July 14th, 2014, 07:21 PM | #1 |
Stunts Extraodinar
Join Date: Jun 2014 Motorcycle(s): 1999 Ninja 250 Posts: 74
Sprocket Cover Inspiration
Why you should open up that front sprocket cover every now and then when you clean and lube your chain! This thing probably hadn't been opened up at all before I got the bike.
That gunk in there is so thick I had to use a knife to scrape it off. It would deposit sludge back onto the chain after cleaning it as the chain was ribbing right on through it. Also the sprocket after cleaning was shiny silver and squeaky clean. Ramifications? HORSEPOWER BABY! It's a totally different beast now. You would be surprised how much that can affect performance. I could only reach about 87 mph tucked in and maxed out rpm 5th to 6th, now I got to 90 without even trying and accelerate up big hills in 6th no problem. |
July 25th, 2014, 11:53 PM | #2 |
July 26th, 2014, 06:10 AM | #3 |
Certified looney toon
MOTM Jul '13, Jul '14
Bah, that's nothing. Mine was so gunked up the first time I removed it, it was basically glued on. Took a lot of work to pry that sucker off.
July 26th, 2014, 08:16 AM | #4 |
Wrench wench
Join Date: Jun 2014 Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS Posts: 415
Haha, oh man. I just did that last week, for probably the first time in the bike's life. It had a chunk so big, the only place there wasn't grease was directly where the chain travelled.
Felt really good to clean that up. |
July 26th, 2014, 07:48 PM | #5 |
motorcycle rider
Join Date: Apr 2009 Motorcycle(s): '14 Yamaha V-Star 650 Custom (silver) Posts: A lot.
I don't really get how cleaning your chain would give you an extra 3 MPH. Would a build-up of grime really impact your top speed?
'14 Yamaha V-Star 650 Custom (silver) |
July 27th, 2014, 01:41 PM | #6 |
Stunts Extraodinar
Well when the little ninja is trying to squeeze every last horse power out of its engine at speed, every little bit helps a lot. Friction is pretty powerful, powerful enough to stop your bike with a little post it sized brake. The same reason tucking down makes a huge difference due to air resistance. I'm sure the difference would feel negligible on a larger displacement motorcycle. Moving your limbs as fast as you can through water sure sucks compared to air doesn't it? :P
Will backflip for tips |
Sprocket cover removal | 675Raisinator | Ninjettes At Speed | 3 | January 24th, 2012 12:58 PM |
Sprocket cover | demp | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 10th, 2010 06:36 PM |
