Old October 3rd, 2012, 04:49 PM   #521
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
Originally Posted by n4mwd View Post
Just sayin, since you have the old throttle body you can just remove each plastic injector one at a time and wiggle it out. A single screw holds it in. You don't have to remove the whole throttle body. Doing that may be a major pain depending on your configuration.
Thank god.
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old October 3rd, 2012, 05:00 PM   #522
ecotrons
Originally Posted by 138 View Post
Matt:
I'm looking at the read out from the data log and I'm curious as to why the error condition for the MAP sensor hasn't been met. I'm obviously not criticising or anything but I'd like to make sense of these numbers. Thanks!
Because MAP sensor and Crank sensor are good. Otherwise you don't have normal sparks and injections at all. ECU detect engine phase by both sensors.
Here is a plot of your data. That's why I think the valves are till problematic, at least the reason for the crappy run the other day.
ecotrons is offline   Reply With Quote
Old October 3rd, 2012, 05:17 PM   #523
lolibater
lolibater's Avatar
We're going to film us doing the valves in HD so that you guys can point out what we are doing wrong.
Old October 3rd, 2012, 06:53 PM   #524
n4mwd
n4mwd's Avatar
Backflow
The last I heard, the Ninja is supposed to have a little backflow at the beginning of the compression cycle. The intake valve is intentionally held open a little ways into the compression stroke. This causes the bike to have greater efficiency - more power, more MPG, less noise from the muffler.
My Ninja Blog
Old October 3rd, 2012, 06:57 PM   #525
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Perhaps someone else with an ecotrons kit on a pregen can log some data from the MAP sensor to see if its consistent?
AFM #676
Supersports are for n00bs
Old October 3rd, 2012, 09:12 PM   #526
I have some data somewhere. Let me see about digging that up...
EDIT: I don't have the disk with me atm so I can't take a screen shot, but I'm not sure if we can even upload that type of files here anyways?
Anyhow Matt, you have some logs from me when I was getting set up. You're more than welcome to use those as a comparison if you'd like.
Old October 4th, 2012, 05:30 AM   #527
n4mwd
n4mwd's Avatar
Show what you are calling the "1|T" and "2|T" mark. I know there are some people that don't use the marks, but they are pros. Newbies should use the marks - especially when there is a question as to whether it was done right.
Attached is a photo of the two marks. Note that the hole is not directly above the mark, so you have to look at a sharp angle to see under the housing.
I think there is also a "1|B" mark on there which is used for something else.
My Ninja Blog
Old October 4th, 2012, 05:44 AM   #528
n4mwd
n4mwd's Avatar
________________________________________________________
Send your tasteful nudes to Jiggles@ninjetteporn.com
Seriously Jiggles, you actually registered ninjetteporn.com ???
My Ninja Blog
Old October 4th, 2012, 06:29 AM   #529
lolibater
lolibater's Avatar
I will take pictures of it on saturday, but yes, those were the marks we used.
Old October 4th, 2012, 07:24 AM   #530
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Wasn't me
AFM #676
Old October 4th, 2012, 07:30 AM   #531
lolibater
lolibater's Avatar
Jiggles, you know you wanna come bring your bike over for working EFI comparison purposes on saturday
Old October 4th, 2012, 07:34 AM   #532
n4mwd
n4mwd's Avatar
He never installed his. He can bring the parts though.
My Ninja Blog
Old October 4th, 2012, 07:39 AM   #533
lolibater
lolibater's Avatar
THe MAP sensor @ecotrons mailed should be here by then anyways, even though we think the current one is good to go.
I guess we will be filming the valve adjustment and also filming the removal of the injectors and spraying them into the air.
Old October 4th, 2012, 07:40 AM   #534
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I'm all carbs (for now)
AFM #676
Old October 4th, 2012, 07:43 AM   #535
lolibater
lolibater's Avatar
I wish I could say that at this point.
Question regarding my case: Is there ANY chance that the ECU could be to blame for this?
Old October 4th, 2012, 08:45 AM   #536
n4mwd
n4mwd's Avatar
ECU dead
After all that effort trying to get this thing installed. And finally doing it. The ECU is DEAD. No fuel pump running, no MIL light. Nothing. Dead.
EDIT: Referring to my installation and not lolibater.
My Ninja Blog
Old October 4th, 2012, 08:50 AM   #537
lolibater
lolibater's Avatar
Lol thank you for clarifying that. You almost gave me a heart attack.
How did you come to this conclusion for your kit though?
Old October 4th, 2012, 08:50 AM   #538
lgk
i doubt it, if the priming charge works.
Old October 4th, 2012, 08:57 AM   #539
n4mwd
n4mwd's Avatar
I kept getting an error in Procal when I tried to connect. I checked all my settings and they were right. Then I checked to see if the fuel pump comes on and it doesn't. There is no snapping of the relay. The little LED (MIL light) doesn't do anything either.
Perhaps Matt will chime in on this.
My Ninja Blog
Old October 4th, 2012, 08:58 AM   #540
Dumb question n4mwd:
is your key turned "on" when you try and connect the ecu to the computer?
