September 8th, 2010, 08:41 PM | #1 |
Join Date: Aug 2010 Motorcycle(s): 2007 Blue Ninja 250R Posts: 650
Stranded :(
So.. today I tested my AAA membership (it works..) and had my poor lil Ninja towed back home
I was on my way back home from work and noticed right away my Ninja was idling funny.. and as soon as I picked up some speed on a longer stretch of road, it died on me as I was happily cruising at around 7K rpm.. WTF? So I come to stop, pull over to the side of the road and try to start it back up. After to 15th attempt and nothing happened, I called up my hubby and he eventually managed to start it. But something wasn't right still.. the bike still wouldn't idle correctly although fully warmed up, and sure enough, as soon as I hop on it and head back home, 2 lights down the road the bike dies again. I start it back up.. and after another couple lights, it dies again. This time for good We tried everything: turned the fuel thingy to reserve, turned it back to ON, choke on, choke half way, choke off. Nothing. My husband's good working on cars but not on bikes so we eventually gave up and called AAA, that took the bike back home. We'll get another free ride to the dealer this weekend. Now I'm without my baby, and I'm really sad!!! |
September 8th, 2010, 08:46 PM | #2 |
Its funny AAA doesn't cover bikes in RI, varies by state. I have AMA membership which provides towing if needed. Sorry to hear bike is dead. If you remove fuel line and open petcock does fuel flow ok? Can put a meal can or something to catch the gass. Wonder if you are getting spark?
September 8th, 2010, 08:49 PM | #3 | |
September 8th, 2010, 08:51 PM | #4 |
maybe carbs need cleaning, or bad gas? could empty tank and try a little fresh gas...
September 8th, 2010, 08:58 PM | #5 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
Please post back on what the problem was for us nerd cataloging the issues... :P
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
September 8th, 2010, 08:59 PM | #6 |
Next time try to open the gas tank cap, and see if the symptoms go away. For a bike that's running well to suddenly die in the way you're describing, a common problem is some type of venting issue that isn't letting the gas exit the gas tank quickly enough to keep the float bowls full.
September 8th, 2010, 09:01 PM | #7 |
I was going to suggest that, but wasn't sure if this was an issue with the pregens, too.
September 8th, 2010, 09:02 PM | #8 |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
Yikes! I'm glad you managed to get home safely, but I'm sorry you had to go through that.
This problem can be anything....but it'll be easy to diagnose. The dealership should be able to solve this no problem....but the bike's pretty easy to work on so maybe you and your husband can try and problem solve it a little first? It may help take away the 'mystique' of all the mechanical bits and make you more confident with the bike. Start with the basics. Make sure the engine is getting: 1. Air 2. Fuel 3. Spark This problem exists because one of those 3 things isn't getting where it needs to be. |
September 8th, 2010, 09:03 PM | #9 |
It's an issue with all bikes, but more prevalent on carbed bikes where there isn't a fuel pump to overcome any venting anomalies.
September 8th, 2010, 09:03 PM | #10 | |
September 8th, 2010, 09:05 PM | #11 | |
September 8th, 2010, 09:18 PM | #12 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
I hope you get it figured out, you just started commuting on it too... Carbs can be PITA sometimes
09 ninja 2fiddy SE Driving slow things fast |
September 8th, 2010, 09:19 PM | #13 |
September 8th, 2010, 09:29 PM | #14 |
I hate driving...
They should make a direct fuel injected ninja 250r, now that would be awesome, might even make more power over the carb'ed versions if they tune it right. Though I haven't seen direct injection on motorcycles attempted or even planned
September 8th, 2010, 09:32 PM | #15 |
As long as I don't have to deal with a choke any longer.. I'm happy
September 8th, 2010, 09:37 PM | #16 |
I hate driving...
I never could really use my choke just makes my bike act weird so +1 for the FI. After I shimmed my needles using the choke worked better but now I don't really need it with the needle shimming. When I first was looking at the new ninja I expected it to be fuel injected then I found it was carburated. I was like wow carbs still exist in this day and age...Not that carbs are horribly bad or anything but everything has to be in a nearly fine balance with these machines.
September 8th, 2010, 09:38 PM | #17 |
Sigh.. going to work in my car tomorrow
September 8th, 2010, 09:41 PM | #18 |
I wouldn't think I'd need it either considering where I live and the temperatures we get.. but my bike always needed a bit of choke to start up no matter what. I know the previous owner played with it to make it run a bit better, but no sure what he did.. and it doesn't look like it worked anyhow
September 8th, 2010, 09:45 PM | #19 | |
I hate driving...
