Old September 10th, 2012, 05:31 PM   #81
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Originally Posted by dfox View Post
It's the way my mind works, the way I view the world. I see things in concepts, not in definitions. My spatial reasoning is how I interact with the world. I see things in my head in four dimensions. I can visualize how the center of gravity shifts and how that changes the distribution of weight between the front and rear tires. I can visualize why counter steering works, instead of just having someone tell me it does and learning strictly from experience. I understand this is not the way the normal person views the world, and don't think that my way is better or worse, I just have a different skill set, which is why I am an engineer.
----> My Youtube! <----
Old September 10th, 2012, 05:34 PM   #82
ah yes, "cold tires". your post has me thinking... what other gases could be used outside of standard air (nitrogen/oxygen) and how would their viscosity effect the handling of the tire? how hard would it be to make a gas that is quicker to compress than it is to decompress? lol i wonder what air motogp tires run
I had friends using helium for some time.
Results: minimum weight and inertial momentum saving and increased rate of leaking out.
Opposite to liquids, the viscosity of gases increases with the temperature.
Gases act like springs: they store energy and release the same amount later; hence, I see very difficult that such a gas is achievable,.............but not impossible, I guess.
I don't know what GP tires use.
Here are a couple of schematics that show how the shape and size of the contact patch changes with lean angle for some tires, which was what started this discussion.
A couple of posts at the beginning of the thread (#3 and #12) pointed out the contact patch-lean angle dependance.
Old September 10th, 2012, 05:39 PM   #83
Kevin2109
KThanksBye
Kevin2109's Avatar
Probably Nitrogen, If I had access to some all the time thats what I would be running. Its not effected by temperature and takes longer to leak out
Old September 10th, 2012, 05:42 PM   #84
dfox
dfox's Avatar
Motorcycle(s): 08 250R
The air in your tires is already roughly 75 to 80% nitrogen, enjoy it for free...
dfox is offline   Reply With Quote
Old September 10th, 2012, 05:43 PM   #85
yes. i am also an engineer. i also have an imagination. you are not unique in your "abilities"
however you have not answered my question. aside from a generic "level of grip related to forces applied to tire", there is no benefit in terms of kinetic ability or spacial reasoning to knowing how to accurately describe the forces applied on the tire.
lets take your countersteering example. i also try to visualize the exact effect and understand how it works. i understand that the countersteer pulls the front wheel one way causing a rotational moment, tilting the top of the bike away from the turn (into the intended direction). but at the exact same time, knowing that does absolutely nothing for me in terms of ability to operate the handle bars. regardless of knowing or being able to describe how counter-steering works, you push on the inside bar, you lean. you don't need to know the internal mechanisms to understand the relation between input and output. you of all people (an engineer, someone who prides them self on logically dissecting the functionality and construction of an object) should know that's the beautiful thing about neural networks.
Old September 10th, 2012, 05:54 PM   #86
dfox
dfox's Avatar
Okay, this is just getting out of control. You obviously have some reason to keep arguing, and I do not. Understand that I enjoy knowing the physics behind what I do in life, and believe it increases my ability to understand the upper limit of my abilities.
Old September 10th, 2012, 06:03 PM   #87
Did anybody go back to see edited post #1?
This may be the first Jiggle's thread that has branched off out of his brilliant control !!!
Old September 10th, 2012, 06:07 PM   #88
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I don't care enough to argue physics
AFM #676
Supersports are for n00bs
Old September 10th, 2012, 06:18 PM   #89
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
You're all saying the same thing
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old September 10th, 2012, 06:23 PM   #90
Felipe the Ant
Everyone talks about contact patch like its the end all.
Simple physics shows that until you lose traction, or are talking about melting rubber (think drag racing), contact patch means nothing.
and you're all missing the first part of his statement
Old September 10th, 2012, 08:07 PM   #91
Originally Posted by Jiggles View Post
THIS IS A DISCUSSION THREAD ON CONTACT PATCHES, EVERYONE ELSE GTFO
Baaahahahahaha!
Old September 10th, 2012, 11:45 PM   #92
Domagoj
Your views remind me of my own at a time.
Yes, you are right, there was some confusion between terms grip and friction.
There is a very nice sentence that @Motofool has posted. It is the essence of what I tried to say before buy my clumsy english did not allow me to express myself accurately. I forgot to quote so I'll just paste it here:
"...rubber as a material is something between a solid and a very viscous liquid; it is compressible, so it digs deeper into the crevices of the pavement under higher normal force; its characteristics vary with temperature."
It is important because it emphasizes two very very significant factors.
First, being something between solid and viscous liquid, rubbers does not conform accurately to the friction formula for solid rigid bodies, which we discuss here.
Second, it changes state with temperature change. Cold rubber is completely different than a warmed up rubber.
Back to the formula.
Ff = coefficient * Fn
Elementary school math explains the relations between the two. It is clear to everyone that with CONSTANT coefficient, Ff (Force of friction) can be increased only by increasing Fn (normal force). Following this trail of thought leads to a simple solution that smaller contact patch leads to larger Fn and hence larger Ff.
What I'm saying here, is that coefficient is NOT CONSTANT, it is a function of temperature, contact area (contact patch) and other things. The question that I cannot answer is how exactly that function looks like.
Experience tells us that coefficient will increase as temperature increases, up to a certain level, then it will reach a maximum, and then keep dropping as tires overheat more and more. Typical example of this is too many laps with road tires on a track. Once your tires overheat you crash.
Experience also tells us that coefficient will increase as the contact patch increases, because there is a better chance with larger area that warm rubber will dig into the crevices of the road. This will also reach a maximum, and after it will keep declining because the normal force decreases and at a point becomes insufficient. Typical example is a light car with too wide tires, a common "tunning" mistake people like to make. The ground pressure becomes so small that the car actually looses grip.
