January 22nd, 2013, 10:45 PM | #1 |
Sync Carb must after Jet Kit installation?
Hi,
Here is a story of my bike. Bike run fine with stock setup from factory (even with slip on). After reading all thread and jetting dabase I purchase Factory Pro jet Kit. And this is what I do : 1. I installed/replace the needles and put eclip on 3 and 3 washer above. I ride my bike and notice at 9K bike seem bog and won't past 9k. (hard to climb from low end). Mixture screw Left 2.5 Right 2.5 as factory pro instruction. 2. Then I try to lower the needle and I put eclip on 2(put 2 washer above), test ride again and feel pull strong on low end and midrange, but whe I rev the thortle, it seems any hesitate the rev to high. Mixture screw 2.5 both. 3. I try eclip still on 2 (1 washer above clip and 1 washer under eclip). Test run bike seems ok but not as pull hard from low. Mixture screw 2.5 both. So my question is which combination was close to right setup and should I sync carb after installed jet kit? Because I play with the mixture screw and change with Left 2 3/4 Right 2 on all my combination test above and look like better then stock FP mixture. all test using stock PJ and MJ thanks |
January 22nd, 2013, 10:50 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
Did you change the jets at all?
in number one, when it would bog, was that under partial throttle or full throttle?
January 22nd, 2013, 10:54 PM | #3 |
January 22nd, 2013, 10:58 PM | #4 |
MOTM - Apr '13
Try removing your snorkel and going with either option 1 or 2
January 27th, 2013, 01:49 AM | #5 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
I had this issue when I first did my rejet. The problem was my main jets were too big (main jets = high revs). I was using a stage 2 kit from FP. FP recommends using the 90 main with 40 pilot for a stock air setup.
If you (like me) bought the stage 2 kit, you'll need to remove the airbox and install pods if you want that jet kit to work for you. Otherwise, you'll need to go back to your stock 98 main and stock pilot (you can still use the FP needle to shim and get better response on the low/mid range).
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
carb sync | WELLS | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 19th, 2013 08:30 PM |
Carb/jet kit pictures | Ytse Frobozz | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 27th, 2012 12:09 PM |
Jet Kit Installation | ride2rideagain | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 27th, 2010 08:11 PM |