September 9th, 2010, 09:26 AM | #20 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250 x2, Ninja 650R Posts: 165
Also check the fuel tank vent hose under your seat. If your seat pinches it, it can cause the symptoms you described.
The Rally - Oklahoma |
September 9th, 2010, 09:30 AM | #21 |
Join Date: Jun 2010 Motorcycle(s): 2010 Ninja 250R Posts: A lot.
awww Rosie, i'm sorry. Hopefully your baby will get fixed up and we can laugh at this day later...much later.
sometimes I aim to please, but mostly I shoot to kill |
September 9th, 2010, 09:48 AM | #22 |
September 9th, 2010, 12:36 PM | #23 |
It kinda sounds like your fuel filter may be clogged.
September 9th, 2010, 12:39 PM | #24 |
September 9th, 2010, 12:40 PM | #25 |
September 9th, 2010, 12:43 PM | #26 |
HA!!! where are all those folks that told me i should buy used. And alas, my reasons have come clear...
September 9th, 2010, 12:45 PM | #27 | |
I'd but used again, but this time I'd want everything documented. P.S. My hubby agrees with you though |
September 9th, 2010, 12:46 PM | #28 |
Rosie, probably be something simple.
September 9th, 2010, 12:48 PM | #29 |
September 9th, 2010, 12:57 PM | #30 | |
So what are you going to do? taking it to a shop?
September 9th, 2010, 01:36 PM | #31 |
September 9th, 2010, 01:45 PM | #32 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
I had a new 2007 before I grabbed the 2009. My idle screw would work itself down and I'd have to readjust it a few times to get the idle up so that it would operate properly. Seems I would hit it when fiddling with some wiring and the vibration would bugger it up occassionally. Just my 2cents is all.
September 9th, 2010, 01:47 PM | #33 | |
September 9th, 2010, 03:18 PM | #34 |
So far, every problem we had involved that "Weasel Piss" that is passed off as gasoline. It affects lawn mowers, chain saws, outboard motors, and, yes, our cherished bikes. The only solution, at least in our case, has been to use Marine Stabil (The Blue stuff) every time we fill up. Also buy your gas at high volume stations--the ones that fill their tanks frequently. Gas has a very limited shelf life. You are also safer if you buy Regular 87 Octane gas--since that is used more often in most cars. You may pay a little extra for the gas but it is a good idea to stick to the known brands. In our area it is Shell, Mobil-Exxon, Sunoco, and Irving. We stay away from the Kwik Fills, No Names, etc. My 2 Cents worth
September 9th, 2010, 03:27 PM | #35 | |
September 9th, 2010, 03:34 PM | #36 |
Rosie, Your Kawi mechanic will have the problem sorted out in no time. Best he gives your baby a clean bill of health and then you will be safe and enjoy your ride a lot more.
September 9th, 2010, 03:44 PM | #37 |
Can you describe how it's idling funny (rpm hanging, never warming up?). Maybe we can figure it it before Saturday
Any chance you have non-stock grips? When I changed out my grips, the grips were longer so the rubber would catch on the bar ends and cause the throttle to stick. Likelier answer is that the throttle cable hasn't been lubed in awhile. |
September 9th, 2010, 03:56 PM | #38 |
September 9th, 2010, 04:01 PM | #39 | |
September 9th, 2010, 04:07 PM | #40 |
check to see if the clamps on either side of both carbs that attach them to the rubber boots are loose. give the clamp screws a 1/4 turn each to be sure.
also, look for loose/disconnected or damaged vacuum hoses in that area. |
Stranded: Need help with ignition/battery | Samer | 2008 - 2012 Ninja 250R Tech Talk | 9 | September 1st, 2013 05:14 AM |
Just found myself stranded on a not so abandoned Island :] | imataiwanezz | New Members | 8 | February 23rd, 2012 10:20 PM |
[topix.net] - Brad Pitt stranded by motorcycle mishap | Ninjette Newsbot | Motorcycling News | 0 | September 14th, 2010 03:40 PM |
[topix.net] - Stranded biker, BMW Motorcycles has an app for that | Ninjette Newsbot | Motorcycling News | 0 | July 22nd, 2010 02:30 PM |
[superbikeplanet.com] - Pedrosa: It's Better Than Being Stranded ... | Ninjette Newsbot | Motorcycling News | 0 | April 19th, 2010 11:40 AM |
