April 25th, 2015, 12:24 PM | #1 |
Join Date: May 2012 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 38
Throttle Sticking When Steering Right
After doing some maintenance on the carbs and checking the valves, I put my bike together and now the throttle sticks when I steer to the right. When pointed straight and to the left the throttle snaps back perfect, but when I steer right it sticks really bad. Any ideas?
I thought it was a bad, bent bar that was causing it but after ordering a new bar and installing it the same problem is there. |
April 25th, 2015, 12:51 PM | #2 |
Cables are binding, recheck them, make sure They are not, also lube them while your there.
April 25th, 2015, 12:54 PM | #3 | |
When you say the cables are binding? What do you mean? |
April 25th, 2015, 12:57 PM | #4 |
Binding as in the routing is wrong, causing one if not both to twist slightly, also make sure that the cable itself is properly adjusted, and has some slack, too not enough slack will cause your problem.
April 25th, 2015, 01:12 PM | #5 |
How do I give it some slack? Do I do it to both cables or just one?
April 25th, 2015, 01:54 PM | #6 | |
The manual of your bike shows a specific way of routing those two cables. Unfortunately, I cannot find the schematic to post it here. That routing ensures that the cables bend equally for both extreme turns of the handlebar. What may happen now is that the bend is excessive when turning it right and the spring in the carburetors cannot overcome the internal resistance of the cable.
April 25th, 2015, 02:07 PM | #7 |
You have three points, two of which is down by the carburetors, by adjusting the the two cables, pull/push, the third one is more of a fine adjustment, up on the right controls.
April 25th, 2015, 03:19 PM | #8 |
Thank you very much Ghostt, it was an adjustment issue, indeed. I didn't have enough slack on the pull cable on the carb.
April 25th, 2015, 04:56 PM | #9 |
Very good, glad it was simple and cheap fix, like my prom date
Carb sticking | 102dalz | 2008 - 2012 Ninja 250R Tech Talk | 3 | November 2nd, 2014 02:37 PM |
Front Brake is sticking...Help! | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 19 | October 25th, 2014 05:30 PM |
Throttle sticking, need help | WiffleBiscuit | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 1st, 2014 05:11 PM |
[crash.net - MotoGP] - Sticking throttle spoils Reddingâ??s debut | Ninjette Newsbot | Motorcycling News | 0 | March 20th, 2014 04:00 PM |
2010 throttle sticking? | wtfh4xx | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 1st, 2011 01:14 PM |
