October 17th, 2017, 11:00 AM | #1 |
[motorcycle.com] - 2018 Ducati Monster 821 Revealed
Ducati announced an update to the Monster 821, making it look more like the Monster 1200, including the larger model’s TFT screen. The model refresh comes on the 25th anniversary of the Ducati Monster family, and will be the first of five new or updated motorcycles Ducati will showcase in a couple of weeks at EICMA. The Ducati Monster 821 receives a new tail design that looks similar to the Monster 1200. The 821 also gets the larger Monster’s round headlight with a halogen bulb with LED “horseshoe” side lights, as well as the 1200’s fuel tank, which unfortunately also reduces fuel capacity from 4.6 gallons to 4.36 gallons. The tank does add an attachment clip, a nod to the original M900. The exhaust also looks similar to the unit on the Monster 1200. The engine remains unchanged, but the new silencer does reduce the 821’s performance numbers, reducing the claimed peak power from 110.5 hp to 107.3 hp at 9250 rpm, while claimed torque output is reduced from 65.9 lb-ft. to 63.4 lb-ft. It’s an odd choice, considering the 2017 Monster 821 was already Euro 4 compliant, and the changes actually increase emissions slightly while reducing fuel economy by 1.7 mpg to 43.5 mpg. The Monster 821 will again offer three power modes, an eight-level traction control system, and a three-level Bosch ABS system. Ducati replaced the old model’s LCD display with a full color TFT display with fuel gauge and gear indicator. Bluetooth connectivity is available with an optional add-on. Other changes include separate rider and passenger foot peg mounts, while a quick shifter is now available as an optional accessory. The 2018 Monster 821’s chassis is fairly similar to last year’s model. Suspension remains the same 43mm upside-down fork and adjustable rear shock with progressive linkage. The braking system is also the same, with radially-mounted Brembo M4-32 monobloc four-piston calipers and twin 320mm rotors up front and 245mm rotor and two-piston caliper at the rear. The 2018 Ducati Monster 821 will be offered* for $11,995 with three color options: red with matching trellis frame, black with a black frame, or yellow with a black frame. 2018 Ducati Monster 821 Revealed appeared first on Motorcycle.com. Click here for full story...
[motorcycle-usa.com] - 2015 Ducati 821 & 1200 S Monster Stripe | Ninjette Newsbot | Motorcycling News | 0 | November 3rd, 2014 07:40 PM |
[motorcycle.com] - 2015 Ducati Monster 821 Review – First Ride | Ninjette Newsbot | Motorcycling News | 0 | June 30th, 2014 05:20 PM |
[RoadRUNNER] - Ducati Unveils New Monster 821 | Ninjette Newsbot | Motorcycling News | 0 | May 30th, 2014 03:15 AM |
[cyclenews.com] - First Look: Ducati Monster 821 | Ninjette Newsbot | Motorcycling News | 0 | May 28th, 2014 07:50 PM |
[motorcycle.com] - 2015 Ducati Monster 821 Revealed | Ninjette Newsbot | Motorcycling News | 0 | May 28th, 2014 08:40 AM |
