December 8th, 2017, 02:11 PM | #1 |
[motorcycle.com] - 2018 TVS Apache RR 310 Revealed
TVS Motors revealed its new Apache RR 310, the most advanced model ever released by the Indian manufacturer. While the 2018 TVS Apache RR 310 will likely never be brought over to the U.S. market, it is important for one reason: it’s essentially the precursor for a BMW G310RR. BMW and TVS worked together to develop a platform using a 313cc DOHC Single-cylinder engine and trellis frame. The platform has already resulted in two BMW models, the G310R and the G310GS. The first sportbike version, however, is from TVS, giving the company a 300-class sportbike to compete against the likes of the RC390, from KTM and TVS’ direct Indian rival, Bajaj. While 300-ish sportbikes are considered entry-level models in the West, they are considered premium models in India, offering a significant step up from the 150cc to 200cc models that make up most of the local market. “Today is a proud moment for us at TVS Motor Company. Driven by our promise of delivering more to customers than their expectations, TVS Apache RR 310 is the beginning of our breakthrough into the super-premium category,” says KN Radhakrishnan, TVS president and chief executive officer. “We started building our premium brand – Apache RTR with 150cc and succeeded in raising the customer aspirations with 180cc and 200cc bikes. TVS Apache RR 310 is another step in our effort to deliver beyond customers’ expectations and offering them a chance to upgrade from premium to super-premium category. TVS Apache RR 310 is a testimony to our Racing DNA and R&D capabilities, positioned to fulfill the ever-growing aspirations of the new age customers globally.” The reverse-mounted Single cylinder is inclined slightly rearward with the air intake at the front, providing a more direct path for both the ram air intake and exhaust. On the Apache, TVS claims the engine produces a peak output of 33.5 hp at 9700 rpm and 20.1 lb-ft at 7700 rpm, numbers not too far off from the G310R’s claimed 34 hp at 9500 rpm and 20.6 lb-ft at 7500 rpm. Strip away the Apache’s bodywork and you’ll see a similar engine, trellis frame, suspension, and even wheels as on BMW’s G310R. The suspension is also similar to the G310R’s, with a 41mm upside-down fork and a directly-mounted KYB monoshock. TVS did not provide rake or trail information, but we do know the Apache’s 53.7-inch wheelbase is about a third of an inch shorter than the G310R’s. Curb weight is a claimed 374 pounds, or about 24 pounds heavier than the naked G310R. The brakes are also identical between the TVS and BMW, with a single four-piston caliper with a 300mm disc up front and a two-piston caliper with 240mm disc at the rear. ABS is offered as standard equipment. The Apache also uses the same 17-inch five-spoke die-cast alloy wheels as found on the G310R. The Apache adopts a mass-forward design with a high, rising tail with aggressive edges inspired by the silhouette of sharks. TVS says it conducted extensive wind tunnel testing to reduce drag and maximize downforce. The shark motif continues with the gill-shaped vents between the layered bodywork. TVS says it plans to offer the Apache RR 310 in international markets, but we’re unlikely to see it in North America. More likely, we’ll see BMW introduce its own version, likely to be called the G310RR. TVS offers two color options: Racing Red pictured above and Sinister Black pictured here. 2018 TVS Apache RR 310 SpecificationsEngine Type4-stroke, 4-valve, liquid cooled, reverse inclined single cylinderDisplacement313ccMaximum power33.5 hp at 9700 engine rpm (claimed)Maximum torque20.1 lb-ft at 7700 engine rpm (claimed)Bore x Stroke80mm x 62.1mmFuel injectionBosch – Closed loop EFICompression ratio10.9 : 1StarterElectricIgnitionDynamically controlled integrated high energy ignition systemClutchWet multi plate – 8 plate designTransmission6 speedBattery12V, 8AhHeadlampBi-LED projector, 30W @ 13 VTail lampLED 4 WFrameTrellis frame, split chassisFront suspensionInverted cartridge telescopic forkRear suspensionTwo arm aluminum die-cast swingarm mono tube floating piston gas assisted shock absorberFront BrakeFour-piston fixed caliper with 300mm petal type disc with ABSRear BrakeTwo-piston floating caliper 240mm Petal type disc with ABSFront WheelMT 3.0×17Rear WheelMT 4.0×17Front Tire110/70-R17 M/C 54H TubelessRear Tire150/60-R17 M/C 66H TubelessTank Capacity2.9 gallonsHeight44.7 inchesLength78.8 inchesWidth30.9 inchesWheelbase53.7 inchesGround clearance7.1 inchesSaddle height31.9 inchesKerb weight373.7 pounds2018 TVS Apache RR 310 Revealed appeared first on Motorcycle.com. Click here for full story...
[visordown.com] - TVS Apache RR 310 unveiled | Ninjette Newsbot | Motorcycling News | 0 | December 6th, 2017 03:26 AM |
[visordown.com] - Incoming: TVS Apache RR 310 | Ninjette Newsbot | Motorcycling News | 0 | December 4th, 2017 07:21 AM |
[visordown.com] - TVS Apache RR310S revealed in design sketch | Ninjette Newsbot | Motorcycling News | 0 | August 15th, 2017 04:43 AM |
TVS Akula 310 Concept | toEleven | Videos | 2 | February 20th, 2016 07:55 PM |
[visordown.com] - TVS Apache 200 BMW connections continue | Ninjette Newsbot | Motorcycling News | 0 | January 11th, 2016 04:43 AM |
