July 5th, 2022, 04:44 AM | #1 |
[webbikeworld.com] - 2022 Kawasaki Z650RS [Specs, Features, Photos]
Click here for full story...
The 2022 Kawasaki Z650RS: Ride Light, Ride Free Contents Kawasaki has always stayed on top of trends in the motorcycle world, so it should be no surprise that they decided to capitalize on the cafe racer renaissance by producing a factory-ready middleweight cafe-style naked of their own. Enter the Z650RS—a bike seemingly designed to prove that Japanese motorcycle manufacturers understand eurobikes just as well as any major British or Italian brand. This is a brand new bike for 2022, although it draws heavily from both the Z650 and the Z900RS. It essentially takes the style and performance flourishes from the latter bike and adds them to a bike with roughly the same size and power as the former. The result? A nimble, easy-to-handle standard motorcycle that still packs enough zip to get your blood pumping. You’ve got a 649cc parallel twin engine here, pumping out 67 hp @ 8,000 rpm and 48.5 lb-ft @ 6500 rpm. That gives you plenty of power to play with—and believe us, you’re going to want to play with this thing. Other features include horizontal back-link rear suspension for handling bumps in the road, and Kawasaki’s economical riding indicator, plus an assist & slipper clutch. The Z650RS comes in Metallic Spark Black or Candy Emerald Green—both of which help it stand out as a classy and distinctive member of the Kawasaki motorcycle lineup for 2022. It’ll also compete handily with rivals from other brands, like the Royal Enfield Interceptor 650. The 2022 Kawasaki Z650RS starts at $8,999 USD / $9,999 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Z650RS in one place. Model Overview </p>General Info
Main Specs
Competitors 2022 Kawasaki Z650RS Specifications ENGINE Engine649cc, 4-stroke, 2-cylinder, DOHC, liquid-cooledPower67 hpBore x Stroke83.0 x 60.0mmCompression Ratio10.8:1 Fuel SystemDFI® with Keihin 36mm throttle bodiesStarterElectricLubricationDRIVETRAIN ClutchTransmission6-speed, Manual, Return ShiftFinal DriveSealed chainCHASSIS Suspension FrontTelescopic fork/4.9 inSuspension RearHorizontal back-link with adjustable spring preload/5.1 inBrakes FrontDual 300mm discs with two-piston calipers, ABSBrakes RearSingle 220mm disc, ABS Tires Front120/70 ZR17Tires Rear160/60 ZR17Fuel Tank Capacity3.2 galColorCandy Emerald Green, Metallic Moondust Gray/Ebony ELECTRICAL IgnitionTCBI with electronic advanceSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS Overall Length81.3 inOverall Width31.5 in.Overall Height43.9 inWheelbase55.3 inGround Clearance4.9 inSeat Height31.5 inCurb Weight412.3 lb*WARRANTY Warranty12 MonthsKawasaki Protection Plus12, 24, or 36 months 2022 Kawasaki Z650RS Features Assist & Slipper Clutch Based on feedback from racing activities, the Assist & Slipper Clutch uses two types of cams (an assist cam and a slipper cam) to either drive the clutch hub and operating plate together or apart. Under normal operation, the assist cam functions as a self-servo mechanism, pulling the clutch hub and operating plate together to compress the clutch plates. This allows the total clutch spring load to be reduced, resulting in a lighter clutch lever feel when operating the clutch. When excessive engine braking occurs – as a result of quick downshifts (or an accidental downshift) – the slipper cam comes into play, forcing the clutch hub and operating plate apart. This relieves pressure on the clutch plates to reduce back-torque and helps prevent the rear tire from hopping and skidding. This race-style function is particularly useful when sport or track riding. Dual Throttle Valves Late-model sport bikes often use large-bore throttle bodies to generate high levels of power. However, with large diameter throttles, when a rider suddenly opens the throttle, the unrestricted torque response can be strong. Dual throttle valve technology was designed to tame engine response while contributing to performance. On models with dual throttle valves, there are two throttle valves per cylinder: in addition to the main valves, which are physically linked to the throttle grip and controlled by the rider, a second set of valves, opened and closed by the ECU, precisely regulates intake airflow to ensure a natural, linear response. With the air passing through the throttle bodies becoming smoother, combustion efficiency is improved and power is increased. Economical Riding Indicator Using high-precision electronic control for engine management, Kawasaki models can achieve a high level of fuel efficiency. However, fuel consumption is greatly affected by throttle use, gear selection, and other elements under the rider’s control. The Economical Riding Indicator is a function that indicates when current riding conditions are consuming a low amount of fuel. The system continuously monitors fuel consumption, regardless of vehicle speed, engine speed, throttle position and other riding conditions. When fuel consumption is low for a given speed (i.e. fuel efficiency is high), an “ECO” mark appears on the instrument panel’s LCD screen. By riding so that the “ECO” mark remains on, fuel consumption can be reduced. While effective vehicle speed and engine speed may vary by model, paying attention to conditions that cause the “ECO” mark to appear can help riders improve their fuel efficiency – a handy way to increase cruising range. Further, keeping fuel consumption low also helps minimize negative impact on the environment. ABS (Anti-lock Brake System) Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment. Horizontal Back-link Rear Suspension Compared to the Kawasaki traditional Uni-Trak® rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling. 2022 Kawasaki Z650RS Photos 2022 Kawasaki Z650RS Videos New 2022 Kawasaki Z650RS First Ride Review! Kawasaki Z650RS 2022 Review | New Kawasaki Z650 RS Road Test in Marseille | Visordown.com Links Kawasaki Official Websites Social Media Links The post 2022 Kawasaki Z650RS [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Kawasaki Ninja ZX-14R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 2nd, 2022 10:14 AM |
[webbikeworld.com] - 2022 Kawasaki Ninja ZX-6R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 2nd, 2022 10:03 AM |
[webbikeworld.com] - 2022 Kawasaki Ninja H2 SX SE [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 04:53 PM |
[webbikeworld.com] - 2022 Kawasaki Ninja H2 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 04:41 PM |
[webbikeworld.com] - 2022 Kawasaki Ninja H2R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 02:02 PM |
