March 6th, 2010, 05:17 PM | #1 |
Join Date: Nov 2009 Motorcycle(s): 2009 Kawasaki 250R, 2008 Genuine Buddy 50 Posts: 121
Interstate riding
Just took the bike out for a couple hour ride including about 20 miles of interstate riding. It may just be a matter of acclimation, cold tires stock tires or something but the entire distance it felt squirrely and the experience was fairly tiring. This left me wondering, how far have you ridden at interstate speeds? How does the bike handle for you? Being in the midwest, being able to traverse long distances is going to be part of the deal. Is there anything besides sucking it up and dealing with it that can be done to give the bike better highway manners?
March 6th, 2010, 08:19 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250, '11 Street Triple R Posts: 337
Just relax. The bike is great on the freeway. Wear some ear plugs, get used to 9,000 rpm, and enjoy the ride.
The Sunday Best | Current mileage: 50,000 |
March 6th, 2010, 09:03 PM | #3 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
I ride at interstate speed and above on almost every road, but for some reason I-65 tires me. It seems so much more windy for some reason. Also everyone does 90-100mph so I have to run wide open on the interstate, and I can't pass anyone. Also all the big trucks scare me.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink |
March 6th, 2010, 09:04 PM | #4 |
Join Date: Aug 2009 Motorcycle(s): 2014 Ninja 300, 2008 ZX6, 2011 Ninja 1000 Posts: 622
For me, the 250 has been fine on the highways. Yes, you have to get used to the high revs. But, that part of the charm of the bike. For the wind noise, I wear headphones. I keep the volume at a level where I hear what's going on around me and still rock to the music. Cruising around 55 - 60 mph is fine sitting straight up. After that, you are going to have to tuck. Keeping your arms relaxed in both stances is the key. I used to ride with my shoulders tensed up. After every ride, my whole upper body would end up aching. After loosening up a bit, I haven't had that problem.
March 6th, 2010, 09:33 PM | #5 |
My bike has always been very stable at highway speeds and above. Two things that have improved the experience though in when I switched to Pirelli Sport demons and when I intalled a double bubble windscreen.
March 7th, 2010, 07:48 AM | #6 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
Check your tire pressures. Low pressure can give you that squirrely feeling, esp. in the front wheel.
March 7th, 2010, 03:36 PM | #7 |
Caferacer
Join Date: Mar 2009 Motorcycle(s): 2008 Ninja 250r Posts: 39
Plus one on the tire pressure...interstate speeds just amplify the issue. Check your pressures before leaving home.
March 7th, 2010, 04:04 PM | #8 |
All of the above---plus relax your grip. You don`t have to "White Knuckle" the handlebars. Assume a nice relaxed grip and let the bike dance under you. It is a sweet dancer with a smooth rhythmic motion--a dance you can enjoy if you relax. Don`t push the lead, erstwhile you get your toes stepped on.
March 7th, 2010, 04:05 PM | #9 | |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
Just be aware that at highway speeds and in tight traffic, the little Ninjette has very little "extra" to give. Look further ahead and plan accordingly. Like anything else, it's a skill set that you'll get better at the more you do it.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
March 7th, 2010, 04:14 PM | #10 |
+1 to all above. Also might consider a 15-T front sprocket, it'll drop your highway RPM a little. I used to ride with a tight upper body like Andre and even 20-30miles on hwy left me stiff. Now I do 300mi+ (1-2 stops) without so much as an ache.
Big +1 for the sport demons. I've been abaolutely thrilled with their performance in corners as well as on the highway over my stock Dunlops.
March 8th, 2010, 02:09 PM | #11 | |
Fastly Slow!!!
Join Date: Feb 2010 Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125 Posts: 467
March 8th, 2010, 03:18 PM | #12 | |
March 8th, 2010, 03:42 PM | #13 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ebony Ninja 250R Posts: 137
The bike is fine on the highway, or mine is at least. Sprocket swap made world of difference.
Posted via Mobile Device |
March 8th, 2010, 04:36 PM | #14 | |
Don't get me wrong, I want a bigger bike and will have a zx6 in the next few weeks. But, the 250 is just fine for whatever you want to do, in my opinion. Granted, I thoroughly expect my opinion to change once I get my zx6. |
March 8th, 2010, 06:29 PM | #15 |
I am DEFINITEVLY with Paul, Jeff, and Matt. The 15T sprocket change made a big difference--at least for me. I will be honest, and say that I have only had two days experience with that mod--but am really impressed with the result. At least to me, it looks like a good start. It does amaze me that a one tooth change can make such a difference.
March 8th, 2010, 06:32 PM | #16 |
I went ahead and did the 41toother in the back. Those two sprockets completely changed the character of the bike.
Matt 2008 Ebony Ninja 250R (a.k.a. "Venom") |
March 8th, 2010, 06:50 PM | #17 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
The 250 for me on highways (100 mi. +) can be fun but on excrutiating windy days very tiring. In order to make the freeways an easier and more enjoyable ride I did the following mods and adjustments...... 1. Sport Demons 2. Piugg Racing Windscreen 3. Corbin Seat which makes gripping and turning more controlled 4. Adjusted the pre-load up by 1 notch 5. Adjusted tire pressure (increased). With that I now have very little concern when travelling the freeways. It feels planted, the wind is less of a concern (remember too to keep your arms loose and ride the wave so to speak) and its by far more enjoyable.
