September 4th, 2012, 06:31 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): 2009 Kawasaki Ninja 250r SE Posts: 4
Brake Light Always On
Hey all,
Looking for a little advice for a problem with my 2009 that I noticed this evening. It looks as though my brake light is constantly on. The previous owner had a flashing brake light installed (blinks 5 times, then goes solid). I have had the bike for a little over 100 miles and have not noticed any issues with the brake light prior to tonight. About two weeks ago, I took the bike into the shop to make sure everything is in proper working order and had the brake fluids flushed. When I first turn the key, the rear light flashes and then stays solid as if I have applied the brakes. If I apply the front or rear brakes, there is no change in the intensity of the light. I have read that it may be the rear brake pedal switch, however I am not sure how you adjust this. Thanks for the help! |
September 4th, 2012, 06:34 PM | #2 |
Try ruling things out.
First thing I would do is take the flasher out of the circuit and see if the problem still occurs. |
September 5th, 2012, 12:07 AM | #4 |
hi,
check brake switch with spring attached as can sometimes need adjusting, happened to mine. found kinda behind break pedal on right side of bike. |
September 5th, 2012, 05:48 AM | #5 |
Thanks everyone! The brake switch "screw" was barely threaded in. I assume this happened after they changed the brake fluids a few weeks ago. Regardless, it is fixed!
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL | coelgrim | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 11th, 2013 05:10 PM |
Wire integrated tail light such that the brake light stays off while signal flashes? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 4th, 2012 06:36 PM |
FS: Original brake light or FDB integrated tail light (current generation) | CZroe | Motorcycle-related | 9 | September 11th, 2011 06:23 PM |
WTB: Rear OEM 2008+ Ninja250 Tail Light/Brake Light | FerociousNINJA | Items Wanted | 5 | March 29th, 2010 08:52 AM |
OEM Tail/Brake Light Comparison to LED Tail/Brake Light | g21-30 | 2008 - 2012 Ninja 250R Farkles | 19 | November 7th, 2009 12:08 PM |
