December 1st, 2009, 01:01 AM | #1 |
Join Date: Nov 2009 Motorcycle(s): 2001 Ninja 250 (Sold); 2008 Ninja EX500 Posts: 273
Windscreen for a shorty?
Okay, I've barely cracked 70mph on the bike, and I'm thinking I want to change out my windscreen, as I'm not terribly fond of the "lifty" sensation I'm getting with the stock screen.
I've been reading the reviews for different replacement screens (Mike's, Double Bubble, etc.) on this forum, but most are from taller folk than I. I'm pretty short (5'2" on a good day, although the BF swears I'm shorter).....any suggestions for a little rider? |
December 1st, 2009, 10:16 AM | #2 |
December 1st, 2009, 10:58 AM | #3 |
Well, it's probably just me.....I'm not used to riding at higher speeds....I don't think I did over 40 on the little 305LTD I had 25 years ago. Anyway, it feels like the wind wants to take me off the bike, upwards. I was kinda hoping I could change that; if not, I guess I'll have to get used to it.
December 1st, 2009, 11:00 AM | #4 |
Mr. 988
I have a Laminar Lip and like it. You can adjust the height to your preference. http://www.laminarlip.com/ex250.php
Here is a photo of my bike. I have repositioned the Lip about 1.5 inches lower since this photo was taken. It is attached with Dual Locks (kind of industrial strength "velcro" like dots). I have had my bike up around 85+ with no problems and the airflow hits me at about helmet level, not mid chest like the stock screen. The only issue is a slight buffeting and noise at speed. Not really a problem with me. jeff |
December 1st, 2009, 06:33 PM | #5 |
Join Date: Mar 2009 Motorcycle(s): '09 Ninja 250 Black Posts: A lot.
I have the touring zg windshield and i'm only 5'. I still feel the wind on my helmet when i'm riding sitting up just cruising but when i'm on the freeway and leaning on the tank it's perfect espescially when i'm doing 100mph so the speedometer says
I'm not small, I'm fun sized |
December 4th, 2009, 02:27 AM | #6 |
Join Date: Jul 2009 Motorcycle(s): 2001 Kawasaki Ninja 250 Posts: 74
I think you'll get used to it. Keep riding and see how you get accustomed to it. I am 5'8" and have the ZG Double Bubble, and putting that on made the wind hit the upper part of my chest rather than a couple inches below. It did move it up a bit, not significantly, but it feels a bit better than before. I still get plenty of wind hitting me, but I've done 300 mile days on a normal expressway with speed limits of 70mph without tucking in much...I just got used to the wind after a while.
But my reasoning for getting a taller windscreen was to lessen the wind hitting my helmet...which didn't really change after switching to the ZG double bubble windscreen :P So I recommend you ride for a little bit more to see how you fit with the bike. I know I can now do 300+ mile days instead of the 50 mile days I first started out with! |
December 25th, 2009, 08:12 PM | #7 |
This may help.
I got a euro gt shield from mikesshields.com
It's 23" tall and blocks lots of air. I don't feel like I'm flying off the bike anymore. The old stock windshield used to push air right under my helmet, now riding is much quieter. |
December 31st, 2009, 11:28 AM | #8 |
Join Date: Apr 2009 Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold) Posts: 586
If you are 5'2", how high over the stock shield are you anyway? I had the ZG Double Bubble, and at just shy of 6' I really liked it. If I tucked, I was out of the wind.. I would imagine that at your height, the wind would be pushed at the top of your helmet or so...
2000 Honda CBR600F4 Silver and Red 1999 Kawi Racing Green Ninja 250 sold |
December 31st, 2009, 11:45 AM | #9 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
If you are 5'2" and havent cracked 70mph...you need to twist the throttle.
Im 6'3" 185lbs, and I can crack 70mph no problem. Stick it in 6th, and twist the throttle...let it go past 8g and it will fly with you on it. |
December 31st, 2009, 04:18 PM | #10 |
I'm sorry thats just fugly on the little ninja I do like your front fender mod though.
January 4th, 2010, 02:12 AM | #11 |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
Yeah those screens don't look the best, but they work.
Sometimes people need to make a choice, use something that works they way they want, or stick with something that looks good. To me it doesn't look that bad, I guess since I have seen several Euro bikes running them.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
February 15th, 2010, 09:24 AM | #12 |
Being about 4 inches taller than you and having quite a bit of seat time over the 100 mph mark on the pre-gen 250s I think you should work on bringing your head a little lower. Full tuck the chinbar of my helmet usually scuffs up the gas cap, give or take a little. I'm not saying you have to run full tuck everywhere but sportbikes are designed around the idea of a rider tucked in somewhat. At 160 mph, regardless of what bike I'm on if I just sit upright the helmet will try and choke me out and shift upwards obscuring my view. I would suggest getting a little lower in the bike and see how much of a difference its making. Also, lower end helmets can cause more buffeting than a higher dollar helmet that fits you better. My old Bieffe helmet used to do that to me around 80 mph....switched to Arai and it doesn't start till 160 untucked.
A.
04 EX250: 112.7 mph 00 ZX12R: 229.6 mph Built & Tuned by RnR Cycles |
February 15th, 2010, 02:51 PM | #13 | |
February 15th, 2010, 04:43 PM | #14 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
Amazing the prices of those Laminar Lips. I guess if it say motorcycle or boat on it, the price goes waaaaayyy up.
Those super velcro dots just stick on to the windshild and the lip? So you can remove it any time you want? |
February 15th, 2010, 04:47 PM | #15 | |
Mr. 988
Jeff |
October 21st, 2010, 08:39 PM | #16 | |
Join Date: Oct 2010 Motorcycle(s): 2006 Ninja 250 Posts: 1
I like it.
I does look geeky, but I think I'm going to go with the same one you got for the winter, and then change it back in the summer, when a little wind is actually good. |
February 22nd, 2011, 09:26 PM | #17 |
Join Date: Feb 2011 Motorcycle(s): 2005 ninja ex250 Posts: 2
I just purchased a Euro GT for my winter/cold weather/ and long distance riding. Tired of the cold wind blast, I'm a comfort over looks guy myself. If this works well I may invest in the winter wings as well. Thanks for the pic of it mounted on the bike.
February 24th, 2011, 07:50 AM | #18 | |
Mr. 988
Did you contact Mike? I understand that he had been having health issues and had stopped taking orders for a while. I do notice that he has taken down the notice on his site that stated he was not taking orders. Seems he is back in business . Let us know how long it takes to receive your order. Jeff
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix Cancer |
February 24th, 2011, 08:12 AM | #19 |
Hey Jeff,
Yeah, I noticed the website had changed too I decided to place an order. He got back to me the next day and said he would build it and ship it in a few days. |
February 24th, 2011, 08:59 AM | #20 |
Mr. 988
Good to hear. Thanks.
Shorty brake lever | caineroad | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 18th, 2013 10:36 AM |
FS: Chinese shorty levers | Old Lemon | Motorcycle-related | 11 | December 2nd, 2012 11:29 PM |
Shorty vs. Long Levers | THE BIG SITT | 2008 - 2012 Ninja 250R Tech Talk | 19 | October 8th, 2011 10:50 PM |
Shorty levers installed | chitor | 2008 - 2012 Ninja 250R Farkles | 8 | June 22nd, 2011 06:00 PM |
Gear help for a (female) shorty? | Talonne | Motorcycle Gear | 15 | August 3rd, 2009 10:14 PM |
