April 7th, 2009, 07:48 PM | #1 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
quick question about fuse size
i never took a look at the size of our fuses. could someone please tell me if we have the mini or standard size fuses? thanks.
i need to get a 25 amp fuse for my HID kit. |
April 7th, 2009, 07:50 PM | #2 |
April 7th, 2009, 07:53 PM | #3 |
Bad idea, the wiring that the fuses are protecting isn't rated for 25 amps. Only way you want to put a 25 amp fuse in there is if you're upgrading the entire wiring loop from battery all the way through to the HID ballasts to be capable of a 25 amp load.
April 7th, 2009, 07:56 PM | #4 |
Ramen Rider
well, the instructions for my kit say to change to a 25 amp in BOLD RED print, so i figure i better be safe and just follow it. maybe different kits have different requirements? idk.
yeah, i know the fuse block is under the seat. i am just too lazy to pull of my seat and go check. thought someone might know offhand. edit: didn't see alex's post.... well, i guess i can run the stock one and see what happens? |
April 7th, 2009, 07:58 PM | #6 |
Ramen Rider
the instructions are for a motorcycle. actually, they don't have a specific 250 one. they give the 03-07 zx6r instructions.
April 7th, 2009, 08:00 PM | #7 |
Ramen Rider
April 7th, 2009, 08:00 PM | #8 |
I would ride it with what's in there now. (that's what I've been doing for over a year now)
Be sure not to have the hi light on when you start the bike and that will help some with the current draw. (haven't looked... don't even know if all the lights are on the same fuse) If you blow fuse, replace it with the next step higher amperage one, though I doubt you will ever have to do that. |
April 7th, 2009, 08:02 PM | #9 |
Ramen Rider
ok... i trust you guys more than the instructions. strange that it says to make sure to start up with both headlights on.
was thinking about just hooking up the low beam side and running the stock high beam. idk. |
April 7th, 2009, 08:06 PM | #10 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE Posts: 564
When I installed my HIDs, if I ever went to high beam (start the bike with low beam only then after 5 mins turn on high beam) I would blow the stock 10A headlight fuse. I replaced mine with the next step up, a 15A fuse and have had no more issues. I can start the bike with both on and it is fine.
2008 GREEN Kawasaki Ninja 250R. AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen |
April 7th, 2009, 08:08 PM | #11 |
do the hi beam too... you will be amazed what you can see on an unlit road at night.
April 7th, 2009, 08:10 PM | #12 |
Ramen Rider
ok thanks everyone for the quick replies. i will do both.
April 7th, 2009, 09:35 PM | #14 |
Join Date: Mar 2009 Motorcycle(s): 2009 Kawi Ninja 250R Posts: 114
15A is probably the best compromise you can make. don't go any higher.
April 8th, 2009, 02:49 PM | #15 | |
Join Date: Feb 2009 Motorcycle(s): '95 BMW K75 Posts: 188
Going directly to a 25A fuse is the equivalent of sticking a penny in your fuse at home. Everything will work fine, but nothing will ever stop an overload (and therefore a fire). 15A may well be unsafe also, as it may be too much amperage for the circuit. |
April 8th, 2009, 03:07 PM | #16 |
when calculating a wire's max amp capability, not only does the gauge have an affect, but also distance of run, too, though I guess in this case it's negligible.
quick question | Electronic M | 2013 - 2017 Ninja 300 Tech Talk | 57 | March 17th, 2015 04:41 AM |
Quick question | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 26th, 2014 11:40 AM |
Quick Question | PsHYk | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 10th, 2012 02:58 PM |
Just a quick question | zooman | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 18th, 2012 10:52 PM |
Quick Question! | shiftdrift06 | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 1st, 2012 08:31 PM |
