May 7th, 2009, 12:45 PM | #1 |
Pimpin
Join Date: Nov 2008 Motorcycle(s): Bunch of em Posts: 973
Hard starting... tight valves?
My racebike has 2400 miles on it and is getting harder and harder to start. Someone told me that if the valves are getting tighter, it will result in harder starting. Any feedback on this from you mech types?
May 7th, 2009, 02:39 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE Posts: 564
My bike takes a little extra cranking to start after a hard run in the high RPMs (no doubt where your bikes are run) Mine has 12000kms on it and is going for the 12000km service on Monday. I will see if I can get the valve specs before and after as a reference. Try taking it for a soft run for 10 mins (as if you were on the road) and see if that makes a difference.
2008 GREEN Kawasaki Ninja 250R. AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen |
May 7th, 2009, 04:55 PM | #3 |
self wrencher
May 7th, 2009, 05:11 PM | #4 |
Ms. Personality
What do you mean by the valves getting "tight?" If by that you mean that the clearances are too small and the cam is resting on the valve and keeping it partially open all the time, you could possibly have starting problems due to low compression. In fact, I'd get that checked out right away before you possibly bend a valve or cut a hole in a piston.
A simple compression check may yield an answer. If it holds compression you should be ok, if not more than likely you have a "leaky" valve due to it being open even when it's supposed to be closed. Just a thought. |
May 7th, 2009, 06:25 PM | #5 |
IC2(SW)
Also, the new valve train is suppose to be a bit better. The clearance should be more as it wears. The only way its gonna get tighter, is if the valve seats are screwing up(soft). Time for a clearance check, good piece of mind
May 7th, 2009, 06:28 PM | #6 |
Ms. Personality
Richard, do you break in your bikes in any way before racing them?
May 8th, 2009, 10:07 AM | #7 | |
Pimpin
Time to bring in the big guns |
May 8th, 2009, 10:09 AM | #8 | |
Pimpin
For break-in, I do 5 heat cycles, including (2) 20 mile sessions on the track not exceeding 8000 rpms. Then I change the oil and let em rip |
May 8th, 2009, 12:30 PM | #9 |
Ms. Personality
There are lots of theories on break in. Basically they need to heat cycle and get lots of oil changes. Sounds like you are doing a fine job there.
May 10th, 2009, 07:35 AM | #10 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
PLUGS PLUGS PLUGS what did the plugs look like?? Thats where I start when trying to figure out "whats wrong here". Might be way too rich and fouling the plugs???
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
Hard starting in cold weather | scorch | 1986 - 2007 Ninja 250R Tech Talk | 23 | May 13th, 2016 08:25 PM |
[motorcyclistonline] - Hard-Starting FJ1200 | FAQs | Ninjette Newsbot | Motorcycling News | 0 | November 29th, 2014 10:40 PM |
bike running lean, hard starting | d16soda | 1986 - 2007 Ninja 250R Tech Talk | 19 | October 25th, 2011 09:25 AM |
Bike had a hard time starting | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 14th, 2011 05:10 PM |
Tight valves=Popping? | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 15 | April 11th, 2010 04:07 PM |
