August 21st, 2013, 02:02 PM | #1 |
WOT WOT WOT
Join Date: Jul 2013 Motorcycle(s): '12 Ninja 250R Posts: 421
5 - 7 inch piece of bent metal on my bike
It's a 2012 250r. It's attached to the left (if you're looking forward while sitting on the bike) side of the radiator at the top. When I was taking apart the front assembly I saw wires were held to it via some rubber pieces.
What is that? EDIT: Never mind, I'm going to have to take a pic. I'm seeing several pieces that look like it on the parts diagram but I'm not too sure. |
August 21st, 2013, 02:08 PM | #2 |
Join Date: Mar 2013 Motorcycle(s): 2011 Ninja 250 Black Posts: 30
Sounds like the horn mount. Do you have a picture? Does your horn work? ;-)
August 21st, 2013, 02:34 PM | #3 |
Join Date: May 2011 Motorcycle(s): 2006 GSXR 750; 1983 CB750SC Posts: 277
(Assuming I'm talking about the right piece of metal) It's a bracket that connects from the frame to the front fairing stay. This bracket is just there to guide the wires from the bike to the headlights and to the dash.
August 21st, 2013, 02:51 PM | #4 | |
WOT WOT WOT
Should I bother replacing it or just do my own thing with it? It's bent in, if it's just for the wires, I s'pose I could bend it back the way it needs to be. @mgovern I was looking at that on the parts diagram, at first I thought it was but I don't think it's the one. Man, I should of really posted after I took a pic. When I get home from work, I'll do it. |
Metal piece under stock front fender | samw | Ninjettes At Speed | 59 | October 20th, 2015 07:47 PM |
Lowside- bent clutch thrust rod and possibly bent shift fork? | Klondike1020 | General Motorcycling Discussion | 3 | April 1st, 2014 02:29 AM |
[crash.net - MotoGP] - Edwards blasts 'piece of sh*t' bike, Aprilia at Indy? | Ninjette Newsbot | Motorcycling News | 0 | July 26th, 2012 09:00 PM |
Bent some metal and stripped some screws.. help me ha | Jordan91 | 2008 - 2012 Ninja 250R Tech Talk | 13 | May 21st, 2012 07:17 PM |
[roadracingworld.com] - Pirelli To Switch From 16.5-Inch To 17-Inch Slicks For 2013 S | Ninjette Newsbot | Motorcycling News | 0 | October 18th, 2011 06:20 AM |