Can you accept this as a plausible explanation for track tire behaviour?
Road tires also have a fluctuating coefficient, but much less so. They are much closer to a rigid body, formula becomes more accurate, and increase of contact patch does not bring benefit because the coefficient does not grow quickly enough in relation to the drop of normal force.
Old September 11th, 2012, 01:08 AM   #93
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
I'm starting to think the "d" in "dfox" stands for "douche."
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old September 11th, 2012, 06:37 AM   #94
Fappy
Fappy's Avatar
Motorcycle(s): 2007 Ninja 650R, 2008 Ninja 250R (sold)
So now back to tires. When you open the throttle during a turn, the torque applied to your wheel times the radius of the wheel is a force that propels the bike forward. But at a certain lean angle (or a big enough throttle opening), μmgcosθ (magnitude of friction due to normal force, unless I got the wrong trig function) will be less than the applied force on the back wheel, due to turning, and the wheel will spin or slide, even if the back of the bike squats and loads the back wheel.
So if we apply that same force from turning (same squatting rear, same throttle input, same lean angle) over a larger area on the same compound (but wider) tire, the pressure between the contact area and the idealized gym floor road would be less. Each unit area, dA, would have less force acting on it because the total friction force is split up over a larger area, so each individual dA would not be asked to deliver a force larger than μmgcosθ and the tire will not break loose. That's my logic.
I guess maybe I'm thinking grip (the probability that the tire will maintain traction - I liked your definition) and I'm using the word "friction"? I dunno, I just feel like they wouldn't use wider tires if they didn't have to; they impede how quickly the bike can lean over. But they also make identical tires in a 160 and a 180, so it's not just that a better compound is available in a wider tire.
My head is confused. It's nice outside. I don't have a ton of hw, and I already went to physics class today.
So essentially here, if you imagine a 60-foot wide tire, as opposed to a 5" wide tire, as long as they both have the same mass and material, the friction maintained by each tire would be exactly the same. Yes, you're exactly right that each unit area of floor/tire dA would have less force acting on it, and thus would be able to maintain grip for longer... IF there were also the same amount of normal force acting on each dA. But with that larger tire that weighs the same, the normal force on each unit area is proportionally less, such that the friction in the end is the same.
This actually brings up another benefit of using a wider tire in the real world, though. Aside from having a greater probability of reaching an area where grip is better, wider tires also usually have greater mass. Greater mass will hurt the bike's overall acceleration, BUT the tradeoff is that a heavier tire will be able to supply a greater frictional force to the rear of the bike because of the increased normal force acting on it.
Hope I cleared it up a bit?
Fappy is offline   Reply With Quote
Old September 11th, 2012, 06:42 AM   #95
Yeah that helped. I guess I just didn't take the normal force being proportionately less into account, which explained why I was confused.
Thanks for addressing my individual steps of thought.
Old September 11th, 2012, 06:47 AM   #96
Fappy
Fappy's Avatar
The tires are designed to maximize the contact patch, yes. But it's not for the reasons you might think. As was mentioned previously, maximizing the contact patch maximizes the probability that grip will be maintained over an irregular surface. It still does nothing to increase friction forces, but it DOES help to maintain so-called "grip".
See mah previous postzzs.
Friction != grip. These are separate things
Old September 11th, 2012, 06:50 AM   #97
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
hmmm, I think jiggles tagged dfox's tires. Cause nobody on the internet argues about physics/math/science stuff for 3 pages, unless your on 4chan....
Where can I get a white marker for rubber?
Old September 11th, 2012, 07:13 AM   #98
Silver sharpie
Old September 11th, 2012, 09:20 AM   #99
and the cookie goes to... Domagoj!
Old September 11th, 2012, 09:22 AM   #100
dino74
dino74's Avatar
I'm with you
To me, its all the same difference...
CVMA #55
Old September 30th, 2012, 04:36 PM   #101
Dragonracer76
Dragonracer76's Avatar
Exclamation Speaking of contact patches...
Check out what the PO of my new ninjette left me... I can't wait until my new ones get here. Corners feel squirrely as hell with wannabe car tires..
Beards make everything better. ATGATT
Dragonracer76 is offline   Reply With Quote
Old September 30th, 2012, 04:37 PM   #102
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Wow, how many miles on that bike?
AFM #676
Old September 30th, 2012, 05:02 PM   #103
Dragonracer76
belive it or not...
10,000. I think he never got it over 50 or something. haha He was a bit older than me and just used it for commuting to work.
Old September 30th, 2012, 06:01 PM   #104
Seems like a kickstand is optional on that bike. Just stop and get off; it's not going anywhere.
Old October 1st, 2012, 08:54 PM   #105
Dragonracer76
Hahaha.. no doubt. like a built in center stand. You can see I've barely rolled over them on my way to school a couple of times. It'll be a much more fun trip once they're sorted.
The first 7 miles are twisty through the hills and woods, followed by a long run down a brand new 65mph highway, then into town.. coming home is better though. ...save the best for last..
[motorcyclenews.com - sport] - Valentino Rossi: Extra motivation and pressure after L Ninjette Newsbot Motorcycling News 0 June 27th, 2013 09:50 AM
[roadracingworld.com] - Repsol Honda: Three Riders Will All Have Different Motivation Ninjette Newsbot Motorcycling News 0 November 1st, 2011 09:40 AM
[sportrider - latest stories] - Motorcycle Rider's Motivation - What Drives You? | St Ninjette Newsbot Motorcycling News 0 September 6th, 2011 05:30 PM
Motivation alex.s Off-Topic 12 July 7th, 2011 09:14 PM
My motivation at work Mr.E General Motorcycling Discussion 7 May 16th, 2011 01:29 PM
