Old September 14th, 2011, 04:52 AM   #1
demp
Clutch Problem?
This morning, I found that the bike is pulling forward with the clutch lever fully depressed... tried adjusting the cable with the little screw adjuster on the handlebars without much luck, do I just need to adjust it even more?
any other causes of this?
Old September 14th, 2011, 05:09 AM   #2
Vampyre
Vampyre's Avatar
Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue
When it is cold it will do this sometimes. Mine will tug just the tiniest bit until it is warmed up. If you have your rear on a stand you will even notice that if you start the bike in neutral is will slowly spin the wheel. If you clutch cable is properly adjusted I wouldn't worry too much about it.
Vampyre is offline   Reply With Quote
Old September 14th, 2011, 07:27 AM   #3
leed
leed's Avatar
Motorcycle(s): Time will tell
Yup. This is normal. You can also feel it a little if you start your bike in gear. It doesn't hurt to double check, though. See how it is when it's all warmed up.
If you're curious as to why, it's because of the wet clutch system. The oil acts like a fluid coupling between the clutch plates, since it is of relatively high viscosity especially when the oil is cool. When one plate starts moving, it spins the oil, which in a free system, would cause the other plate to move. If you're sitting, it will just feel like it wants to go forward instead.
Old September 14th, 2011, 11:05 AM   #4
demp
KABOOM Clutch cable broke... I can't believe I never noticed it was fraying!
Old September 14th, 2011, 01:54 PM   #5
leed
leed's Avatar
Yeesh. Well, hopefully you found out before getting too far on the road!
Old September 14th, 2011, 03:36 PM   #6
demp
Lol! bike's actually in barrie, no worries it's locked in one of our C-cans
picking up a new cable tomorrow
Major Clutch Problem? Help! MaxxVE 1986 - 2007 Ninja 250R Tech Talk 32 August 22nd, 2013 04:29 PM
Helping a friend with a clutch plate problem! skilletmo 2008 - 2012 Ninja 250R Tech Talk 109 April 28th, 2013 06:09 PM
clutch problem for a 09 650 ninja james250ninja General Motorcycling Discussion 5 February 13th, 2013 08:06 PM
New engine, new clutch problem headshrink 2008 - 2012 Ninja 250R Tech Talk 16 August 16th, 2011 12:14 PM
Dead clutch or Newbie problem? Racebrewer 1986 - 2007 Ninja 250R Tech Talk 10 November 23rd, 2009 10:23 AM
