Old February 28th, 2012, 11:47 PM   #1
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Don't ever take a Ninja 650 apart
I just spent 9 hours installing heated grips, won't be doing that ever again.
AFM #676
Supersports are for n00bs
Old February 28th, 2012, 11:59 PM   #2
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I didn't take any pictures, but the fairings are quite a bit more complicated than on the 250. The next problem was the unmovable gas tank. Not only is there now a fuel pump to deal with, but the ignition is also incorporated into the gas tank. I have no idea how to remove the tank from the bike and spent a good amount of time trying. Since I couldn't remove the gas tank my options were extremely limited on what I could attach my relay kit to. Wiring the grips from the battery was also more complicated because I couldn't go under the tank. Once I had everything wired, the grips weren't working. All the wiring looked perfect and I was perplexed. Went to the store and bought a multimeter so I could find the problem. I forgot to install the fuses in the relay kit
Oh also the threads on the bolt for the gas tank were all ****ed up so now my gas tank is not attached as the bolt won't go back in. Hopefully the dealer will replace it.
Basically because there were no DIY's I spent a good amount of time saying, "How in the ****ing hell am I supposed to do that?!" Ended up attaching the relay to the brake lights.
I only took one picture, around 6:30pm and sent it to my date to tell her I wouldn't be able to make it tonight.
AFM #676
Old February 29th, 2012, 12:56 AM   #3
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
The relay to the brake lights is actually a good idea. Keeps the grips from drawing power once the bike is off.
Trailerboy531 is offline   Reply With Quote
Old February 29th, 2012, 12:56 AM   #4
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I wanted to do it to the horn though in case something shorts, then I'd be out a horn not brake lights
AFM #676
Old February 29th, 2012, 01:06 AM   #5
Trailerboy531
Have some faith in your work man!
Old February 29th, 2012, 01:34 AM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Lol, I didn't know what I was doing.
AFM #676
Old February 29th, 2012, 01:58 AM   #7
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Reading this is exactly what makes people scared to buy used bikes.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old February 29th, 2012, 04:37 AM   #8
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Too bad you aren't working on a bike that has a dedicated forum with outstanding DIYs.
Old February 29th, 2012, 05:44 AM   #9
HKr1
IC2(SW)
HKr1's Avatar
google seems to have a few links about removing fuel tank 650r.
Q. I want to remove my fuel tank, how do I do this?
A. Take off the seat and remove the two Phillips head screws that hold on the tank/seat side trim. Remove the trim by pulling it out of the clips which hold it in place along the side, take care not to loose the rubber spacers on the fuel tank seam at the forward end of the trim.
Remove the two 12 mm bolts that hold the seat front locator “U” bracket in place. Gently lift the tank and support it with a small wooden block approx 2” high. On the left hand side disconnect the electrical connector to the fuel pump and the fuel tank cap vent line (black hose). On the right hand side disconnect the main fuel hose by sliding the red locking tab on the female connector (hose side closest to the engine) out until it reaches its stops. Support the male connector (hose side, closest to the tank) and pull the connectors apart. A small amount of fuel may leak from the connectors but the tank will not drain.
A small flat blade screwdriver may be needed to open the locking tab. The fuel tank can now be removed by sliding it aft off the two rubber mounts on the front frame. Installation is the reverse procedure.
http://homepages.slingshot.co.nz/~shanetp/Index.html
Old February 29th, 2012, 06:17 AM   #10
Dano
Dano's Avatar
Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919
thats exactly why having a manual is a good idea.
Dano is offline   Reply With Quote
Old February 29th, 2012, 07:58 AM   #11
Whiskey
Am I the only one thinking "why?"
heated grips in cali just sound unnecessary... it's about 8C (46-47F) here & i'm wearing summer gloves on the bike.
Old February 29th, 2012, 08:16 AM   #12
bluesinorbit
bluesinorbit's Avatar
Lived in the UK all your life? The temperature has been hitting below 50F lately and it feels like the cold is going straight to the bones. Our bodies are very much adjusted to the good weather in California. Before Cali, I lived in South Florida where it is hot and humid just about all year around. I used to love cold weather as a child in South Korea. After about three years of Florida, I couldn't stand strong air conditioning.
bluesinorbit is offline   Reply With Quote
Old February 29th, 2012, 08:45 AM   #13
Whiskey
Nope, moved recently from wetter & colder Ireland
Old February 29th, 2012, 09:59 AM   #14
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Heated grips? In Cali?
Would you like to borrow some balls?
Old February 29th, 2012, 11:16 AM   #15
thisisbenji
thisisbenji's Avatar
Motorcycle(s): 2009 Ninja 250r (Sold), 2009 FZ6, 2015 Honda Grom
It's in the 50s here today, I felt like it was super warm. I could see hand warmers being great when it's in the 30s though.
thisisbenji is offline   Reply With Quote
Old February 29th, 2012, 11:37 AM   #16
ajcadoo
Towster ['__'`,-,
ajcadoo's Avatar
Motorcycle(s): 2010 Green Ninja 250 SE
haha, seriously. Thats what I thought. Cmon Jiggles, heated grips, really?
Although us Californians are really picky with our sub-50 degree weather.
ajcadoo is offline   Reply With Quote
Old February 29th, 2012, 11:44 AM   #17
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Ah but I don't have a 650r I have a 650, it was completely redesigned this year and that DIY is no help
AFM #676
Old February 29th, 2012, 11:46 AM   #18
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yea uh it's more for the 40 degree nights when I have a 45 minute commute home on the freeway. When I get home, my hands are numb
Also for the rain
AFM #676
Old February 29th, 2012, 11:48 AM   #19
Jiggles
Jiggles's Avatar
MOTM - Apr '13
See the thing is I don't ever drive my car. It's raining today, I'm going to be very happy to have these installed
AFM #676
Old February 29th, 2012, 11:58 AM   #20
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Below 50°? Bwahahahaha!!!!
That ain't cold. Try 16°F, for that I needed heated gloves. I generally don't run heated anything until the temps are in the low 30's. Then again, it's all relative. Summers around here only get into the low 100°F range for a few weeks at a time.
Old February 29th, 2012, 05:06 PM   #21
ajcadoo
Towster ['__'`,-,
ajcadoo's Avatar
Got it! Makes all the sense in the world now...
Old February 29th, 2012, 05:07 PM   #22
ajcadoo
Towster ['__'`,-,
ajcadoo's Avatar
Below 50 in cali is Antarctica. We dont like it one bit
Old February 29th, 2012, 06:09 PM   #23
lol noob.
[cyclenews.com] - First Look: 2015 Kawasaki Versys 650 ABS & 650 LT Ninjette Newsbot Motorcycling News 0 October 16th, 2014 05:40 AM
[motorcycle.com] - 2015 Kawasaki Versys 650 ABS/650 LT Preview Ninjette Newsbot Motorcycling News 0 October 15th, 2014 08:30 AM
[sportrider - features] - 2015 Kawasaki Versys 650 ABS and Versys 650 LT First Look Ninjette Newsbot Motorcycling News 0 October 15th, 2014 07:50 AM
[faster and faster] - 2013 Husqvarna TR 650 Terra, TR 650 Strada unveiled Ninjette Newsbot Motorcycling News 0 July 12th, 2012 03:00 AM
[topix.net] - BMW Powertrain Recalls: F 650/800, GS 650 Ninjette Newsbot Motorcycling News 0 June 21st, 2010 12:30 PM