Old October 4th, 2012, 09:03 AM   #541
n4mwd
n4mwd's Avatar
Yes. I tried it both ways. Tried disconnecting the ECU to restart it, but that didn't help either.
The ECU is dead. It should run the fuel pump for a few seconds and it isn't.
My Ninja Blog
Old October 4th, 2012, 09:08 AM   #542
Did you go through the troubleshooting tips that are on the pdf file included on the disk? There's steps of things to check for if the pump doesn't cycle when you turn the key to "on".
Does the computer show a connection at all to the ecu when they're connected and the ecu is powered?
Not to be insulting here, but are you sure it's installed correctly? We all forget small details sometimes.
Old October 4th, 2012, 09:20 AM   #543
n4mwd
n4mwd's Avatar
The only troubleshooting I got says that if the fuel pump doesn't come on for a few seconds after turning on the key - Check the wiring. I did and its all connected. The Pro Cal comes up and seems fine until I try hitting CONNECT. Then it gives errors. Does the same whether the key is on or off.
I tested the com port and it works. I don't think I forgot anything because everything is connected.
My Ninja Blog
Old October 4th, 2012, 09:48 AM   #544
n4mwd
n4mwd's Avatar
I just checked the fuses and they test OK. There are two of them. One is on the red battery wire and the second is on the green wire on the CDI connector.
I thought I had just figured it out, but the ECU is dead for sure. Its getting power, it just isn't doing anything with it.
My Ninja Blog
Old October 4th, 2012, 09:59 AM   #545
lolibater
lolibater's Avatar
I thought CDI was removed by installing the EFI kit?
Old October 4th, 2012, 10:01 AM   #546
EMSRacer07
EMSRacer07's Avatar
It is removed
Old October 4th, 2012, 10:02 AM   #547
EMSRacer07
EMSRacer07's Avatar
Maybe its the wiring. But it should communicate with the ECU if its correct. I would make sure everything is connected and powered correctly.
Old October 4th, 2012, 10:50 AM   #548
lgk
are you sure you the ecu plug is seated right?
mine was tough for sure
Old October 4th, 2012, 12:02 PM   #549
n4mwd
n4mwd's Avatar
The actual CDI box is removed. I was talking about the connector that used to connect to it. The new @ecotrons ECU takes over the CDI function. There is a fuse on the green wire that goes to the connector.
The fuel pump has two little female spade connectors and they are different sizes so you can't mix them up.
Yes, the ECU connector is set correctly. There is a lever and it is pushed down all the way.
I tried shaking the wiring harness while the key is set to ON and nothing happened.
I also followed the ECU reset procedure that Matt gave earlier in this thread. No change.
@ecotrons - Matt is there specific diagnostics for the ECU to see if its dead or not? Should I send it back?
My Ninja Blog
Old October 4th, 2012, 01:55 PM   #550
Jiggles
Jiggles's Avatar
MOTM - Apr '13
You only voided your TB's warranty right?
Try not to mod the ECU
AFM #676
Old October 4th, 2012, 02:14 PM   #551
lgk
ouch, jiggles is on a roll today
Old October 4th, 2012, 04:53 PM   #552
n4mwd
n4mwd's Avatar
No I haven't added a new pulley to the ECU.
I'm not able to get it to show any signs of life. So it should still be covered under warranty. I'll try to post a video later.
My Ninja Blog
Old October 4th, 2012, 05:13 PM   #553
lgk
Did you check all the relays and fuses?
Old October 4th, 2012, 07:36 PM   #554
ecotrons
One good start data, plotted as below:
Note, only it's comparable before the engine fires, because after fired, the MAP signal changes much faster.
Old October 4th, 2012, 07:50 PM   #555
Is that my data?
Old October 4th, 2012, 08:14 PM   #556
n4mwd
n4mwd's Avatar
Yes all the fuses and relays are good.
I also noticed tonight that the ECU was sort of warmish after sitting several hours with the key off but still connected to the battery.
I don't think the ECU is supposed to get warm like that when its off.
Matt, any suggestions? Should I send it back?
My Ninja Blog
Old October 4th, 2012, 08:15 PM   #557
ecotrons
Is that my data?
I am not sure. But below one is just downloaded from your email. To make sure. Same as a good case.
Old October 5th, 2012, 04:35 AM   #558
lgk
what year bike is it?
Old October 5th, 2012, 05:11 AM   #559
n4mwd
n4mwd's Avatar
2007 Ninja 250.
My Ninja Blog
Old October 5th, 2012, 05:33 AM   #560
lgk
did you try the reset procedure earlier in the thread?
how the voltage on the battery?
ecotrons tech questions. bigbadbob 1986 - 2007 Ninja 250R Tech Talk 1 April 17th, 2015 10:50 AM
Ecotrons map swarfman64 2008 - 2012 Ninja 250R Tech Talk 2 January 15th, 2015 06:09 AM
WTB:Ecotrons petcock crimsondragon Items Wanted 2 September 21st, 2014 06:54 AM
Ecotrons kit garth285 Items Wanted 0 June 17th, 2014 05:09 PM
Ecotrons Gen2 FI Kit Install Terminal 1986 - 2007 Ninja 250R Tech Talk 85 October 15th, 2012 02:02 PM
