August 22nd, 2016, 09:54 AM | #1 |
Join Date: Jul 2016 Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6 Posts: 210
Oil leak AND ticking noise
So there's definitely an oil leak coming from what looks to be the front-left portion of the valve cover gasket. Time for a new gasket? Looks like it should be a cheap and easy fix if that's the case..
Furthermore, I have a slight ticking noise that many people in the past have attributed to loose valves, so it may need an adjustment. I took it into the shop a couple of months ago and they did a valve adjustment, but maybe there are still some that are out of spec? Here's a video of the ticking noise: https://youtu.be/0c0HCdZ196o |
August 22nd, 2016, 10:05 AM | #2 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
Did you try tightening the bolts on the valve cover? 87 IN lbs
August 22nd, 2016, 10:11 AM | #3 |
Join Date: Feb 2016 Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish Posts: 40
Fresh valve cover bolt grommets with a new valve cover gasket will fix you up. Make sure you clean all the goop out of the groove the VC gasket sits in. Adjust your valve per the service manual paying very close attention to the adjuster nut specs.
August 22nd, 2016, 10:51 AM | #4 |
Do you have part numbers for those grommets? Not quite sure what you're referring to.
August 22nd, 2016, 11:20 AM | #5 |
Join Date: Feb 2015 Motorcycle(s): 286, 296, 599, 799 Posts: 436
http://www.bikebandit.com/oem-parts/...9183#sch433963
that link should take you right to all of the parts. #92055 x4 #11009A x2 #11009 X1 |
August 22nd, 2016, 11:43 AM | #6 |
If your ordering new gasket, be sure to get all of them
# 11009, 11009A, and 92055 Nothing is more annoying than forgetting a gasket, and have it leak, don't be cheap, and save yourself a possible headache. Be careful not to overtighten the valve cover bolts, you could possibly break them, cheap Japanese bolts don't like to be overtightened.
August 22nd, 2016, 11:49 AM | #7 | |
August 22nd, 2016, 12:07 PM | #8 |
Those are just part numbers for the diagram.
The actual part numbers are as follows, 11009-1575 GASKET X 2 11009-1574 GASKET,CYLINDER HEAD X 1 92055-1225 RING-O,HEAD COVER BOL X 4
August 22nd, 2016, 12:20 PM | #9 |
August 22nd, 2016, 06:13 PM | #10 |
Good deal, it's important to remember NOT to over tighten the bolts.
I personally use a 1/4" drive set on almost the whole bike Less tendencies to over torque/tighten. Add to that I've changed over most of the fasteners to stainless steel allen heads, and some titanium as well, not only for looks, but for a better fastener. There are a few things I break out the 3/8" but not many.
August 24th, 2016, 06:03 AM | #11 |
To get to the valve cover, do you need to remove the two coils? I've already unbolted the entire front engine mount with the radiator and moved it all forward just slightly, but the coils are still kind of in the way.
September 3rd, 2016, 01:47 PM | #12 |
So I adjusted the valves, replaced the gasket, and put it all back together. I also cleaned the air filter since the gas tank was already off (the air filter was mounted in sideways. WTF.)
I'm still hearing a ticking noise, though. Also, when I give it throttle, it doesn't respond but then it finally will. Didn't have this problem before. Maybe doing something with the air filter caused it? https://youtu.be/PzA0ofLD0ro EDIT: So I took it out for a 15-20 minute ride and it rode pretty well and no longer had unresponsive throttle. Yay. Last futzed with by Cra1g; September 4th, 2016 at 07:52 AM. |
September 4th, 2016, 01:25 PM | #13 |
Join Date: Jun 2015 Motorcycle(s): 1999 Ninja 250 Posts: 5
The ticking could be this:
http://faq.ninja250.org/wiki/Cam_cha...sioner_removal Here's the sound mine was making https://youtu.be/63BYlPWJqEM |
Ticking noise... at lean angle? | MattyJamm | 2008 - 2012 Ninja 250R Tech Talk | 18 | May 4th, 2017 05:50 PM |
ticking noise | jcsalazar | 2008 - 2012 Ninja 250R Tech Talk | 5 | October 29th, 2014 12:24 PM |
Ticking/clicking noise? | rmorse | 2008 - 2012 Ninja 250R Tech Talk | 18 | August 15th, 2012 07:36 AM |
Ticking/Clicking noise coming off throttle | patw | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 4th, 2011 04:01 PM |
Ticking noise on front wheel? | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 11th, 2010 11:14 PM |
