my camera. But then all of a sudden bike went dead.
Good news is, the bike just started. Bad news is i dont know what caused it. I moved and checked all wires and connectors didnt see anything exposed. Everything was well insulated. I'll put everything back together and make sure it turns on again..
Old October 18th, 2013, 10:14 AM   #13
broilmebk
broilmebk's Avatar
Yup. Still turns on. I really need to get to work...I hope this doesnt happen again.
Old October 18th, 2013, 10:57 AM   #14
tc.young
Better carry a few main fuses and this weekend look at all the wires.
Old October 18th, 2013, 12:15 PM   #15
broilmebk
broilmebk's Avatar
Yea, I have a couple now.
I checked all the wires though
Old October 18th, 2013, 01:07 PM   #16
broilmebk
broilmebk's Avatar
Just for gits and shiggles..
Old October 18th, 2013, 01:54 PM   #17
That was a really dangerous situation !!!
Hope it never happens again.
If a road bump could caused it, I would find the source of this problem before riding at night again.
Old October 18th, 2013, 02:12 PM   #18
broilmebk
broilmebk's Avatar
Totally caught me off guard, but I did the best I could. I feel like it was better to be stuck in traffic than moving in 60+ mph traffic.
I road over 50 miles today with all kinds of bumps; no problems. Hoping I fixed the issue while making sure wires and connections were good.
Old October 18th, 2013, 08:20 PM   #19
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
For shits and giggles:
Does your cooling fan work?
Is the Cooling fan fuse Good (actually pull it out and test the resistance of it)?
Are all the other fuses ok?
With bike running, try tapping the Starter Relay (big round thing 30A fuse it attached to) and the Starter Circuit Relay (the one at the battery), what happens?
Check resistance at starter switch (black/red wire)?
Why is your dash red?
R6's don't blow fuses.
Old October 24th, 2013, 11:30 AM   #20
broilmebk
broilmebk's Avatar
Haven't been able to try anything until another issue is fixed.
No other fuses blown or have problems.
Where is it red on my dash?
Old October 24th, 2013, 11:37 AM   #21
broilmebk
broilmebk's Avatar
My bike has been sitting around waiting for a part for an unrelated issue, but the other day I went to turn it on and let the motor run for a while. When I revved the engine a bit, my brake light blinks (brake light mod) even when brakes have already been engaged. I don't know if this is related or when it started happening. None of my lights flicker or get brighter/dimmer when I rev. Just the blinking.
Is it related to this issue? Anybody know what's causing brake mod to blink when revving?
Old October 24th, 2013, 04:17 PM   #22
Asspire
Asspire's Avatar
ummm, so if you rev the engine without touching the brake lever(s), the brake light will flash?
have you checked system voltage when running?
Old October 24th, 2013, 04:48 PM   #23
............Is it related to this issue? Anybody know what's causing brake mod to blink when revving?
I would say yes.
Vibrations may worsen a bad connection or broken wire.
Old October 25th, 2013, 09:41 AM   #24
broilmebk
broilmebk's Avatar
I thought I tried that, but I can't remember what the outcome was.
I have not. I'll have to get my hands on a meter to check. What should it be?
I would say yes.
So it should be a wire related to to brake modulator?
Old October 25th, 2013, 10:35 AM   #25
Any live wire (or metal of a connector) touching ground would do.
Old October 25th, 2013, 10:48 AM   #26
Asspire
Asspire's Avatar
12.3 v at idle or higher, 14.4 over 4000 rpm
Tail light fuse keeps blowing radi4fun 2008 - 2012 Ninja 250R Tech Talk 21 May 14th, 2013 09:15 PM
Turn signal fuse keeps blowing..... Stingray1000 2008 - 2012 Ninja 250R Tech Talk 1 May 29th, 2012 10:58 AM
Headlight fuse keeps blowing iangee 2008 - 2012 Ninja 250R Tech Talk 5 May 26th, 2012 01:00 AM
30A main fuse blows j.cuesta 1986 - 2007 Ninja 250R Tech Talk 5 October 29th, 2011 10:06 AM
Keep blowing headlight fuse! Hexdex 2008 - 2012 Ninja 250R Tech Talk 8 October 26th, 2010 07:01 PM