March 8th, 2010, 06:50 PM | #18 |
Matt , You went 15--41? Would be interested on your take with this mod.
March 8th, 2010, 07:03 PM | #19 |
Thanks for the input guys. I checked the tire pressure before setting out today. Rear was down quite a bit and the front was a bit low. Remedied that problem and we'll see how that affects things. I'll consider the sprocket mod since it seems to be recieved well by most folks. I'll want to get my carburetion sorted out first since I'm still having some low end hiccups and I'm guessing that the slightly taller gearing will not help. I'm also going to pick up a double bubble once I graduate (parking permit is stuck to the windscreen) as that will help with airflow over my 6 foot self in a tuck. Maybe an upgrade from the stock IRCs?
March 9th, 2010, 05:31 AM | #20 | |
Psychic war veteran
March 9th, 2010, 05:43 AM | #21 |
You are sleeping
Tire pressure, lights and brakes before every ride.
I've done 3 hours on the freeway at once with the stock gearing and seat. I can sit up on the bike at top speed. (no real need to tuck, although I love tucking and usually do) The high RPM doesn't bug me.. I like how it sounds TBH. Will sound even nicer when I get that Yosh on there. I do worry the thing will explode on the freeway sometimes though at 10k in sixth gear. Still on the stock "rubbers". I've had it up to 100mph max on level ground and 105mph coming downhill. lol
<Yeah, it's a 250. LMFAO! Weaksauce |
March 9th, 2010, 06:23 AM | #22 | |
Join Date: Jun 2009 Motorcycle(s): Ninja 250R Fuel Injected Model 2009 Posts: 357
If the bike is squirmy its usually not the tires, its usually the rider having a death grip on the bars. While going along you should be able to bend your elbows freely and easily rather than have your arms locked out in front of you. This will also help with fatigue if you rely on your legs and feet to support your weight better rather than using your arms which is what people naturally tend to do when they sit on a bike, even one that's very upright like the 250r. Earplugs and relaxed grip should be cheap and effective. I'd try those before the other suggestions. Some of us can go on motorway trips, with standard sprockets and IRC tires and not feel fatigued at the end, so we must be doing something different (well ok ear-plugs). Try it before you buy something you don't need, you might be surprised.
My vlogs on Youtube are here |
March 9th, 2010, 06:58 AM | #23 |
Ride it like you stole it
Join Date: Jan 2010 Motorcycle(s): '09 Ninja 250R, '04 R6(sold) Posts: 362
March 9th, 2010, 07:19 AM | #24 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Its not that bad...Sure finding some windy backroad is way more fun, but the 250 will run fine on the interstate.
I think the key is staying loose. If you white knuckle it at that speed, every little muscle flinch you do will get translated into the bike. Take a deep breath, relax, and enjoy the ride. And with the cooler weather, bundle up and stay warm. If you are shivering, the bike is gonna feel it and act funny. Most of what you think is unstableness in the bike is actually the bike responding to you, not to the road. Get yourself in check, and the bike will follow suit. |
March 9th, 2010, 08:22 AM | #25 |
I regularly wear earplugs when riding (went so far as to mount a pillbox to the dash to hold them so I always have a pair) and on the particular ride in question I did make a point of keeping a loose grip on the bars. I learned early on with the scooter (with its agressive rake and tiny wheels) that stranging the bars is counterproductive. We're forecast for rain for the next few days so I'm probably not going to be headed out onto the interstate for any distance riding until the weekend. We'll see if proper tire pressure maintenance takes care of the wandering feeling.
March 9th, 2010, 08:25 AM | #26 |
Also the fatigue is mostly mental as the squrrely seat of the pants sensations kicks off a little adrenaline and jacks up my already focused mental state such that by the time I hit the kill switch it feels like I took the LSAT all over again.
March 9th, 2010, 09:03 AM | #27 | |
March 9th, 2010, 09:54 AM | #28 | |
Fastly Slow!!!
March 9th, 2010, 11:07 AM | #29 |
Honestly, I would do this mod 100 times over. I did the 15/41 swap and was amazed at what a difference it made with the bike. The buzziness and high-strung tendancies were completely removed. My buddy, who also has an '08 250R, liked it so much that he did the same thing. It basically stretches out the powerband a bit more, adding some top-end flexibility. It doesn't take it too far, as 6th gear still has acceleration in it. This isn't a set-up for everyone though. Obviously, people who do regular track days and such will find this useless. I commute alot, plus some spirited riding around the area and the sprockets are great for it. Single best mod for the bike, IMO...
P.S. I'm not trying to hijack the thread and turn it into a tech discussion or anything like that. Just giving the reason why my bike is fine on the highway... Posted via Mobile Device |
Throttle Cable Snapped while on Interstate | SafetyPaws | 2008 - 2012 Ninja 250R Tech Talk | 17 | July 21st, 2014 11:43 AM |
Interstate/Early Morning Ride | Outlander Systems | Videos | 11 | August 6th, 2011 04:32 PM |
US Fish and Wildlife authority on the interstate? | backinthesaddleagain | Off-Topic | 23 | September 21st, 2010 10:57 AM |
Interstate Riding | hoodadooda | General Motorcycling Discussion | 19 | August 28th, 2010 03:21 PM |
Interstate 29 North of Omaha Incident | Lasorcier | General Motorcycling Discussion | 7 | August 11th, 2010 12:05 PM |
