March 12th, 2010, 11:24 AM | #1 |
MOTM - Sep '18, Feb '16
250 Ninja Service. Baltimore Area
Well it is spring and time to ride again.
For all those interested in service work . Racer X is open and doing service work on 250 Ninjas. Only on the 250 Ninja . I am located in Baltimore City and I can pick up and deliver you bike. I charge $1.00 a mile one way to pick up and deliver. So if you live 10 miles away it only cost 10 dollars to pick it up. Then another ten to deliver it . Or you can bring it to my shop.PM me for details and an appointment. My prices are reasonable . I charge 55 per hour. And have flat rates for some things. You are welcome to get you own parts . And I don't have much in stock so I would have to order parts before you bring the bike. Or you will have to wait for the parts .Or I can get parts .If I get the parts I charge 10% for parts that I get from Cheap cycle parts . For the time being a 600 mile service /oil change is 100 dollars I will change the oil and filter included in the price. K&N filter Your choice of oil or Repsol 10w40 Lube and adjust the chain . Check brakes Pads and fluid Check tire condition and pressure check year. I can replace and balance tires for an additional charge. Check coolant Test the battery with a state of the art battery and charging system tester. Check body for missing bolts and plastic clips Check Clutch for adjustment I can also do any other major or minor work on both new and old 250 ninjas I do carb jetting suspension tuning and install accessories so PM me if you need work or just have a question . |
March 14th, 2010, 10:52 AM | #2 |
So slow I'm first!
Join Date: Oct 2008 Motorcycle(s): 06 Kawasaki Ninja EX250 Posts: A lot.
mmmmm thanks for the info ^^
Learn from the mistakes of others, you cannot make them all yourself. Save yourself the trouble and Learn. |
Ninja 250 Maintenance and Service. | krolinked | General Motorcycling Discussion | 4 | January 23rd, 2013 10:03 PM |
Need 08+ Ninja 250 Service Manual | abhijitz | 2008 - 2012 Ninja 250R Tech Talk | 8 | November 13th, 2011 10:58 PM |
Good service spots in Bay Area in California? | Sungfooo | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 30th, 2010 12:19 PM |
When do I need to do the 2nd service for Ninja 250 | bikermunda | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 16th, 2009 03:29 PM |
For Sale: 2004 Ninja 250 - Baltimore, MD | nmd003 | Motorcycle-related | 21 | August 6th, 2009 08:06 PM |
