Old October 12th, 2011, 05:54 AM   #1
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
Blinkers stopped working :(
So, the other day I noticed my blinkers weren't turning on sometimes they would work, sometimes they wouldn't. Now they just plain don't work! Any ideas? I already ordered a new flasher relay
I have flush mount fronts, integrated rear, and it doesn't matter if I try to use left or right blinkers if that matters
Please help
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old October 12th, 2011, 06:41 AM   #2
Do they come on and stay on or not come on at all when they are "not working?" Does the dash indicator light at all?
Old October 12th, 2011, 08:37 AM   #3
caps
Sexy Beast
caps's Avatar
Nothing at all
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old October 12th, 2011, 11:29 AM   #4
Check your relay. It may have developed a short.
Old October 12th, 2011, 07:27 PM   #5
caps
Sexy Beast
caps's Avatar
I ordered a new one (that better fits my application anyway) hoping it is as simple as that
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old October 12th, 2011, 07:57 PM   #6
Do you have your original around in the mean time? With it, you should at least get *something* (solid lights).
Old October 12th, 2011, 11:37 PM   #7
Domagoj
I have stock blinkers, but I had a similar situation. Turned out to be an issue with the dirty contacts.
As all of yours are dead, have you tried something super simple, like turn signal relay fuse? Try measuring the voltage and see where it goes dead.
Sometimes working sometimes not looks like faulty contact somewhere. I'm no electrician though.
edit:
link to the old thread
Old October 13th, 2011, 12:54 AM   #8
jonthechron
Motorcycle(s): magHitVE
Thumbs up
I personally use this stuff, it has worked for me numerous times on all of my vehicles..
Kaleco synthetic blinker fluid
http://kalecoauto.com/index.php?main...&products_id=6
Old October 13th, 2011, 03:44 AM   #9
caps
Sexy Beast
caps's Avatar
They don't blink with the stock relay
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old October 13th, 2011, 04:44 AM   #10
I did blow a fuse for my tag light and dash lights once. Not sure if there's one for just the blinkers though.
Old October 13th, 2011, 05:06 AM   #11
caps
Sexy Beast
caps's Avatar
if it was a fuse it wouldnt have been working intermittently the other day
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old October 13th, 2011, 05:58 AM   #12
Yep, but if something was shorting out intermittently and causing the intermitent operation, it very well could have blown a fuse to cause it to stop working completely. Replacing the fuse wouldn't solve the issue that caused it, but it would be a necessary part of fixing it if that happened.
Old October 13th, 2011, 08:45 AM   #13
caps
Sexy Beast
caps's Avatar
You have a good point their, I will check it when I get my relay
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old October 15th, 2011, 10:54 AM   #14
caps
Sexy Beast
caps's Avatar
http://www.ninjette.org/forums/showt...063#post388063
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
12v stopped working rasta 2008 - 2012 Ninja 250R Tech Talk 8 January 25th, 2014 01:17 AM
Turn signals stopped working. Insan3guy General Motorcycling Discussion 1 October 15th, 2013 10:17 PM
Tach stopped working? beta7 2008 - 2012 Ninja 250R Tech Talk 1 July 4th, 2013 09:31 AM
Blinkers just stopped working coluk33 1986 - 2007 Ninja 250R Tech Talk 8 May 6th, 2013 09:13 PM
tach stopped working -.- ajaygraci 2008 - 2012 Ninja 250R Tech Talk 23 March 31st, 2012 10:55 PM
