Old September 5th, 2010, 08:41 PM   #1
KTRacing38
2010 250 Cup Champion
KTRacing38's Avatar
Motorcycle(s): 2008 Ninja 250R and 2007 Honda CR150F
Last futzed with by KTRacing38; September 10th, 2010 at 08:29 PM.
KTRacing38 is offline   Reply With Quote
Old September 5th, 2010, 09:09 PM   #2
Originally Posted by KTRacing38 View Post
- tip over sensor
tip over sensor???
Old September 5th, 2010, 10:42 PM   #3
KTRacing38
KTRacing38's Avatar
some people call it a relay... it's the part that tells the motor to shut off if the bike is on its side. I cut mine off for race purposes (can shut the motor off if you lean too far), but because I'm putting the bike back to street, it really should have one again.
Old September 5th, 2010, 10:53 PM   #4
Kristy... are you sure our bikes have one? I can't find it in this wiring diagram, but I could be missing it.
http://www.mickeywebpages.com/users/...e_Dia_v1.1.gif
if there isn't one, what is it that you cut off? where was it located?
Old September 5th, 2010, 11:04 PM   #5
KTRacing38
KTRacing38's Avatar
Near the sidestand - in the diagram it looks like they are calling it a sidestand switch.
Old September 5th, 2010, 11:35 PM   #6
cool... so you need a sidestand switch.
FYI, the sidestand switch works by killing the engine (actually not allowing the ignition to work) when the side stand is down and in gear... it has nothing to do with the angle/lean of the bike.
Old September 6th, 2010, 12:05 AM   #7
Yeah. I remember Motoman of Mototune USA/"Break In Secrets" fame warning everyone about them but there isn't one on our Ninjettes. A lot of racers take the sidestand off to save weight (they tow thier bikes around with hitches and wheel chocks), so bypassing it might make sense there (depends if it needs to be normal open or normal closed).
Last futzed with by CZroe; September 6th, 2010 at 08:38 AM.
HELP! 2009 Stock Parts Value? ladyrocket Motorcycle-related 3 April 14th, 2013 05:59 PM
A Few 2010 stock parts NathanUc Motorcycle-related 2 May 30th, 2012 01:27 AM
Stock parts off a 2012 saxnbass Motorcycle-related 15 April 27th, 2012 08:39 PM
2011 stock parts.. greatwhiteninja Motorcycle-related 20 August 24th, 2011 10:54 AM
Looking for a few stock parts used jeffwessel Items Wanted 9 April 13th, 2009 11:42 AM
