Old March 26th, 2014, 01:07 PM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
metric thread size question
hi I was wondering where I might be able to get the thread size of the bolt that holds the shifting link into the heel guard the hill guard is bolted on for the footpeg and the shifter is bolted onto the heel guard,
I feel mine is a little stripped out and I wanted to try and tap it which is less expensive to buy a tap and it would be to buy the heel guard, it's held in there tight enough it doesn't move when you put a Allen wrench thread locker, I check it on a pre trip it's more of a bother just knowing that it is there like that.
could I find that size in the E service manual.
forgive my newbee 250 questions thanks,
mikedabike64 is offline   Reply With Quote
Old March 26th, 2014, 01:11 PM   #2
bring the screw with you when you buy the tap. you can get a full tap and die set with teeth feelers at HF for $25.
Old March 26th, 2014, 01:20 PM   #3
mikedabike64
ok
Ty Alex, getting ready for spring for the track here in Nj, with such a long winter it gave me plenty of time to work on it. having a blast working on it. thanks
Old March 26th, 2014, 03:38 PM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
The thread is 8x1.25. If you can find a thing called thread chaser it would be better than a tap. A tap will cut metal away. The chaser will bend the metal back it its original shape. If all else fails a helicopter coil or time-cert will repair the heal guard.
Worlds fastest 250 ninja
Old March 26th, 2014, 03:59 PM   #5
mikedabike64
ok thanks eric
appreciate the help
Old March 26th, 2014, 04:17 PM   #6
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Originally Posted by Racer x View Post
...If all else fails a helicopter coil or time-cert will repair the heel guard.
Your spell check got you! I think you meant to say helicoil or keensert (key insert is the generic term). Or did you say that on purpose? (no offense intended, either way).
Old March 26th, 2014, 06:17 PM   #7
Racer x
Racer x's Avatar
Ya it got me. I was at work doing some dumb ****.
I ment heli coil. But I don't like them at all. Except they are readily available. What I use are Time sert thread repair. I have used them for twenty years. When rebuilding Mercedes Benz V8 engines all the head bolt threads in the block must be replaced. This is what the factory uses.
www.timesert.com
Old March 26th, 2014, 06:57 PM   #8
dcj13
Participant
dcj13's Avatar
Cool! Thanks for the link. Looks like a keensert without the stakes.
Not another tire size thread!?!?? really!? gantt 2008 - 2012 Ninja 250R Tech Talk 10 March 23rd, 2015 08:01 AM
Rear spool thread size Robbo81 2008 - 2012 Ninja 250R Tech Talk 20 August 18th, 2014 01:48 AM
Coolant drain plug thread size Kneedragon88 2008 - 2012 Ninja 250R Tech Talk 1 June 7th, 2014 12:06 PM
Speedometer Thread Size skilletmo 2008 - 2012 Ninja 250R Tech Talk 18 April 3rd, 2013 05:50 AM
Thread pitch and size for Spool bolts Xuracing 2008 - 2012 Ninja 250R Tech Talk 5 July 5th, 2009 01:21 PM
